What I'm working with!
uberkevin
  • Replies 3.2k
You are so fucking paranoid about not having water in it... You are only going to see if it fires up on it's own,, not warm it up or anything .. You have an attached garage and running it for more than 15 seconds is probably going to kill you and your neighbors with carbon monoxide poisoning,,   faster than your engine .
Don't forget that i didn't put screw in the speedo gear when i put it in there..
  • Like 4
I start engines all the time without water in them, but I don't normally run them for more than a couple minutes at idle or just above idle.
I think it is Eric with the drag truck that filled his block water jacket with cement all the way to the top, he don't even have water in that block and he races quarter miles with it, but that is not a engine that drives down the hiway for hours and hours either.
  • Like 3
