Whoracle Posted October 16, 2009 Report Share Posted October 16, 2009 Whoracle what size are your wheels? Jovial I read your blog about that software looks cool. I may have to try that when I finally get tuned up. not sure on the offset, but they are 14" x 6.5"(i think its 6.5") Quote Link to comment
SRSANDS Posted October 17, 2009 Report Share Posted October 17, 2009 Today I replaced my 8" GC coilover springs with 7" to get the front lower, replaced my stock rear shocks with KYB gasadjusts, removed my bumpstops in the rear and bolted my cage down. I also put money down on a subi LSD and money down on my VG oil pan and pick up. Man I cant wait!!!!! Oh and used a California duster to get all the dam dust off my poor car! Quote Link to comment
bigjoe619 Posted October 18, 2009 Report Share Posted October 18, 2009 Today i installed the drive shaft, mounted the slave cylender, i installed a 1in front sway bar, tightened misc bolts , mounted all the relays,and started plugig the wireing harnes up motor turns by key but slowly and i hope to pick up the coil tomorrow.. i hope i can start it finaly, and last but not least i mocked up the air damn its comming together.... Quote Link to comment
jovial_cynic Posted October 18, 2009 Report Share Posted October 18, 2009 Sealed up some of the floors on my 510; the previous owner welded in floors but didn't cut out all the old floor, so I cut out as much of the old stuff as I could and sprayed in some rubberized paint to prevent moisture/dirt from getting between the new metal and the old. Quote Link to comment
izzo Posted October 18, 2009 Report Share Posted October 18, 2009 wheeled it, over heated it, got mud all over the inside and outside. And put water in it before the trip :D Quote Link to comment
bonvo Posted October 18, 2009 Report Share Posted October 18, 2009 installed a new head gasket and timing chain tomorrow asiliscope tuning and driving Quote Link to comment
bigjoe619 Posted October 19, 2009 Report Share Posted October 19, 2009 (edited) today i hit the junk yard and picked up a gear reduction starter, i picked up an accel coil wired it up and installed the dist tried to start the car but timing was off so i dropped the oil pump set the timing but its still off by a hair so i took the 10mm bolt off so i can see how far off the timing is but it started loud as hell with no exhaust just short header but those 44mm mikuni carbs sure sound good.... I will be down in mission valley soon Edited October 19, 2009 by bigjoe619 Quote Link to comment
jovial_cynic Posted October 19, 2009 Report Share Posted October 19, 2009 Almost finished wiring up the headlights. Also installed a bunch of sound deadening material, which should hopefully help me hear myself think while I'm driving. Quote Link to comment
68Datsun510 Posted October 21, 2009 Report Share Posted October 21, 2009 I drove it! Been doing a lot of Datsun Driving lately, a far cry from the last 2.5 YEARS of being datsunless... Quote Link to comment
bonvo Posted October 21, 2009 Report Share Posted October 21, 2009 drove it she like the higher rpms (couldnt use them due to timing being out if wack) dug threw the local pnp for an inline radiator filler from an mr2 and there was nothing Quote Link to comment
AtomChurch Posted October 21, 2009 Report Share Posted October 21, 2009 I need a inline filler too! I changed a radiator hose and then I realized my digital volt meter isn't working. uhg. haha. I needed to rewire it anyway, but now I just HAVE to instead of it being a good idea. Quote Link to comment
paradoxx Posted October 21, 2009 Report Share Posted October 21, 2009 fixed my turn signal system and changed flasher. Saturday I will change a couple of studs. Quote Link to comment
hang_510 Posted October 21, 2009 Report Share Posted October 21, 2009 i stared at the goon in its new garage for ~20min :mellow: anyone got some time for sale? i dont have any... Quote Link to comment
bigjoe619 Posted October 22, 2009 Report Share Posted October 22, 2009 I got my car running ........... now to install the gauges and do odds and ends Quote Link to comment
chebetio510 Posted October 22, 2009 Report Share Posted October 22, 2009 put on my new bluebird mesh jdm grill :D :fu: Quote Link to comment
mazdat Posted October 24, 2009 Report Share Posted October 24, 2009 a couple of days ago, replaced the valve seals , adjusted the carbs and timing, car runs GREAT!!, and i though it ran great before, and no more smoke:D Quote Link to comment
5dimer Posted October 24, 2009 Report Share Posted October 24, 2009 Sanding and sanding and even more sanding. I hate sanding :) Quote Link to comment
thisisastickup Posted October 24, 2009 Report Share Posted October 24, 2009 Drove it for about an hour. Got stares from everyone, I love it. Quote Link to comment
bonvo Posted October 25, 2009 Report Share Posted October 25, 2009 gave it a hot vave adjust and drove her hard she likes it :D Quote Link to comment
bigjoe619 Posted October 26, 2009 Report Share Posted October 26, 2009 got my car all running and found out the tranny was bad so i took the one out last nite and put a different one in today it was a workout lol.. no i can start the odds and ends.. Quote Link to comment
chebetio510 Posted October 26, 2009 Report Share Posted October 26, 2009 mounted my 15x7 enkei 92's :D offset,, 205 50 15's Quote Link to comment
jovial_cynic Posted October 26, 2009 Report Share Posted October 26, 2009 Pulled the alternator. The internal voltage regulator puked, causing the voltage to jump past 18+ volts. No good. Fortunately (or unfortunately,depending on how you feel about this), my alternator has an Autozone lifetime warranty, so I'm getting a new one tomorrow at no cost. Because Autozone alternators aren't known to be the most reliable, I think I might wire in an external voltage regulator as an emergency backup, so that if the next alternator fails, I can toggle over to the back up voltage regulator (kind of a manual "limp mode" for the car) and won't worry about toasting my battery while I'm driving home from a trip or something. Quote Link to comment
murderwagon Posted October 29, 2009 Report Share Posted October 29, 2009 priced out my winter build and did some research on my rear suspension and drifted the shit out of her in the rain gotta love traffic circles Quote Link to comment
SRSANDS Posted October 30, 2009 Report Share Posted October 30, 2009 Ran new 5/16 fuel line and return to and fro a volvo fuel pump. Test fitted and fabbed a golf rad I got from the PAP Quote Link to comment
jovial_cynic Posted October 30, 2009 Report Share Posted October 30, 2009 Installed the new alternator. And... I probably won't be driving it for a while, since we're packing up to move in 3 weeks, and it's probably best if I prioritize the packing and moving plans. I'll have the car on a flatbed trailer for the drive down. Maybe, just maybe, I'll make sure to pull the 510 off the trailer every rest stop we make, so I can say that I've driven my 510 through several different towns. ha. Quote Link to comment
