d.p Posted February 26, 2023 Author Report Share Posted February 26, 2023 Nice. I will call IMI tomorrow and see what is doing. Quote Link to comment
d.p Posted February 26, 2023 Author Report Share Posted February 26, 2023 Alright so went to start the truck today after being on the tender for like 4 days or so. Truck would not start…it would try to turn over but very slowly. My voltmeter read like 13.x with the truck off and when starting it would drop down to 7.x and the shut off because it wasn’t getting enough power. I take the stupid tender off and have to use my battery charger and it’s ‘engine start’ mode to get the truck going. But once I do that it starts and dives fine. So it’s almost like the battery on the tender is draining it? I guess I’ll just leave it off the tender for a few days and see what it does. Before with the standard acid battery it never did this. It would always start even after sitting for awhile. Quote Link to comment
datzenmike Posted February 26, 2023 Report Share Posted February 26, 2023 On 2/22/2023 at 12:44 PM, datzenmike said: Use booster cables to a known good charged battery to eliminate your 'battery' as the cause of the slow turning of the starter. Your battery may be the problem and a new starter won't fix this. How cold is it where you are? Oil may be too thick so install a block heater. Quote Link to comment
d.p Posted February 26, 2023 Author Report Share Posted February 26, 2023 Today? 50 give or take. Quote Link to comment
datzenmike Posted February 26, 2023 Report Share Posted February 26, 2023 Not cold enough. My brand new '76 B-210 would turn just 3 times and stop. Switched to 10w and installed a block heater. Boost and see if better cranking or not. Quote Link to comment
thisismatt Posted February 26, 2023 Report Share Posted February 26, 2023 I'm not bothering with AGM anymore for under the hood. Not worth the extra cost. Quote Link to comment
banzai510(hainz) Posted February 26, 2023 Report Share Posted February 26, 2023 (edited) 3 hours ago, d.p said: My voltmeter read like 13.x with the truck off and when starting it would drop down to 7.x and the shut off because it wasn’t getting enough power. this number is a common reading. I think the COLD cranking amps on the battery is important. I went back to a lead acid battery myself. I had red Optimas and gave up on them after I left the lights on a few times they never recovered. be honest I think your starter is fine if you jumper with another car. I got my starter from here but I think it was sent from California straight to my house. IMI. Just note I never installed it as I have about 5 extra nissan boxed starters.. But TSI was cheaper in price than anywhere else. I figured more of these would be used here on Ratsun. But only Bigtanker seemed to use these. Its actualy a good price for this type of starter. I would get only 8months to 1.5 years on a daily driver (O rileys or Autozone starters) http://tsimportedautomotive.com/gearreductionstarters.html Edited February 26, 2023 by banzai510(hainz) 1 Quote Link to comment
d.p Posted February 27, 2023 Author Report Share Posted February 27, 2023 (edited) Thanks for that link but I don’t think my starter is the issue. I’ll reach out to them and see what their selling for just so I know. I paid a grip for AGM this battery but if this continues I’ll go back to a lead acid. I got no interest in having to hook up a battery starter everytime I want to drive it. Plus this AGM weighs a fuck ton. Edited February 27, 2023 by d.p Quote Link to comment
d.p Posted February 27, 2023 Author Report Share Posted February 27, 2023 5 hours ago, datzenmike said: Not cold enough. My brand new '76 B-210 would turn just 3 times and stop. Switched to 10w and installed a block heater. Boost and see if better cranking or not. Once I put a battery starter on it it will turn right over. Quote Link to comment
thisismatt Posted February 27, 2023 Report Share Posted February 27, 2023 My last AGM basically did the same thing. Was working fine, but as soon as the weather got cool it crapped the bed - only like 3 years old in the daily driver. If it's only going to last 3 years F it 1 Quote Link to comment
banzai510(hainz) Posted February 27, 2023 Report Share Posted February 27, 2023 make sure the batter cables ends are not cracked from over tightening Quote Link to comment
d.p Posted February 27, 2023 Author Report Share Posted February 27, 2023 Fucker did it again this morning, it wouldn't start at all until I put it on the batter charger/starter. I don't understand why it won't start on its own less than 24 hours after driving it a bunch? Quote Link to comment
ShutterMeShort Posted February 27, 2023 Report Share Posted February 27, 2023 (edited) 3 minutes ago, d.p said: Fucker did it again this morning, it wouldn't start at all until I put it on the batter charger/starter. I don't understand why it won't start on its own less than 24 hours after driving it a bunch? Battery is toast. Your voltage gauge says it all. Started at 12 volts and then it flashed 8.2 volts while cranking. Check for parasitic drains too. Battery quality has gone way south in the last few years. AGM's are great and all but your car can't quite charge it right so you can't expect the best life. Lead Aa Edited February 27, 2023 by ShutterMeShort 1 Quote Link to comment
d.p Posted February 27, 2023 Author Report Share Posted February 27, 2023 I shouldn't have anything draining it but who the fuck knows. I am going to try and warranty the battery and see where it goes, if nowhere I will just go back to a lead acid battery. Quote Link to comment
Stoffregen Motorsports Posted February 27, 2023 Report Share Posted February 27, 2023 AGM batteries don't like to sit. I know that from experience. I've had them go bad with regular use too. Odyssey wouldn't even warranty the last one that went bad. The fact that you've got a tender on it tells me that you're one of the unlucky ones who's battery just gave up the ghost for no reason at all. 1 Quote Link to comment
d.p Posted February 27, 2023 Author Report Share Posted February 27, 2023 Yeah don't know what the deal is with it. Put the battery on the charger for 45 minutes or so just now and it reads 12.xx with the truck off. When running its right around 14.2-14.3 so what does that tell me? That it can take a charge but will drain overnight? I guess I can disconnect it tonight and see if there is something draining it. Quote Link to comment
thisismatt Posted February 27, 2023 Report Share Posted February 27, 2023 It's the battery, Brian. Always has been. 2 Quote Link to comment
mainer311 Posted February 27, 2023 Report Share Posted February 27, 2023 (edited) 2 hours ago, d.p said: Yeah don't know what the deal is with it. Put the battery on the charger for 45 minutes or so just now and it reads 12.xx with the truck off. When running its right around 14.2-14.3 so what does that tell me? That it can take a charge but will drain overnight? I guess I can disconnect it tonight and see if there is something draining it. That only tells you that your alternator and VR are working correctly. The battery has a bad cell. It reads the correct voltage, but you see a huge voltage drop when it sees any kind of load. The battery is toast. You can charge it for a week, but it won't fix a bad cell. And the truck runs fine after it's started because the alternator takes over once it's spinning. Edited February 27, 2023 by mainer311 1 Quote Link to comment
banzai510(hainz) Posted February 27, 2023 Report Share Posted February 27, 2023 On your 2nd vid Once you got it started it seemed your cig volt meter was still low reading like 12 while running. then 13 for a sec before the vid stopped. does it go up close to 14volts with no load like lights and heater? if yes then your charging system is fine then put a load on there with heater and lights and say 1200rpm and see what the volts are 1 Quote Link to comment
d.p Posted February 27, 2023 Author Report Share Posted February 27, 2023 (edited) Yeah it will go to 14.2 or so and appears to charge fine and when driving around even with lights and shit it would only drop down to around 13.x or so. But I just had the battery tested which it failed..said it has 106CCA vs 765CCA its supposed to have. I submitted a warranty claim with Odyssey so will see where it goes. Fucking learned more about car batteries in the past couple days then I have my entire life. Lol Edited February 27, 2023 by d.p Quote Link to comment
Stoffregen Motorsports Posted February 28, 2023 Report Share Posted February 28, 2023 Good luck with Odyssey. I had a bad one out of the box, but I didn't open the box for six months and they said it was out of warranty. Even though I explained that it was just out of the box. Quote Link to comment
d.p Posted February 28, 2023 Author Report Share Posted February 28, 2023 They are sending me a new one, warranty claim was pretty painless. Only pain was having to lug that fucker to pep boys to have it tested. 1 Quote Link to comment
Stoffregen Motorsports Posted February 28, 2023 Report Share Posted February 28, 2023 Glad you got it warrantied. Quote Link to comment
datzenmike Posted February 28, 2023 Report Share Posted February 28, 2023 28 minutes ago, d.p said: They are sending me a new one, warranty claim was pretty painless. Only pain was having to lug that fucker to pep boys to have it tested. BUT.... Quote Link to comment
]2eDeYe Posted March 1, 2023 Report Share Posted March 1, 2023 All caught up 😄 I just switched to odyssey dangit! 1 Quote Link to comment
