denmarkboy Posted January 9, 2015 Author Report Share Posted January 9, 2015 Steve, LMAO.... ^^^^^^^^ I see what ya did there , but you do realize most of our youngsters will have no idea what your doin there, Lol , I just tried explaining to my 18 year old daughter , she had no idea what i was talking about . 3 Quote Link to comment
Loren O Posted January 9, 2015 Report Share Posted January 9, 2015 That's funny, I was also thinking most of our Ratsun-ers wouldn't be old enough to remember those commercials. 2 Quote Link to comment
]2eDeYe Posted January 9, 2015 Report Share Posted January 9, 2015 :rofl: Don't know why I find it so humorous, but I do :lol: 3 Quote Link to comment
Charlie69 Posted January 9, 2015 Report Share Posted January 9, 2015 :rofl: Don't know why I find it so humorous, but I do :lol: 2 Quote Link to comment
Charlie69 Posted January 9, 2015 Report Share Posted January 9, 2015 Those were great commercials! 1 Quote Link to comment
Charlie69 Posted January 9, 2015 Report Share Posted January 9, 2015 Does this look correct? Quote Link to comment
denmarkboy Posted January 10, 2015 Author Report Share Posted January 10, 2015 I've just been really busy , but i did snap a couple pictures 2 Quote Link to comment
denmarkboy Posted January 10, 2015 Author Report Share Posted January 10, 2015 Also got a picture of the wheels from jrock , Thanks to CT Specialties for donating the powder coating on the wheels & dash . 4 Quote Link to comment
Mattndew76 Posted January 10, 2015 Report Share Posted January 10, 2015 16-18th is open wrenching day? 2 Quote Link to comment
EastBay521 Posted January 10, 2015 Report Share Posted January 10, 2015 Yes yes!! 2 Quote Link to comment
Charlie69 Posted January 10, 2015 Report Share Posted January 10, 2015 jrock does nice work. 2 Quote Link to comment
Charlie69 Posted January 10, 2015 Report Share Posted January 10, 2015 Take the fuse block off carefully. Get a quart wide mouth Mason Jar, I think it will fit, put the fuse block in it and fill it up with white distilled vinegar and leave it over night. Take it out the next day and gently rinse it off. Blow it off with low pressure air to dry. Inspect and repeat process if still tarnished. 2 Quote Link to comment
DanielC Posted January 10, 2015 Report Share Posted January 10, 2015 I am not sure if the 4 always hot, 2 ignition hot, or the 3 always hot, 3 ignition hot is the correct fuse box for this truck. Just wire it up like the cover indicates, so it is not confusing to the next owner of the truck. I would suggest using an extra relay, with fused power directly from the battery, or starter lug, to supply power to the original 521 headlight relay. Pin 85 on new relay goes to ground. Pull the red with yellow stripe wire off the original headlight relay, plug it into PIn 86. Direct battery power goes to pin 30 of the extra relay. Pin 87 of new relay goes to the empty pin on the original headlight relay. This mod takes headlight current out of the original 521 fuse box. If you have seen a fair number of 521 fuse boxes, they probably have heat damage at the headlight fuse. without headlight current having to go into the cab, through the headlight switch,and back out of the cab again, the headlights get higher voltage, and are brighter. If the extra relay is located close the the original headlight relay, even when the fuse for the original headlights blow out, you can move the power wire from pin 30 back to the original headlight relay, where the red with yellow stripe wire was, and have headlights. 3 Quote Link to comment
mklotz70 Posted January 10, 2015 Report Share Posted January 10, 2015 That's almost a "must have" mod on the trucks. My wife's 521 kept melting the ends out of the fuses....wouldn't blow....just melt to the point where it wouldn't work. I did this relay mod to it and like Danial said....the headlights get noticeably brighter. Haven't had to replace a fuse since. Quote Link to comment
denmarkboy Posted January 10, 2015 Author Report Share Posted January 10, 2015 16-18th is open wrenching day? That it is ! But you might want to bring a couple of your own wrenches , :thumbup: , Looks like there is going to be crowd :thumbup: 2 Quote Link to comment
denmarkboy Posted January 10, 2015 Author Report Share Posted January 10, 2015 DONATED CANBY TRUCK PARTS : DONATED BY : FRONT BRAKES & KING PIN REBUILD........................................mklotz70 SEATS & DOOR CARDS .......................................................ratdat3 PARTS TRANSPORT & LABOR ................................................................. hobospyder TRANSPORTATION ................................................................................... eagle_adam DASH BOARD ..................................................................... ....................... uberkevin IGNITION SYSTEM & SWITCHES ............................................................. charlie69 TRANSPORTATION .................................................................................... fastdadd FRONT TURN LENSES .............................................................................. skyblue POWDER COATING .................................................................................... jrock4224 HOOD AND LABOR ..................................................................................... jester KNOBS & SHIFTER ..................................................................................... mattndew76 521 TRUCK .................................................................................................. datslocos & denmarkboy INFORMATION AND SUPPORT .................................................................. ratsun EVENT & RAFFLE ........................................................................................ datsuns northwest PAYPAL & TOWING ...................................................................................... bowtie towing BUILD BOARD & GRAPHICS ........................................................................ the graphics shop STREERING WHEEL & WING WINDOWS & HUBS...................................... wayno RATSUN GRILL BADGE & RATSUN SHIFT KNOB ...................................... Dime Dave PAYPAL DONATIONS CAN BE MADE : Tbowtie@comcast.net please make donations as a gift , to avoid 8% fee per transaction. PAYPAL DONATIONS : ]2eDeYe a6m-zero Justin Berni hobosyder Charlie69 Gradyfest THANK YOU TO ALL OF YOU DONATING PARTS AND LABOR . http://www.bluehandsinc.com http://eugenegraphicsshop.com http://www.youtube.com/user/bluehandsvideo. http://datsunsnw.org http://www.md-machinist.com http://www.futofab.com/ PARTS STILL NEEDED FOR THE BUILD 14 inch white wall tires paint labor one hub cap transportation carpet fuse block labor paint rubber kit 1 Quote Link to comment
denmarkboy Posted January 10, 2015 Author Report Share Posted January 10, 2015 I am not sure if the 4 always hot, 2 ignition hot, or the 3 always hot, 3 ignition hot is the correct fuse box for this truck. Just wire it up like the cover indicates, so it is not confusing to the next owner of the truck. I would suggest using an extra relay, with fused power directly from the battery, or starter lug, to supply power to the original 521 headlight relay. Pin 85 on new relay goes to ground. Pull the red with yellow stripe wire off the original headlight relay, plug it into PIn 86. Direct battery power goes to pin 30 of the extra relay. Pin 87 of new relay goes to the empty pin on the original headlight relay. This mod takes headlight current out of the original 521 fuse box. If you have seen a fair number of 521 fuse boxes, they probably have heat damage at the headlight fuse. without headlight current having to go into the cab, through the headlight switch,and back out of the cab again, the headlights get higher voltage, and are brighter. If the extra relay is located close the the original headlight relay, even when the fuse for the original headlights blow out, you can move the power wire from pin 30 back to the original headlight relay, where the red with yellow stripe wire was, and have headlights. great mod tip Daniel, thanks for that info. 1 Quote Link to comment
DanielC Posted January 10, 2015 Report Share Posted January 10, 2015 If anything in my explanation does not make sense, I can provide more clarification. This is Ratsun's fuse box cover. The main difference between the fuse block on Ratsun and Canby truck, that I can see is this. Canby truck has the four always hot, two ignition switched configuration, and Ratsun has the three always hot, three ignition switched configuration. On Ratsun, the headlight fuse is also the tail and marker light fuse. Canby truck uses one fuse for headlights, and the fourth always hot fuse for the taillights. I did have the wiring for the tachometer light short to ground on Ratsun. That took out all my lights, and had I not had the extra relay set up for the headlights, I would have been in the dark with Ratsun, on the way home. I did use the added power wire to the extra relay to power the original headlight relay directly, and turned on the four way flasher, to have some lights on the back of the truck. 1 Quote Link to comment
jrock4224 Posted January 10, 2015 Report Share Posted January 10, 2015 well i cant wait to win this beast 7 Quote Link to comment
jrock4224 Posted January 10, 2015 Report Share Posted January 10, 2015 nas those are your wheels onthe left ...kevin sheats can attest they been done for a grip ... life has just been tough i will meet up this week with you bro i promise,.....coated the dash too ...did the lower inthe wheel color but we are gonna do it white ... some one was sending me a metal ass tray for this ... please speak up i never got one for it but the dash looks tight in blue too .....canby blue as its now called 4 Quote Link to comment
Charlie69 Posted January 11, 2015 Report Share Posted January 11, 2015 Jrock I a have not forgot you I am still looking for the 520 ash tray and as soon as I locate it it will be on the way to you. 2 Quote Link to comment
skyblue Posted January 11, 2015 Report Share Posted January 11, 2015 Nide work Jon. This is gonna be a sick truck!! 1 Quote Link to comment
DanielC Posted January 11, 2015 Report Share Posted January 11, 2015 My opinion, the original fuse box on a 521 is adequate, on a stock truck, with no added electrical accessories, when new. That was 45 years ago. The headlight current going through the headlight fuse makes the fuse clips get hot. Then they lose spring tension. The heat also speed up oxidation of the fuse clips, making the connection there even worse. Glass fuses are made by soldering the fuse element to the end caps of the fuse. If the fuse gets hot, it is very common for the fuse element to come unsoldered, inside the end cap, and you cannot see that. The fuse looks good, but it is not. 1 Quote Link to comment
