What I'm working with!
uberkevin
If you run power directly to your coil on one side an tap a ground with the other side it should fire even without it hooked up any other way. .. don't leave hooked up very long just a few seconds to test.
Yeah it could shock the fuck outta you if you hold it in your hand soooo find a way to run coil wire to engine ground,,,, or not,,  and video tape it. :rofl:
  • Replies 3.2k
Not sure I understand, or even want to do that by my lonesome.
Got the injector figured out.. someone had taped it in with the harness!!
So now it's running on all 4 cylinders.
Small bugs.
Think I need to drop the oil pump and clock the dizzy back a notch or two.
She dies after 10 or so seconds.
I can't pull codes do to not having a green bulb in my ecu, but it would throw codes no matter what do to not having emissions shit..
#3 injector was leaking, fixed that.
Exhaust is really going to be the big thing.. everything is really close to the torsion bar and the block/tranny. A had to cut my ebrake mount to.
Overall it loud! And is nice as fuck to hear run.
My dumb ass.. doesn't know if I got oil pressure tho..... I don't see why I wouldn't have but still.. I didn't hook up a gauge.
