My Datsun trucks...
bare metal or primer works for me.. chrome is too fancy.. not very ratsun.. i may paint mine red.. or primer black.. mind sending a few good pics so i get an idea of what i need an where to bolt it.. or just post them that would work also.. and i might just have the cash next week since im workin a lil more this week, anyways thanks again man!
ooh and ya.. i'd rather have something on my truck that a fellow datsun fan made then some store made crap.. also i conisder u a buddy so i can say "my buddy made it for me" :P
  • Replies 305
Ill prob. start another thread concerning the sway bar as soon as i get them started. After i removed the bump stops & put my 17 inch rims on needless to say it lowered the truck the rest of the way for a total 6 inch drop approx. & i noticed the pinion angle was off by quite a bit. So...what i did was cut off 1 inch off of the splined part of the rear shaft & put some angled shims under the blocks & it fixed the problem. I was also getting a loud noise @60 mph before & thats gone too. Jeez all i wanted was a simple drop...:D
More baby steps taken today... I installed the mirrors I bought from Ryan today up on the fenders. I want to go for a semi stock /Japanese market look if that makes sense :D
view from inside...look a old 620 ;)
and the interior...still need to rip up the carpet padding then wire wheel & undercoat the floor, plus make some stock looking door panels.
Mario the door panels will be awhile, i want to try & find the same style of viynl as stock if i can but ill keep you posted & wont mind making 2 sets. I got down today...scraped off the house carpet padding, wire wheeled the entire floor, undercoated the flloor & made a new filler plate for the shifter to keep the hot air out. Its not pretty but works plus it'll be under carpet one day so who cares. Also took a small paintbrush & vaccumed/brushed all under the dash & got tons of crap-dust cleaned up. &...installed the pedal rubbers scavenged off my 69! The shift boot is out of my old 68 L 520 BTW & oh yeah i removed the head rests on the Z seats & they lean back a bit more now...my back loves it :D
they just barely go under the lip on the back of the cab but recline 1 more inch now...& notice the ripped seat belt! Still have to replace them...
Mark, I think I like those mirrors...............having said that tho...(uh oh here comes Ron with the caveat!!) I would think that they would be a bit difficult to use. Those of us that are vision challenged (need glasses or contacts) I kinda think it would be hard to use them...oh well though I do like the look...said that already huh....
makibaka- thanks,,the pics hide all the dents..:D
OL YELLER- Ive driven 2 days now with the "new" mirrors & they take a bit getting used to. My habit is to look where they used to be & whammo..no mirror ;)
datsun dreamer- The mud flaps on the 320 are off a 720, & the set on the 620 are factory. I got them at the junkyard for $5. Every time I go i look for them & if i find em Ill buy em so if you need a set let me know. And yeah the plaque represents our truck club..only a few of us left but weve been around since 1981.
Mark, if you do have an extra set of mudflaps i'll buy a set just name your $$$, the truck club sounds pretty cool i mentioned it on another forum before but no one sounded realy interested you know for barbeques and get togethers etc... thanks for the reply!!!
DD ill be going back to the yard in a few days..i found a set of mud flaps I hid that i need to retrieve :D Now onto how its running now. The last few times I drove it at around 60-65 the motor would start to sputter & miss really bad..id slow down & it would run better then id speed up again & it would run like crap again. When it would sputter the ignition light flickers on & off..i replaced the alternator nut that had fallen off & i thought that would fix the problem but nope..stil running rough. Now, i noticed that the dist. will wiggle back & forth a bit so im guessing it's making the points spark/not spark when theyre supposed to. At this point im leaning towards swapping over to the EI w/ HEI module like my 620. In the meantime is there a way to tighten the dist?
Do you mean the shaft? If so, get a new dizzy. The shaft is probably worn out, that the reason I went EI ;)
Your ignition light comes on? That's weird...maybe the condesor is shorting. Is there a condensor?
