Draker Posted May 11, 2016 Report Share Posted May 11, 2016 Just got a shipping confirmation email from Speedhut. My gauges will be here Friday!!!!!!!!!!!!!!!!!!!! :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: You'll enjoy them. Their support is great too. Link to comment
datsunfreak Posted May 14, 2016 Author Report Share Posted May 14, 2016 The eagle has landed. B) 6 Link to comment
Rhapakatui Posted May 14, 2016 Report Share Posted May 14, 2016 Pertty. Is that a GPS speedo, or does it work with the Datsun cable? Link to comment
datsunfreak Posted May 14, 2016 Author Report Share Posted May 14, 2016 Pertty. Is that a GPS speedo, or does it work with the Datsun cable? GPS. Figured I'd shoot the wad and go GPS since I'm planning to play around with tires sizes and gear ratios as we go along. And this saves me from also being forced to play around with different speedo pinions in the transmission every time I make a change. And now I can remove the cable completely and run the harness for these gauges through the firewall hole the cable is using right now. :thumbup: 3 Link to comment
hobospyder Posted May 14, 2016 Report Share Posted May 14, 2016 those are pretty. and now i'm wanting to do some research on gps speedos, i usually just use my phone to check how far off the speedo in vehicle is and go off of that Link to comment
datsunfreak Posted May 14, 2016 Author Report Share Posted May 14, 2016 and now i'm wanting to do some research on gps speedos FWIW, this one has the best reviews I've found. Hard to find anyone with something negative to say about Speedhut stuff. 2 Link to comment
Duncan Posted May 14, 2016 Report Share Posted May 14, 2016 Cant wait to see a photo of those installed! :thumbup: Link to comment
datsunfreak Posted May 14, 2016 Author Report Share Posted May 14, 2016 Cant wait to see a photo of those installed! :thumbup: Gonna modify the gauge surround to fit these tomorrow, then some paint and install. We'll see how far I get... ^_^ 1 Link to comment
datsunfreak Posted May 14, 2016 Author Report Share Posted May 14, 2016 Got one out of the box and gave it a test fit... Size looks good, but... ...it won't get in the hole... ^_^ Time to break out the dremel and get to cutting... :thumbup: First hole cut down to size, and the tach fitted up... Yes, you have to cut out a lot of material... ^_^ All three cut to size... All three installed... Not loving the silver gauge face rings behind the silver gauge rings, so decided to paint it all black. Last minute decided to keep the heater control as is... After some paint... Gonna give it a week to dry reeeeally well, then install the gauges in the dash next week... B) 7 Link to comment
datsunfreak Posted May 21, 2016 Author Report Share Posted May 21, 2016 Got the gauges screwed back in for good this time... Looking through the instructions for the speedo and realized these came with something I didn't even know they had, a dimmer switch! You can actually use it to dim up to 8 gauges at once! :rofl: So, where to put the switch... Took out the plug in the hole under the speedo for the trip odometer knob, drill it out about 1mm bigger, then installed the rheostat for the dimmer in that hole (it's the dime sized silver thing between the gauges)... I like this... B) Drilled the upper right hole (headlights maybe?) out to a larger size and installed a horn button there, and put in the cigarette lighter as a way to hold in in there for now... I want to try and find some new wiper and headlight switches for the bottom two holes, and a new cigarette lighter, then that should be all we need to finish up in here... Yes, I know I don't have wipers... :rofl: It will either just be a dummy switch for looks, or we will hack it to control something else... B) 5 Link to comment
dimlight65 Posted May 21, 2016 Report Share Posted May 21, 2016 ... or we will hack it to control something else... B) Maybe one of those brake solenoid "Roll Control" thingies for the front brake circuit so you can do awesome burnouts? 1 Link to comment
]2eDeYe Posted May 21, 2016 Report Share Posted May 21, 2016 That dash is so nice. :cool: 1 Link to comment
zhent Posted May 23, 2016 Report Share Posted May 23, 2016 It's looking good John! Yes, I know I don't have wipers... :rofl: It will either just be a dummy switch for looks, or we will hack it to control something else... B) Planning on registering it as an antique to get around the wiper requirement in the Texas inspection? Link to comment
datsunfreak Posted May 24, 2016 Author Report Share Posted May 24, 2016 Planning on registering it as an antique to get around the wiper requirement in the Texas inspection? Indeed. None of them are daily drivers, so only antique tags for me. :thumbup: And my inspection guy told me I only need functioning wipers if I have wipers. If they're aren't there at all, they don't need to work. :rofl: 3 Link to comment
Duncan Posted May 24, 2016 Report Share Posted May 24, 2016 THAT sounds like that would be an exact wording in a California law book :) I only need functioning wipers if I have wipers. If they're aren't there at all, they don't need to work. :rofl: 1 Link to comment
DaBlist Posted May 24, 2016 Report Share Posted May 24, 2016 THAT sounds like that would be an exact wording in a California law book :) Some states require wipers but have no wording requiring a windshield 1 Link to comment
njoz1200ute Posted May 24, 2016 Report Share Posted May 24, 2016 Haha that's in case you drive through mud, you can wipe your face clean. 1 Link to comment
datsunfreak Posted May 25, 2016 Author Report Share Posted May 25, 2016 Some states require wipers but have no wording requiring a windshield This is one of those states. :rofl: 1 Link to comment
DaBlist Posted May 25, 2016 Report Share Posted May 25, 2016 This is one of those states. :rofl: Was told that allows for old Jeeps and FJ's etc. with fold down windshields if you can believe States would plan for that Link to comment
KoHeartsGPA Posted May 25, 2016 Report Share Posted May 25, 2016 Wow that's awesome dash! Link to comment
]2eDeYe Posted May 25, 2016 Report Share Posted May 25, 2016 Some states require wipers but have no wording requiring a windshield This is one of those states. :rofl: Washington is that way too. :lol: 1 Link to comment
dimlight65 Posted May 26, 2016 Report Share Posted May 26, 2016 I used to run Brookland Screens on the Lotus. The full windshield cuts down the top speed a little but it sure does make the thing more pleasant to drive. 1 Link to comment
datsunfreak Posted June 12, 2016 Author Report Share Posted June 12, 2016 Few things knocked off the list today... Drained about half the coolant out so I could remove the Auto Meter water temp sender and install the Speedhut sender. Still had water shoot out the head when I removed the sender. :rofl: Got it in, and routed the harness up and around the brake lines so as to be a bit less visible... Pulled out the Auto Meter oil sender and replaced it with the Speedhut sender, and also routed the harness for it up under the stock harness to hide it a bit... While I was under the car today, I noticed something else... We had previously noticed (and I mentioned here) that the car needed more caster since the tires rub the footwells when turning. Made a mental note to fix that some day before driving it, so today was that day. :thumbup: Pulled out the TC rods so I could take them to a machine shop and see about having the shoulder machined down to dial in more caster. Turns out the previous owner had already done that. But for some reason he had installed a spacer on the TC rod to make it have less caster instead. I'm thinking he may have done that to keep the tires from clipping the front fenders (this was pre-flares). So, we popped out that spacer, reassembled it, and it was nowhere near the footwell. At least an inch gap now. It was actually juuuust rubbing the flare on the front. :rofl: Since removing a 1/2" spacer moved the wheel almost 1" further forward, I took it back apart and put in two washers where the spacer was to move the TC rod back 1/8". Now that was enough to give me around 1/4" clearance between the tire and flare at the front and a little over 1/2" space between the tire and footwell. :thumbup: 6 Link to comment
datsunfreak Posted June 16, 2016 Author Report Share Posted June 16, 2016 BProjects "hako" front spoiler showed up today... :thumbup: 8 Link to comment
