What I'm working with!
uberkevin
  • Replies 3.3k
The hood needs to be welded down to the inner hood frame pretty badly because of it
the hood walbals pretty bad.
But yeah it still looks great I think she's amazing!
The bed also needs some big help with the welder too look. This picture was taken right after i put the bumpers on but didn't get them tight or even yet. 20120820_162951.jpg
Right after the picture I washed it hahaha but I had to leave before
I could take more lol. Ill take more she does look way better!
Oh she's mine and she's only going to get better :)
  • 4 months later...
My beast is shaking pretty bad accelerating in 3rd and then stops when i get up to speed.
Also some times going out of second it will shake stop when i change to 3rd but then start again.. Not every time, seems when i turn.
Whats up with it? Seems the trans yeah?
Bolts are tight.
The hood needs to be welded down to the frame pretty badly because of it
if your talking about the hood frame work, dont.
dont weld it or youl just warp the shit out of the hood.
they make glues for that, just like it was glued from the factory.
Thank you both! shes a working progress.
all dattos are a work in progress, the day we stop fixing them up is the day we sell or die
Bolts are tight.
there's a third gear sensor on the trans that activates the second set of points for some emmisions crap. Unplug it.
Hmmm, mine had that third gear problem and I just started unplugging things untill it stopped... found out later it was the third gear switch... another thing was when I lowered my truck with 4in blocks I had a weird shake/vibration... found out later when swapping my driveline, my slip joint was rusted shut and didn't slide anymore... maybe this?..
  • 1 month later...
So i've been doing a little work on MasterChief not as much as id like but still
Here's a dashboard if been working on for a week or so, now that i don't have a job
I don't mind sanding a shit ton. The filler im using is just a padded dash filler i got off line.
Under it as you can see is my tailgate that i'm also sanding down. I want to get all the ugly little dings in it out and get it looking great again.
Also got a powder coating gun from eastwood.com. I was pretty stoked to finally power coat something so I picked
and old heater cover i had. Its baking as i type so you'll see how the first coat is. here a tease... DSC_0049_zps95619e6f.jpg
Oh I took off my door panels to make new ones, I haven't got to far on this just cut one of
the new panels out of some thin plywood i got. I'm a really picky person about little shit
so I know that I wont put something in my truck I don't like or isn't to my satisfaction.
Like the dash board or these panels.
here ya go.
DSC_0050_zpse5792830.jpgif your wondering what the thing in the back ground is? well its a home for this.. DSC_0039_zps6a6cc053.jpg
As far as the dashboard I'm about 85% done. I need to get some leather or something less expensive,
Any ideas where and what to use to cover the dash.
hey on the heater piece.. thats a reaction from baking the paint under the powder when ever possible u should strip to bare metal ....the only thing powder goes over is powder or bare metal...i know your employement situtaion sdosnt allow it but u should get a 520 metal dash top then powdercoat it...but i agree i like the suede.....another cool one but prolly exensive would be like a textured leather ...
Suede isn't to much I think I'll head over to Joann's fabrics
And get some there. It was something like 7 bucks a yard.
I need little more the 4 feet. A yard is 3 something right?
And the heater peace i sanded down to metal
But on the side that looks ugly was some surface rust
I sanded it down a ton but got tired of doing it and really wanted
To powder coat. My dumb fault. Lol
I think I'm going to continue refurbishiny more 521 dashes
I know where at least two more are its not to hard. Once I get this suede
Ill finish my dash and get some oics. And I do in fact
Know where a good 520 is sitting in a junkyard dash is in amazing shape.
I don't have an oven big enough to bake it.
Dude wanted 90 big ones for the whole dash.
