What I'm working with!
uberkevin
  • Replies 3.2k
Changed the subi stater this morning after it died yesterday... luckily it's a stick and I was able to get home.
Banana came over, soldered a few things and left with my down pipe so he can put my o2 sinsor in a better spot.
Where there white is, is around where it will be.
Went a little nuts.... let's hope I can put it all back where it was..
Lots of fucking grounds.... that was the main trouble separating wires..
I'll be learning how to solder,
The FSM is helping a ton, should be able to have two different bundles from the one harness.. m
  • Like 4
Heat shrink tubing is the shit. Makes for tight wiring bundles and corrosion prevention, fuck electrical tape to hell
Get zen with it and tighten up your shit
I'm using tape temporary, just to get everything where I want it.. I'm getting smaller and bigger shrinkwrap.. gunna try RadioShack.. if I can find one. I most likely will have to make a few grounds longer. Crazy how many grounds there are..
This isn't very hard.. if you start from the largest part and work with the wires it's not that bad... a little confusing but I get it.. and now know what I can do to help me next time to make it really fucking easy.!! Got got this!
Almost everything I've jumped into like this I've came out on top.. just gotta remember that I know I can do it. Yah know!
  • Like 3
Agree on the heat shrink. Works awesome. You can also get heat shrink with some type of sealant inside that melts into a totally waterproof seal. The thing about using tape 'temporarily' is you'll need to separate the connections again to slip the heat shrink over the wires if that's what you want to do in the end
