Pacific coast Datsun Posted April 2, 2008 Author Report Share Posted April 2, 2008 Ok been awhile since i touched the 620 so i decided to install my SU's & see how they perform. I had to make the triangle block off plates 1st... & i inserted 2 bolts to plug the holes on the intake, i know one of them will be for the brake booster... heres the size of the bore.... the heat shield is hitting the ex. manifold so I'll have to bend it up a bit... & the test fit........ Im wondering now what to do with the crankcase vent tube. It used to connect to the bottom of the L 16 intake. Still have to run the cables for the speedo & choke [thanks Bleach]. Oh & im also wondering where the vac. advance will attach. I may have to modify one of the block off plates for that but id like to make sure 1st. Quote Link to comment
datsun dreamer Posted April 2, 2008 Report Share Posted April 2, 2008 Man they look Thirsty:D:D! Mark, What are you gonna do with your weber? Quote Link to comment
Steroid Posted April 2, 2008 Report Share Posted April 2, 2008 Those and a 5 speed in a convertable truck?!?!?!??? Your hair is going to blow off and You are going to look like Me on top!!!!!!! Hi Jason!! Quote Link to comment
Pacific coast Datsun Posted April 2, 2008 Author Report Share Posted April 2, 2008 Jason- the Weber will sit until i make sure they run right. Then ill decide to keep for a backup or install on another vehicle or sell. Mike- not much hair left to blow off :D If these work out i can make it to your place in 3 1/2 hours ! Update: success i just fired her up, on the 3rd try & with the chokes open she fired !!! Sounds damm good too! Have to adjust the idle a bit & hook up the choke cable but she'll run on her own. Pix to come in a bit & BTW im going to re-do the throttle linkage later,this was a mock up/test fit. Quote Link to comment
Pacific coast Datsun Posted April 2, 2008 Author Report Share Posted April 2, 2008 Ok pics....... the fuel line & speedo cable mount will be redone before i drive it... & the choke cable, i used a 620 hood release cable :D Oh & i found out where the vac. advance goes...under the carb. next to the radiator.... Also i shot a video that ill post later. Quote Link to comment
]2eDeYe Posted April 2, 2008 Report Share Posted April 2, 2008 Nice. Do you every get confused and think the reflection is what your working on? :D 1 Quote Link to comment
Pacific coast Datsun Posted April 3, 2008 Author Report Share Posted April 3, 2008 Yeah kinda...:D Ok heres the video.... 1 Quote Link to comment
Steroid Posted April 3, 2008 Report Share Posted April 3, 2008 I just watched the video.............................. Your driver's door creaks. Oh, and that's not JUNK in Your bed, it's COLLECTABLES!!! SAVE EVERYTHING! Cool, Mark, very cool!!!! Congratulations! We both fired up "twins" today!! You inspired Me!!! 1 Quote Link to comment
Bleach Posted April 3, 2008 Report Share Posted April 3, 2008 sounds good. You work fast now. Its been so long since I worked on a carb... 1 Quote Link to comment
]2eDeYe Posted April 3, 2008 Report Share Posted April 3, 2008 sounds good. You work fast now. Its been so long since I worked on a CAR... Fixed it for ya :D 1 Quote Link to comment
dat620 Posted April 3, 2008 Report Share Posted April 3, 2008 congrats on the garage bro..like mike said it's all collectables, bet it feels good to be able to leave her tore apart if needed , and not worry about weather, or if something might get stolen..alot differant than working outside..:D 1 Quote Link to comment
Farmer Posted April 3, 2008 Report Share Posted April 3, 2008 When you finally get your throttle cable setup perfect, get some pics of it so I can get some ideas to do mine. Thanks Larry 1 Quote Link to comment
fryanbacon Posted April 3, 2008 Report Share Posted April 3, 2008 dood. I love your truck. I'm way into all the unique custom stuff. 1 Quote Link to comment
Farmer Joe Posted April 3, 2008 Report Share Posted April 3, 2008 damn mark, that thing sounds good!! lopes like a mofo!! 1 Quote Link to comment
Pacific coast Datsun Posted April 4, 2008 Author Report Share Posted April 4, 2008 Tom: ya like he says "save everything" but i had to toss alot of crapwhen i moved :D & ya love the garage. Farmer: heres a pic that'll help us both on the cable setup...not my truck btw... Fryanbacon: thanks, i kinda went beyond the point of no return a long time ago...:cool: Niel: ya i love it at idle. When i bought the engine it came with a "mild cam" 1 Quote Link to comment
Farmer Posted April 4, 2008 Report Share Posted April 4, 2008 thanks for the Picture. Larry 1 Quote Link to comment
bonvo Posted April 12, 2008 Report Share Posted April 12, 2008 that thing sounds sick what are you running for a muffler i thought i heard you say flowmaster but what model? what size pipe? 1 Quote Link to comment
Pacific coast Datsun Posted April 12, 2008 Author Report Share Posted April 12, 2008 that thing sounds sick what are you running for a muffler i thought i heard you say flowmaster but what model? what size pipe? Flowmater 2 chamber 40 series muffler & the pipe is all new 1 3/4 tucked above the trans. crossmember for clearence. 1 Quote Link to comment
Farmer Posted April 13, 2008 Report Share Posted April 13, 2008 Flowmater 2 chamber 40 series muffler & the pipe is all new 1 3/4 tucked above the trans. crossmember for clearence. Got pics of that?? Larry 1 Quote Link to comment
Pacific coast Datsun Posted April 14, 2008 Author Report Share Posted April 14, 2008 Ask & you shall recieve...of course you guys know i take my digital everywhere i go :D What my exhaust guy did was slightly crush the pipe where it goes over the crossmember so it wasnt touching the floor of the truck. I will say this that the floor get hotter than normal because it is so close. This is also a good view of the torsion bar mounts & how they sit after they have been reindex'd. After i lowered it the 1st time they hung down below the frame quite a bit. 1 Quote Link to comment
mklotz70 Posted April 14, 2008 Report Share Posted April 14, 2008 Get some cat converter heat shield from under a newer car and rivet it up under there to keep the heat down :) 1 Quote Link to comment
Fineline Posted April 14, 2008 Report Share Posted April 14, 2008 Sounds great. Keep the idle low...it sounds like it has a huge cam in it!:lol: 1 Quote Link to comment
fiveNdime Posted April 14, 2008 Report Share Posted April 14, 2008 Thats the same thing my exhaust guy did. 1 Quote Link to comment
datrod Posted April 15, 2008 Report Share Posted April 15, 2008 Mark, I had to watch that video a couple o times. (BADASS):cool: 1 Quote Link to comment
Steroid Posted December 8, 2010 Report Share Posted December 8, 2010 HOORAY ! ! ! 1 Quote Link to comment
