My first datsun
Nath96
  • Replies 51
On 6/23/2020 at 2:23 PM, banzai510(hainz) said:
yes that my Green truck I had since Jan2000 for 700$. really got as a throw away but I haven't thrown it away yet.
smashed it and straighten it out and put a Ninja decal over the area and looks Ok again.
..............we would like to see that custom Ninja vinyl work! 😁
  • 4 weeks later...
  • 1 month later...
So the truck should finally be here next week and I'm so excited 😁 does anyone know if there's any conversion kits available just the pcd is 6x139.7 and I dont really like the wheels on the truck or any new ones I can find online, thanks
no man. Has to be custom and you can find some decent old school JDM 6x139s it might just take a while.
Edited by d.p
  • Like 5
  • 4 weeks later...
  • 1 month later...
16 minutes ago, Nath96 said:
Just a quick one does anyone know the best way to remove the rear hubs? Just wanna check they pull straight off with an extractor and there's no special way of getting them off, thanks
The axle or the hub assembly off the axle?
The hub is basically pressed into the backing plate..... I'm trying to figure this out right now to be honest with you....
What are you up too?
Disk brake conversion?
This video has a spot where he is removing the hubs....
  • Thanks 1
1 minute ago, Nath96 said:
Oh so do I have to pull the full axle?
The assembly looks like this.....
You dont need the hub removed from the backing plate just the axle from the hub.... from what I can tell the bearing has a keeper nut but the bearing is actually pressed on the axle shaft....
So you'll need to remove the axle which is the 4 nuts on the back and then remove the bearing to get the hub off....
Might as well put new seals on and maybe a new bearing while your in there...
