Daily Randomness.........Back to Randomness........................................
28 minutes ago, chandlerGTi said:
how does this happen? Just minding my business...
one bolt at a time
thats how the nickname boltswagon came about
  • Replies 25.2k
  • VFR800
    2479
  • datzenmike
    2337
  • q-tip
    1360
  • hobospyder
    1255
10 hours ago, Ranman72 said:
and i still believe the 24 valve Cummins is one of the best motors
Just got back from a test run after the new exhaust install. The exhaust note is perfect, smooth and mellow, not too loud, not too quiet.
This is the only thing I have changed from stock on the engine. A 33% increase in pipe diameter, and all mandrel bends really made a big difference. The acceleration is much improved, turbo lag reduced. I stepped down on it a couple of times and was scrambling to grab another gear as it wound up.
Mmmmmm . . . . . torque.
I always go back to I would  rather be stroked then rammed
First time I heard that it was "Why stroke it, when you can ram it?"
4 hours ago, BrothersGarage said:
cops drag racing have a bit of a problem...
Notice what happens around 3:17 when the airbags deploy and shove the computer screen into the cop's arm.
Bet that hurt.
Light bulb out of shop light.  Been in there approximately 32 years and survived many a fall. Finally bIt the dust in a combination fall/slash kick trying to grab it. RIP
could only find a China replacement.
Edited by bilzbobaggins
bad speler
  • Like 7
On 5/14/2021 at 10:23 AM, Dav said:
made for 6 cyl Z’s but not 4 cyl 510’s?
On 5/14/2021 at 12:40 PM, datsunfreak said:
You're worried the snake oil doesn't work for your application?   😁
Probably afraid that one and a half times more might be too much.
Edited by Racer X 69
Not really, it’s just silly that they might have different “formula” for a four, five, eight, ten or twelve cylinder.  I was looking for ZDDP (zinc) additive.
maybe smaller or larger cans for more or less cylinders ?????? just a guess
Nah - I bet it is difrent - they wouldn’t put it on the can otherwise.
CIT (Cash in transit) heist in South Africa from a few weeks ago. This video shows much more than the previous ones. I don't think these guys hauled the money, they were a follower?
Edited by ratpatrol66
