yello620 Posted March 9, 2011 Report Share Posted March 9, 2011 Damn, that looks good Atom.. Quote Link to comment
MYDAILYROUTINE Posted March 9, 2011 Report Share Posted March 9, 2011 Great work man! Looks awesome! Quote Link to comment
Jester Posted March 10, 2011 Report Share Posted March 10, 2011 How about some updated before and after shots? Nice work Bro! keep it up. Quote Link to comment
dspeirn Posted March 10, 2011 Report Share Posted March 10, 2011 nice work super clean dime. i like the color a lot... drive that biiiitch. Quote Link to comment
andrewhans Posted March 10, 2011 Report Share Posted March 10, 2011 I am inspired by your work. That's so badass that you saved this car!!! It looks amazing. Keep up the awsome work. Quote Link to comment
a100addict Posted March 10, 2011 Report Share Posted March 10, 2011 Where would you cut down the quarter? or would you replace the whole quarter? Yyeah my support piece came from a 4 door so that gave me a limited amount of quarter to work with. What I ended up doing was replacing the trunk pan where is was spot welded in along the frame support and the rear window area and then straight under the pillar vents where they are spot welded in as well. The only area that didnt get welded where a factory seem was is the quarters, and I am curious to know where would weld it to make it nicer to finish the body work next time [if there is a next time] just to make it easier on my self or anyone attempting to do it. haha believe it or not it gets easier every one you do. "the first cuts the hardest". open the door make a line across the car from right to left. that will be the 3rd cut make a line through the b pillar in the middle of window. extend the line through the rear pillar. so 3 cuts and you are left with half of the floor and the roof. on a 2 door the cut will be under the front seats. on a wagon or 4 door behind the front seats. does that make sense? basically you are only having the do finish bodywork in the pillars and the rockers. it is easier than trying to match a bodyline in the middle of a fenderwell . also never cut across the roof!!! the amount of skill to weld a roof without warping and causing more work for yourself is out of most peoples reach. including mine. Quote Link to comment
the510keeper Posted March 10, 2011 Report Share Posted March 10, 2011 believe it or not it gets easier every one you do. "the first cuts the hardest". open the door make a line across the car from right to left. that will be the 3rd cut make a line through the b pillar in the middle of window. extend the line through the rear pillar. so 3 cuts and you are left with half of the floor and the roof. on a 2 door the cut will be under the front seats. on a wagon or 4 door behind the front seats. does that make sense? basically you are only having the do finish bodywork in the pillars and the rockers. it is easier than trying to match a bodyline in the middle of a fenderwell . also never cut across the roof!!! the amount of skill to weld a roof without warping and causing more work for yourself is out of most peoples reach. including mine. That's a great idea if your donor car is a 2 door. But in this case, he only had a 4 door donor car. Yes that side welding and filler work was a bitch Quote Link to comment
Jennifer Posted March 10, 2011 Report Share Posted March 10, 2011 coollioo!! :) Quote Link to comment
AtomChurch Posted March 12, 2011 Author Report Share Posted March 12, 2011 That's a great idea if your donor car is a 2 door. But in this case, he only had a 4 door donor car. Yes that side welding and filler work was a bitch Lots and lots and lots and lots and lots of work. And staying up late. Quarters suck. haha Quote Link to comment
AtomChurch Posted March 13, 2011 Author Report Share Posted March 13, 2011 FLOWMASTER! Quote Link to comment
Laecaon Posted March 13, 2011 Report Share Posted March 13, 2011 She's Alive! Good job! Quote Link to comment
INDY510 Posted March 13, 2011 Report Share Posted March 13, 2011 . NICE!!!! .... :thumbup: .. . . sounds good.... . .. . . . . . how hard was it to mount the intake manifold with the motor in the car??? .... .. and where are the fuel lines going??? .. .. . no kinks? Quote Link to comment
AtomChurch Posted March 14, 2011 Author Report Share Posted March 14, 2011 . how hard was it to mount the intake manifold with the motor in the car??? .... .. and where are the fuel lines going??? .. .. . no kinks? It was easy to install the intake with the motor in. I assembled both halves together in the engine bay. As your the fuel lines there is no kinks at all and I hid them through the intake. It makes the engine look a lot cleaner. When I got this motor it was more then a year ago. I fully rebuilt it and got the harness from the guy I got the motor from. He gave me a 95 harness, and 95 ecu. But its a 91 motor. I didn't bother to check the harness out since I saw the motor in his car. When I put the motor in and went to wire it up I realized that The dist and coil were 91 and the harness had the plug for and internal coil. With a bit of research I managed to get the wiring sorted out and changed from the 95 internal coil to a 91 external. I am running the 95 ecu and harness until I get my hands on a 91 ecu/harness and then I think I might use the knowledge I gained from this misfortune to run a 95 dist so i wont have to have a external coil. Here are some pictures. I have the wiring written down in a book. Its pretty straight forward though if you can read a wiring diagram/ecu pinout and can trace some wires. Quote Link to comment
rusty12ver Posted March 14, 2011 Report Share Posted March 14, 2011 Does the 95 ecu have a different tune than the 91 as far as factory tune? Quote Link to comment
victory Posted March 30, 2011 Report Share Posted March 30, 2011 Atom looks soo happy driving his car! It sounds good too, still loud i can hear it all the way out to the hwy. Quote Link to comment
Ballz Posted March 30, 2011 Report Share Posted March 30, 2011 Awesome build! What wheels are those? Star Sharks? What size? Quote Link to comment
]2eDeYe Posted March 30, 2011 Report Share Posted March 30, 2011 Atom looks soo happy driving his car! It sounds good too, still loud i can hear it all the way out to the hwy. That's the stuff :cool: Quote Link to comment
r0p0doe Posted March 30, 2011 Report Share Posted March 30, 2011 Atom looks soo happy driving his car! It sounds good too, still loud i can hear it all the way out to the hwy. Oics or video, or I ain't a believer lol Quote Link to comment
bonvo Posted March 30, 2011 Report Share Posted March 30, 2011 Atom looks soo happy driving his car! It sounds good too, still loud i can hear it all the way out to the hwy. lol my car is the same way unless i come in "ninja style" (shutting the car off a block away) Quote Link to comment
AtomChurch Posted April 2, 2011 Author Report Share Posted April 2, 2011 I need to get a video up! I took it to the pizza meet and indy510 took some photos of me there and on the freeway! We will see how they turn out. Quote Link to comment
INDY510 Posted April 2, 2011 Report Share Posted April 2, 2011 . They turned out looking like crap ... .. .. :lol: Quote Link to comment
Jester Posted April 2, 2011 Report Share Posted April 2, 2011 Nicely done Atom! To take a car from where you started to not only a driver, but, a dang nice looking one. Must feel very rewarding. Congrats! Quote Link to comment
r0p0doe Posted April 2, 2011 Report Share Posted April 2, 2011 I'm in love lol, looks good man. Quote Link to comment
dennis Posted April 3, 2011 Report Share Posted April 3, 2011 Aren't those phil's plates? :lol: Quote Link to comment
izzo Posted April 3, 2011 Report Share Posted April 3, 2011 Aren't those phil's plates? :lol: :rofl: Yes they are, probably just tossed them on there so he could drive till he gets tabs Quote Link to comment
