edekalil Posted December 27, 2015 Report Share Posted December 27, 2015 Put a drive shaft and fuel pump on the goon. Found all of the parts needed to get the motor up and running. And covered her a bit better for now. Next the breaks and clutch, hydrolic stuff so it can go and stop. Quote Link to comment
edekalil Posted December 27, 2015 Report Share Posted December 27, 2015 Been driving the 72 two door the last couple ofdsys trying to keep from getting rained on. Loving the way it's running. 2 Quote Link to comment
edekalil Posted December 27, 2015 Report Share Posted December 27, 2015 Previous owner started to get some rust in the drivers floor board, his fix was to put some glass down. Decided it was finally time to try and fix it. Need to get some panels some where. Good luck on that. Quote Link to comment
That4doorKiD Posted December 28, 2015 Report Share Posted December 28, 2015 driving it unecessarily the long ways everywhere in town cause I like cruising in my dime hahaa B) 3 Quote Link to comment
freekwonder Posted December 28, 2015 Report Share Posted December 28, 2015 Good luck on that. Yeah, I'm going to need it. Never done it before. Tempted to put the fiberglass back in and do something else lol. Quote Link to comment
russaroll Posted January 3, 2016 Report Share Posted January 3, 2016 Cleaned my K14 mani. SU are at Ztherapy right now. Can't wait. Quote Link to comment
Big_E-Dog Posted January 4, 2016 Report Share Posted January 4, 2016 roof rack so i can carry bodies on the roof lol Quote Link to comment
desmo Posted January 4, 2016 Report Share Posted January 4, 2016 Drove my datsun for the first time in 18 years 5 Quote Link to comment
Anonymous Waffle Posted January 4, 2016 Report Share Posted January 4, 2016 When you find out your roadster SU airfilters dont fit, so you cut the air horns, and make a quick stop at the womans section. 2 Quote Link to comment
edekalil Posted January 4, 2016 Report Share Posted January 4, 2016 Drove my datsun for the first time in 18 years.Good man. Quote Link to comment
edekalil Posted January 4, 2016 Report Share Posted January 4, 2016 Fired her up and drove her yesterday and plan to do it again today. Quote Link to comment
scooter stuff Posted January 4, 2016 Report Share Posted January 4, 2016 I walked by mine when I went to turn on the air compressor 1 Quote Link to comment
jovial_cynic Posted January 4, 2016 Report Share Posted January 4, 2016 Got the SR back into the car with a fixed transmission. This transmission came with a rubber isolator for the mount, so I rebuilt my transmission cross-member to accommodate it. Also installed a new electric fan. I just need to top off the fluids, plug everything back in, tighten all the hand-tightened bolts, and go go go. 2 Quote Link to comment
KoHeartsGPA Posted January 5, 2016 Report Share Posted January 5, 2016 Drove my datsun for the first time in 18 years Moar oics! Quote Link to comment
r0p0doe Posted January 5, 2016 Report Share Posted January 5, 2016 Moar oics! Fuck that, I wanna see video :rofl: Quote Link to comment
jovial_cynic Posted January 6, 2016 Report Share Posted January 6, 2016 Just got these. I'll need to fabricate up the hardware for them, but they sure are pretty. edit: I changed my mind. I didn't get the seats. In other news, after swapping out the transmission and replacing the rod bearings, I got it fired up again. https://youtu.be/1RrLPCBZcSU 1 Quote Link to comment
shacks510 Posted January 14, 2016 Report Share Posted January 14, 2016 Redid the hydraulic lines in the 510. The whole car has been redone. Ditched the unnecessary and ugly pressure switch (most people don't have it hooked up anyway) and cleaned up the mess of hardline. Plain and simple. I used Rhinohide line from O'Reilly. They sell it in prefab various lengths, or you can buy a 25' roll; which is what I ended up getting. It has an olive green polymer coating that will not crack/chip. It's pretty neat. I found a local shop that has an Eastwood flaring tool to do the flares for me. I wasn't going to waste my time or money with those cheapo tools. 3 Quote Link to comment
Doraemon Posted January 14, 2016 Report Share Posted January 14, 2016 Looks good ! Lines look even factory. The black spot paint in the engine bay is it the same kind of stuff the guy with his 510 in Jay Leno's show uses ? Is it easy to clean ? Quote Link to comment
shacks510 Posted January 15, 2016 Report Share Posted January 15, 2016 The black spot paint in the engine bay is it the same kind of stuff the guy with his 510 in Jay Leno's show uses ? Is it easy to clean ? It's Duplicolor spatter paint, which I clear coated. Left raw, it literally turns to mush and will wipe right off if it gets wet too long. I'm hoping I got enough clear coat coverage. It's easy to wipe the dust off with a damp towel. The texture is there, but isn't at all aggressive. You can run your knuckles across it without an issue. I like it a lot. I used it to my advantage to cover up some paint imperfections. I used about 8 cans. The coverage per can is pretty lousy, but I made do. Quote Link to comment
russaroll Posted January 15, 2016 Report Share Posted January 15, 2016 found out my battery sprung a leak. and this... before after i still need to run fuel lines and do something about this crankcase vent. i picked these up. Is this one better? http://seattle.craigslist.org/sno/pts/5354421061.html 510 flat tops with manifold, heat shield, etc. $150 they were 38mm sss flat tops. then i sent them to zTherapy. now they are on my wagon :) Quote Link to comment
pablo Posted January 15, 2016 Report Share Posted January 15, 2016 those are some beauties 2 Quote Link to comment
edekalil Posted January 17, 2016 Report Share Posted January 17, 2016 found out my battery sprung a leak. and this...before after i still need to run fuel lines and do something about this crankcase vent. i picked these up. they were 38mm sss flat tops. thhhen i sent them to zTherapy.now they are on my wagon :)What did it cost at Z therapy for what you had done? What size motor are they on? I have a set of these with kits to rebuild them. Just never have worked on any. Yours look great. Quote Link to comment
russaroll Posted January 17, 2016 Report Share Posted January 17, 2016 What did it cost at Z therapy for what you had done? What size motor are they on? I have a set of these with kits to rebuild them. Just never have worked on any. Yours look great. This will be my first venture into su carbs. It was $680, I just sent them in and said the works. Since i didn't know the condition the were in,(other than used.) i wanted a new starting point. They did send a detailed sheet of what was actually done. You also get a DVD about tuning and some extra helpful info. L20b w/A87 head is what they went on. I just sent the carbs. If you send the manifold and/or heat shield they will polish them up also and it will raise your cost. 1 Quote Link to comment
paradime Posted January 20, 2016 Report Share Posted January 20, 2016 Those flat top SU are purdy. I could never get my SUs to work right on my old L20, so I swapped to Webber. I tell you what though, with a cam and some porting that motor really woke up. It was like flipping the GO switch. 1 Quote Link to comment
heywier427 Posted January 31, 2016 Report Share Posted January 31, 2016 Painted behind the grill/valance. The results give me chub. IMG_1567 by thomas telesco, on Flickr That was a lot of taping. 4 Quote Link to comment
