What I'm working with!
uberkevin
  • Replies 3.2k
I think if you would have simply just texted him a "thank you" for stopping it would have been more than enough... Pulling over on the freeway that is moving at 70+ is a pretty dangerous situation at best and the said person being "pulled over for" ,,, not thanking others for doing so is what he was bent about................   I have teenagers,,,,,,,,,,, i didn't expect it .
You text ME a thankyou i will punch you in the balls.
Dick lips.
  • Like 4
I did thank him. When he was on his phone either texting or something, idk. He said he was going home I said I didn't wanna back track.. said thanks again! Then walked back to my truck.
So what he thinks I didn't do I Infact did two time.
Should have drove up to you an said what's up tho! Lol.
Got a auto ECU on the way..
Along with 2 sets of injectors and another 2 intakes one with a head.. not that I really need more shit but I'll take it for 50 bucks..
Looking for another Maf too just to have another.
As far as when they'd stopped on the freeway I was done with what I was doing and was about to get back on the road, then they pulled up and I waved them to keep going.. got off at the next exit and that's when we stopped again and I told him sup..
Sorry I didn't say something the first time Ted.
As for the truck!!
At times it's better then a L but even Lexi said it's not as fast..
Doesn't pull her back like it used to..
With the vacuum problem and the driveline problem I can see why she thinks that. But at times like I said is fast!! And I know it's hiding more in there somewhere...
Hoping the auto ecu is going to help a few things at the top end..
Couldn't get past 75.. and even when I did get there I couldn't stay there at all..
Wouldn't run right up there.
Also even more gear oil was coming out at higher speeds.
If it won't go past 75 then you definitely have something going on.
Have you figured out where the gear oil is coming from? If you overfill it will go out the path of least resistance. Gear oil expands a lot more than you think once you warm it up and aerate (sp?) it.
Think I hit 80 once.
Not at home now so I can't really do anything.
But it's for sure coming from the tranny tail.
So pinion angle or its to short.. or they forgot to balance it.
Like I said once I get home I'll mount the gopro a few spots and go for a normal'ol drive. So everyone can see/hear what the hell is going on.
Seems to be.
No drive right tonight tho... no gear oil. Well couldn't feel any.. :/
Idle is alot better, better response when I give it gas. So we'll see. Sounds alot better.
Well see tomorrow tho when I give her a drive..
Uploading a short video.
