skyblue Posted October 11, 2015 Report Share Posted October 11, 2015 lowered the rear 5 Quote Link to comment
edekalil Posted October 11, 2015 Report Share Posted October 11, 2015 Someone stole my goon. Not realy. I got lucky and two of McComb's finest helped me push out the Cuda and push the goon from around the corner from behind my building to in front into the garage. So now I can get the motor and trans off the floor and into the goon. Then I just have to figure who will help me push it all back so I can finish it later. Man I shouda cleaned this thing out under the hood. Quote Link to comment
r0p0doe Posted October 12, 2015 Report Share Posted October 12, 2015 Patched up my leaky oil pan so it's all good for now just need to avoid speed bumps lol Quote Link to comment
Three B's Racing Posted October 12, 2015 Report Share Posted October 12, 2015 Nothing to mine because mechanically it doesn't need anything. But I did wash the thing yesterday and drove it to work today and soon it'll get put away for the winter where I may pull the pass door and fix a couple issues but today I drive and enjoy. Quote Link to comment
KoHeartsGPA Posted October 13, 2015 Report Share Posted October 13, 2015 Had a fouled out spark plug, BP7ES, so replaced all 4 for BP5ES set at .40 gap and not only it idles smoother than before, it also has better take off. Quote Link to comment
q-tip Posted October 13, 2015 Report Share Posted October 13, 2015 Lookin like a little blow by, or perhaps a leaky valve seal. Quote Link to comment
KoHeartsGPA Posted October 13, 2015 Report Share Posted October 13, 2015 That's what I thought at first, but no oil, dirty plug with lots of gas, I fired her up and ran fine, then I shut her off for couple hours and was going to go drive around for a bit, when I fired her up she immediately started idling weird then I pulled the throttle and it clearly was running on 3 cylinders, I tried to clear it out by revving her but it clearly wasn't going to, it even started making backfire sounds, so I started taking the plugs out and #2 was drenched in gas, all the others looked good, I put a new set I had and fired right up and ran excellent, I re checked all the plugs after I drove to AutoZone for another set of plugs (I like to keep an extra just incase) and when I got back I checked that #2 and looked ok, I'm going to keep an eye on it though..... Here's a pic of all when I pulled them for replacement.... Quote Link to comment
shacks510 Posted October 13, 2015 Report Share Posted October 13, 2015 Patched up my leaky oil pan so it's all good for now just need to avoid speed bumps lol That's what you said last time you fixed it :lol: 2 Quote Link to comment
r0p0doe Posted October 13, 2015 Report Share Posted October 13, 2015 That's what you said last time you fixed it :lol: Bette result this time :fu: Quote Link to comment
Lockleaf Posted October 14, 2015 Report Share Posted October 14, 2015 I plugged in a tach resistor... Disassembled an entire 720 today though. 2 Quote Link to comment
edekalil Posted October 16, 2015 Report Share Posted October 16, 2015 Finaly got a motor in the goon. Still got to find all the other parts to complete it and get it running. This thing is gonna need a lot of cleanning.I havent driven it in years. 2 Quote Link to comment
Ranman72 Posted October 16, 2015 Report Share Posted October 16, 2015 I drove it here for a car show tomorrow through sunday Quote Link to comment
qwik510 Posted October 16, 2015 Report Share Posted October 16, 2015 Sold it. Boo hoo. Gonna miss this one. Quote Link to comment
DaBlist Posted October 16, 2015 Report Share Posted October 16, 2015 Sold it. Boo hoo. Gonna miss this one. Getting married, getting unmarried, daughter getting married, buying house, starting business, had twins? Quote Link to comment
Draker Posted October 16, 2015 Report Share Posted October 16, 2015 I believe he said health issues forced sale in a different thread. Quote Link to comment
KoHeartsGPA Posted October 16, 2015 Report Share Posted October 16, 2015 That's a bummer... Quote Link to comment
qwik510 Posted October 17, 2015 Report Share Posted October 17, 2015 Yes, unfortunately I have had issues with my eyesight after a surgery and it affects my ability to work on certain things. I decided it would be best to sell this one and keep the other two Datsuns that both run and drive. I can still see fine for driving, life, etc. 1 Quote Link to comment
Draker Posted October 17, 2015 Report Share Posted October 17, 2015 Yes, unfortunately I have had issues with my eyesight after a surgery and it affects my ability to work on certain things. I decided it would be best to sell this one and keep the other two Datsuns that both run and drive. I can still see fine for driving, life, etc. That's really good to hear! Sucks to see one leave the stable, but hopefully it went to another good home. 1 Quote Link to comment
shacks510 Posted October 19, 2015 Report Share Posted October 19, 2015 Finally pulled out the L16 2 Quote Link to comment
paradime Posted October 29, 2015 Report Share Posted October 29, 2015 Finished a lighting upgrade on the 510, and it worked out better than I could have imagined. I used universal halogen projector pod headlights made by Hella, and a custom harness made by Ray at rallylights.com. These pods and their wiring are water tight. You can see on the outside of the light housing there are mounting bolt receivers. As luck would have it, these bolt holes line up perfectly with the inner flange of the stock headlight dish. This made for an easy install, and all the adjustments are still done with the stock bracket. Another added benefit is there plenty of airflow passing around these lights, so it allows cool are for intake. My air filter sits right behind the headlight. On the harness you can see Ray incorporated a stock headlight plug for using the stock output as the relay trip. Again super easy instal. I was going to paint the inside of the headlight dish silver to mimic the sealed beams, but it look janky. I think the black on black with the stainless ring looks much better. Although I haven't take the car out to adjust them yet, the cutoff line is ridiculously crisp, and bright. WAY better than the weak ass stock sealed beams. 3 Quote Link to comment
pablo Posted November 1, 2015 Report Share Posted November 1, 2015 put my grill back on 5 Quote Link to comment
qwik510 Posted November 1, 2015 Report Share Posted November 1, 2015 ^^^^ Love the 68 grill. 3 Quote Link to comment
B-Mackin Posted November 1, 2015 Report Share Posted November 1, 2015 Shake down cruise after many upgrades to an already strong Rebello power plant. 2 Quote Link to comment
