620 FUNK! **NOW with Stroker!**
  • Replies 703
Busy day... fixin allll freakin day
_DSC0031 by metalmonkey47, on Flickr
Hey bro, someone took your bed...
It all seriousness glad to see all this work. Work decided that it would be fun to ruin a great weekend of working on Datsuns by making me come in and stare at a computer for 10 hours Friday night... Oh well, more datsun money.
Dang I missed a LOT  :confused:
Simple-you have more radiator OUTSIDE the shroud,than you do INSIDE.
so what i see you saying is:
"hey matt, you didnt get a big enough fan... "
Z, you dont gotta beat around the bush... were all adults here... or at least id hope..
what is it? a 10 or a 12in? i just ordered a 12in.. will it be 'too small'?
It's a 12in fan.
Run 2 10s?
Can't be done
The radiator CORE only measures out to 13x19, so there's not enough room for a 14in fan, OR two 10's. I was going to try two 10's in opposing corners, but it wouldn't have fit between the tanks. So far, the weather here has been UP to 75 degrees and idling in traffic or banging hard on it I haven't had any overheating issues with a 192 t-stat.  When the LZ goes in, it'll get a 180.
I'm not concerned about overheating. It's the absolute largest this radiator will accept. Down the road, I'll order an aluminum, or find a larger radiator that I can fit under the hood, and mount more/larger fans on that. Even in GA's brutal southern heat, I've seen cars with larger motors and smaller fan's do just fine.
Now onto business.
We pulled the bed over the weekend and into late Tuesday, were working on finishing up the gas tank repairs, and stripping the frame and underside of the bed. Frame got some cheapo paint/primer, until the paint is done on the truck. Don't want over-spray on expensive good paint. The bed got a heavy coat of primer (not the rattle can stuff) and some satin black paint. Should be good for a few decades I hope.
An update on the LZ:
I've got just about all my parts together now. Just need to get a flywheel turned, and assemble the motor, which is happening tomorrow night so expect some awesome pictures.
For now, some teasers of Master_o_turbonics awesome fab work.
Rather then re-using the tiny port L16 intake, it's getting a ported U67 manifold.
EGR Ports welded up
All the extra tabs/BS are all going to be GONE.
And it's gonna be ported to match the 1.5'' intake ports on the A87 peanut.
It's gonna be a freakin blast  :thumbup:
Some Nismo stuff under the valve cover. With Z car dual valve springs
HUGE intake ports.
Big Z valves
Dished 86mm Forged Mahle pistons. From a 4G63
DTP should like this  :thumbup:
  • Like 3
Specs on cam?
Assuming the "325" on the cam is not duration???
DD will be a bitch if so.
Pinkish aluminum retainers....can't remember if they are the 190-230...or the  240+?
Lift is over .500....you have ...
Nismo
Comp Valve Springs
M-99996-M1046
Coil bind at .970 280lbs/in OD 1.34" assem height 1.72" seat pressure 120lbs.
Insert query....
This is gonna be a fun motor  :thumbup:  Gimmie a few weeks ish, give or take... and I'll have this guy in, with the help of the always awesome Master_o_turbonics!
Specs on cam?
Nismo
Comp Valve Springs
M-99996-M1046
Insert query....
The cam is the same one discussed here:
http://community.ratsun.net/topic/31098-help-identifying-a-racer-brown-cam/
Not quite .500, but relatively close.  According to Datsunwizard ''325R is 275 degrees at .025"lift, 250 degrees at .050" lift and .475" lift at zero lash.''
The motor's gonna be an absolute torque monster. I feel like I am gonna be capable of around 150whp+ with the right carb setup. This motor has a very high potential with a small turbo and an open chamber head and EFI. Or well tuned carb.
Like ??? LIKE ????
How bout LOVE !!!!! :hyper: :hyper: :thumbup:
Hawt Damn boi ! If you do 150RWHP ... you'll have as much horsepower as me L28ET !
At least I think ? I have that much at the wheels ... :lol:
maybe much less :rofl:
errrrmmaaahhhh geerrrrdddd .... love the block and head shots ! Looks clean and you took time to actually paint it right.
Those valve springs make me :D
Stroker + Dual valve-springs + bigger zvalves + hotter camshaft + side-drafts...
I think it's safe to say you haz race motor... without da flames  :thumbup: :cool:
Stroker + Dual valve-springs + bigger zvalves + knary camshaft + side-drafts...
Haha DTP you so excited  :rofl:
Actually wasn't the one to do the block paint, that was all M_o_T! Dude is a superb engine builder and an even better fabrication-er! He's gonna get so much good coming to him for this motor. I'm like a little kid in a candy shop everytime I walk into the garage the last few days  :thumbup:
It may not get side drafts, for drivability purposes. I've been looking at a 38/38 outlaw, but we'll see how it runs on the 32/36 first  :thumbup:
 Yes....Datsunwizard knows his shit.
Asked him many a Q.
Actually......I initially ran the 32/36 on my LZ to break it in ....pulled it.
Bought a brand new 38..... L16 IM ported to the U67....ran it....pulled  it.
Then bought a K14 and fitted some 46mm SUs on it......big difference
