polski ogorki Posted April 14, 2013 Report Share Posted April 14, 2013 :confused: :D http://4wheeldrive.about.com/library/uc/uccamundson.htm That's awesome! Quote Link to comment
Master-O-Turbonics Posted April 14, 2013 Report Share Posted April 14, 2013 lol, maybe something was wrong with my 81 frame, no way it would be able to handle that abuse! That pic is pretty epic! Quote Link to comment
]2eDeYe Posted April 22, 2013 Author Report Share Posted April 22, 2013 Got the rest of the rocker protection tube supports in. Set them to the body seam and then bent it up for extra clearance. Passenger side. Drivers side. Bent body seam. I also got the engine bay cross brace fabbed up, still have to tack it together. Connectors Drivers side tube Passenger side body cut for clearance. Cross brace About where it will sit. Quote Link to comment
bonvo Posted April 22, 2013 Report Share Posted April 22, 2013 how are you gonna make that bar removeable? Quote Link to comment
Farmer Joe Posted April 22, 2013 Report Share Posted April 22, 2013 how do those connectors come apart? i dont see it sliding apart like that... both those breakdown points would have to be parallel with eachother to slide out like that... Quote Link to comment
]2eDeYe Posted April 22, 2013 Author Report Share Posted April 22, 2013 The tube is in one plane. It will come forward when unbolted. Quote Link to comment
jesusno2 Posted April 22, 2013 Report Share Posted April 22, 2013 damn i need those hardbody PS parts you scored i'm in the middle of swapping my 720 to a 12v ka. Quote Link to comment
]2eDeYe Posted April 22, 2013 Author Report Share Posted April 22, 2013 I lucked out at the pick n pull. Still need a tensioner pulley and bolt. Quote Link to comment
heretic Posted April 22, 2013 Report Share Posted April 22, 2013 this thread makes me want to lift my KC.!!! bitch'n fab work.! Quote Link to comment
Eagle_Adam Posted April 22, 2013 Report Share Posted April 22, 2013 seriousness amounts of awesomeness in this thread!!!! I LOVE IT!!! Quote Link to comment
]2eDeYe Posted May 13, 2013 Author Report Share Posted May 13, 2013 Got most of the fab out of the way as far as the frame goes. Dug in to the timing chain this weekend. Thanks to Shonuff, everything went pretty quick. I still have to put it back together, but I have everything ready to go so the motor should be back together tonight. Pics... BTW there was a bit of a rattle on startup, I think we found the problem :lol: ..and for those that were asking about the engine bay crossmember. Easily removed with an allen wrench and leaves plenty of room to work. ...and what happens when your buddy helps out. Quote Link to comment
Boxcar Posted May 13, 2013 Report Share Posted May 13, 2013 Nice Build. I'll be fallowing you're progress. Am in the middle of basically the same build as we speak. Will be going with a full exo. and an 8274 winch. on 35s 2 Quote Link to comment
jrock4224 Posted May 14, 2013 Report Share Posted May 14, 2013 hey red where u at ? Quote Link to comment
]2eDeYe Posted May 14, 2013 Author Report Share Posted May 14, 2013 At home in the garage alternating between a timing chain and cleaning the house (my girl is back from vacation tomorrow) :) Quote Link to comment
Shonuff Posted May 14, 2013 Report Share Posted May 14, 2013 ...whatever, as long as you dont draw a penis ok :fu: Quote Link to comment
]2eDeYe Posted May 14, 2013 Author Report Share Posted May 14, 2013 :fu: :rofl: Quote Link to comment
]2eDeYe Posted May 17, 2013 Author Report Share Posted May 17, 2013 Motor is pretty much back together. Need to find a tensioner pulley for the power steering. Little bit of fab left and assembly of the axle... Quote Link to comment
heretic Posted May 17, 2013 Report Share Posted May 17, 2013 I'm digging the powder coat.!! :thumbup: Quote Link to comment
Eagle_Adam Posted May 17, 2013 Report Share Posted May 17, 2013 lookn good man! is this coming to canby? Quote Link to comment
jrock4224 Posted May 17, 2013 Report Share Posted May 17, 2013 love the bg-01 beige.....we did hans parts for his 510 all that color ..... he couldn't picture it so before we bolted them on, he made me change it ... now its gold ... i liked the beige... ....will look awesome done..... Quote Link to comment
]2eDeYe Posted May 17, 2013 Author Report Share Posted May 17, 2013 Thanks guys lookn good man! is this coming to canby? I need it driveable for memorial weekend. So it's a mad dash to Wed. Totally bringing it to Canby :D love the bg-01 beige.....we did hans parts for his 510 all that color ..... he couldn't picture it so before we bolted them on, he made me change it ... now its gold ... i liked the beige... ....will look awesome done..... It looks good with the green for sure. Quote Link to comment
]2eDeYe Posted May 20, 2013 Author Report Share Posted May 20, 2013 Finished up the rear mounts and splashed some paint on the frame. Got the axle put together, one of my ubolts is to short so I need to get that remade. Picked up an early 720 steering column, should bolt right up for the most part. Still need to do the radiator, tie rod and drag link, brake lines and fluids. Should be done just in time to load it up on Thursday and go camping for a week. :thumbup: Quote Link to comment
goes2fast Posted May 21, 2013 Report Share Posted May 21, 2013 There will be pics of the camping trip, right? Quote Link to comment
]2eDeYe Posted May 21, 2013 Author Report Share Posted May 21, 2013 Of course :) Got my radiator modified. Step one: Destroy a perfectly good radiator to figure out how it is put together :lol: Step two: Pick up another radiator at pick n pull and be more carefuller this time. Step three: Modify the new outlet to match the one that was cut out. Step four: Solder shit Step five: Enjoy new clearance. Tonight will be steering. Then it's time to make sure all the bolts are tight and everything has fluids. Quote Link to comment
q-tip Posted May 21, 2013 Report Share Posted May 21, 2013 Can't wait to see this finished up and on a trail! Quote Link to comment
