flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 How did 95lbs of Kevin break anything that isn't ramen noodles? Bwahahahaha. You should know. Quote Link to comment
uberkevin Posted May 24, 2016 Author Report Share Posted May 24, 2016 I realize now why the video is taking so long, it's in 1080p... I'm not worried about the pathfinder shit just fucken happens. It was probably my fault some how, makes me be more on my toes. Drove the pathfinder home nicely today.. Stupid video is hella vibranty.. but there's some part where you can hear me miss gears and some good pulls. Needs refined a litte more, changing plugs did good.. something up tho 4th gear did a couple weird things. Like it wanted me to get it more gas. So next I'll change the shitty plugs for the injectors. Video so I swear Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 Vibranty? Changes the whole context of your video. Lol. 2 Quote Link to comment
q-tip Posted May 24, 2016 Report Share Posted May 24, 2016 Bwahahahaha. You should know. I probably weigh almost twice what Kevin does.... Quote Link to comment
KoHeartsGPA Posted May 24, 2016 Report Share Posted May 24, 2016 Missed gears and needs refining?...maybe driver needs refining? 1 Quote Link to comment
uberkevin Posted May 24, 2016 Author Report Share Posted May 24, 2016 Not use to the super short shift. Clutch is nice. Maybe I'd like a different rear end gearing.. not sure yet. Off to an alignment shop tomorrow I think 1 Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 1980 720 has the 3.9 gear. 79 620 is 4.1. Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 *Deleted because my information was wrong. Quote Link to comment
uberkevin Posted May 24, 2016 Author Report Share Posted May 24, 2016 What should me be? Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 What the fuck is that rattle? Quote Link to comment
Phixius Posted May 24, 2016 Report Share Posted May 24, 2016 stock 240sx final is 4.083. stock 521 is 4.375w/ L earlier is 4.889. Any 2wd 720, HB with 4cyl will have a h190, 3.545, 3.7, 3.889, 4.11... tag will read, HF35, HF37, HF38, HF41, Edit: Pick N Pull is going to have a 50% off sale starting tomorrow May 25-26th for toolkit members. and for genral public May 27th -30th. 1 Quote Link to comment
Rhino13 Posted May 24, 2016 Report Share Posted May 24, 2016 What the fuck is that rattle? I'd assume it's the exhaust against the torsion and frame like he mentioned. Didn't 521's have 4.37 gears? Or maybe even higher on some? I know Al has something like 4.8's out of some Datsun. Quote Link to comment
uberkevin Posted May 24, 2016 Author Report Share Posted May 24, 2016 Exhaust touching frame and torsion rod.. If I were to get one I'd have to look into what o should get. And if I should by a pathfinder one! Oh and I would need someone to get if for me, being I have no time this week. Quote Link to comment
denmarkboy Posted May 24, 2016 Report Share Posted May 24, 2016 I'd assume it's the exhaust against the torsion and frame like he mentioned. Didn't 521's have 4.37 gears? Or maybe even higher on some? I know Al has something like 4.8's out of some Datsun. I have a set of 485 , I usually get my diff's from 720's. 353 are pretty common . The last set I got for the lil hooker were 333's . 1 Quote Link to comment
uberkevin Posted May 24, 2016 Author Report Share Posted May 24, 2016 But what should I get! I have no clue. Quote Link to comment
denmarkboy Posted May 24, 2016 Report Share Posted May 24, 2016 But what should I get! I have no clue. Considering the power plant / trans I would personally go 373 or 355/53. The 355 will give you a great mpg but you'll probably never see 5th unless your on freeway. Just depends on the performance you looking for. 1 Quote Link to comment
uberkevin Posted May 24, 2016 Author Report Share Posted May 24, 2016 Thanks Al. Now I've just gotta drive more and see what I want. 1 Quote Link to comment
denmarkboy Posted May 24, 2016 Report Share Posted May 24, 2016 Shake down run #3 looked pretty good . Congratulations dude ! 1 Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 If do 3.7 or 3.8. Still leaves some pep left for the motor an saves some gas mileage for trips. 2 Quote Link to comment
Rhino13 Posted May 24, 2016 Report Share Posted May 24, 2016 Need to find out what you have in there so you know "what you're working with"... Zing! Haha 4 Quote Link to comment
q-tip Posted May 24, 2016 Report Share Posted May 24, 2016 I agree with al, 3.50-3.70 would be a good all around hearing g for it. The ka has enough grunt to get it going without it being sluggish 1 Quote Link to comment
flatcat19 Posted May 24, 2016 Report Share Posted May 24, 2016 I think 3.7 would be just about a perfect mixture of both. 3.9 if you still want to be sporty at the sacrifice of top end speed and gas mileage. 1 Quote Link to comment
uberkevin Posted May 24, 2016 Author Report Share Posted May 24, 2016 Some tranny noise that goes away when I push in the clutch.. maybe it's just exhaust shifting around. I'm fixing the exhaust a bit more to make it better and more the 2 inchs away from the ground.. I'll have dual exhaust this way. Lol. 2 Quote Link to comment
