DanielC Posted December 10, 2020 Report Share Posted December 10, 2020 The half plate just covers the hole below a plate between the engine and transmission. It stops gravel , dirt, small animals from getting in the clutch levers. 1 Quote Link to comment
d.p Posted December 10, 2020 Author Report Share Posted December 10, 2020 5 minutes ago, DanielC said: The half plate just covers the hole below a plate between the engine and transmission. It stops gravel , dirt, small animals from getting in the clutch levers. Ty mang. 1 Quote Link to comment
jagman Posted December 11, 2020 Report Share Posted December 11, 2020 Y'all know GOD makes tranny jacks Right? 1 Quote Link to comment
mainer311 Posted December 11, 2020 Report Share Posted December 11, 2020 I'm having deja vu over here. 2 Quote Link to comment
datzenmike Posted December 11, 2020 Report Share Posted December 11, 2020 The half plate is mostly used on automatics so you can get at the torque converter bolts on this side, not needed on a standard flywheel. I hope you have the top half. 1 Quote Link to comment
thisismatt Posted December 11, 2020 Report Share Posted December 11, 2020 https://www.amazon.com/Bolt-Thread-Checker-Complete-Metric/dp/B06ZYD4SS8/ref=sr_1_1_sspa?crid=5U7IIW7VFYL&dchild=1&keywords=thread%2Bdetective&qid=1607658839&sprefix=Thread%2Bdet%2Caps%2C287&sr=8-1-spons&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExUDhGMUJENFVWRDhYJmVuY3J5cHRlZElkPUEwMzkzNDkyU1o4TUlMWjlCWUE1JmVuY3J5cHRlZEFkSWQ9QTA5MzU2ODgzRlo0RFFCUEpYRExRJndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ&th=1 1 Quote Link to comment
d.p Posted December 11, 2020 Author Report Share Posted December 11, 2020 1 hour ago, datzenmike said: The half plate is mostly used on automatics so you can get at the torque converter bolts on this side, not needed on a standard flywheel. I hope you have the top half. nah that’s all I got and all that came off my truck. What’s the top look like? 1 Quote Link to comment
datzenmike Posted December 11, 2020 Report Share Posted December 11, 2020 A standard engine plate is simply one piece. Just know that the transmission sits the thickness of this plate forward if missing. About 1/8 inch. The starter bolts to the transmission so the starter gear will engage the starter ring less by 1/8" and the clutch release collar will be forward by this amount and closer to the pressure plate. I'm sure it will probably work but .... Nissan must have put them there for a reason. 2 Quote Link to comment
Crashtd420 Posted December 11, 2020 Report Share Posted December 11, 2020 (edited) 6 hours ago, d.p said: nah that’s all I got and all that came off my truck. What’s the top look like? Did you have another one with the L20b? Or check that other L16 you have..... Edited December 11, 2020 by Crashtd420 1 Quote Link to comment
mainer311 Posted December 11, 2020 Report Share Posted December 11, 2020 7 hours ago, datzenmike said: The starter bolts to the transmission so the starter gear will engage the starter ring less by 1/8" You mean 1/8" more. 1 Quote Link to comment
d.p Posted December 11, 2020 Author Report Share Posted December 11, 2020 (edited) Yeah I got the full plate(s) on my L20B and L16. You can see both of those full plates in the pics below so not sure why I had the additional half plate that was behind the flywheel but bolted to the trans. That is unless the one on my L16 is only the top half like in Mikes picture? Edited December 11, 2020 by d.p 3 Quote Link to comment
mainer311 Posted December 11, 2020 Report Share Posted December 11, 2020 (edited) This is a full plate. If you use a plate that looks like this, then it replaces that little bottom cover: There are a few different flavors: Edited December 11, 2020 by mainer311 3 Quote Link to comment
d.p Posted December 11, 2020 Author Report Share Posted December 11, 2020 Ah shit the L16 is a 2 piece plate vs the 1 piece on the L20B. That mystery is solved. Got my mount studs re threaded and they are good as new. I also ordered new ones from Amazon and will compare to see if would still work. Need to replace throw-out bearing , re-run some of the front brake lines and then hopefully get the trans installed. Hoping to get the engine in and mated this weekend as the weather is supposed to be super nice. Still need to refill steering box with oil as well. When I do mate the trans should I put a little grease on the trans shaft? I know white lithium grease on the shift fork knob/ears. Blue loctite on the flywheel/PP bolts? Torque for both of those sets of bolts? 2 Quote Link to comment
d.p Posted December 11, 2020 Author Report Share Posted December 11, 2020 @mainer311 My l20B came with the one on the bottom left so I am all set. 1 Quote Link to comment
datzenmike Posted December 11, 2020 Report Share Posted December 11, 2020 1 hour ago, mainer311 said: You mean 1/8" more. Flywheel stays with the engine. Starter is bolted to the transmission which without the engine plate will be closer to the flywheel. Starter is moved about 1/8" forward. 2 Quote Link to comment
banzai510(hainz) Posted December 11, 2020 Report Share Posted December 11, 2020 full plate goes on engine first with mating 5 speed(means come from the mating 5 speed together the half plate goes with the orginal 4 speed but one can sneak it down bast the falywheel the half plat don't line up with the newer 5 speed I believe so one has to use the matching plate. Only way to get it one is take the flywheel off and DO OVER!!!!!!!!!! As for the thread question a few lines back remember the body bolts on a early Datsun is SAE and motor is metric. REMEMBER THIS. if a nut don't go on , or a bolt don't go in is most liely the casue of mismatched threads after 73 then it was all metric. 2 Quote Link to comment
mainer311 Posted December 11, 2020 Report Share Posted December 11, 2020 38 minutes ago, banzai510(hainz) said: As for the thread question a few lines back remember the body bolts on a early Datsun is SAE and motor is metric. REMEMBER THIS. Yeah, but we're talking about a motor mount. It's right in the middle. It's a crap shoot. 2 Quote Link to comment
mainer311 Posted December 11, 2020 Report Share Posted December 11, 2020 56 minutes ago, datzenmike said: Flywheel stays with the engine. Starter is bolted to the transmission which without the engine plate will be closer to the flywheel. Starter is moved about 1/8" forward. Oh yeah. Clearly not enough coffee this morning. 1 1 Quote Link to comment
d.p Posted December 12, 2020 Author Report Share Posted December 12, 2020 Back at it today gentleman’s. Can someone tell me if I should install the trans mount(s) before or after I lift the trans into place? 1 Quote Link to comment
datzenmike Posted December 12, 2020 Report Share Posted December 12, 2020 After in will work for sure. If on the truck it will be in the way, if on the transmission less so. 1 Quote Link to comment
d.p Posted December 13, 2020 Author Report Share Posted December 13, 2020 On 12/6/2020 at 3:44 PM, datzenmike said: Also pack the cavity inside the collar (and the pivot ball) with thick bearing grease. For the transmission spline, the two finger tips of the fork where they contact the collar and both ends of the slave push rod use white (lithium) chassis grease. this the cavity you are referring to? Quote Link to comment
d.p Posted December 13, 2020 Author Report Share Posted December 13, 2020 (edited) Thanks man. Anyone got a truck to mate the trans to the engine before installing it? I have a hoist table jack and can’t seem to find an easy to mate them solo. Edited December 13, 2020 by d.p Quote Link to comment
jagman Posted December 13, 2020 Report Share Posted December 13, 2020 Lower your engine toward the floor until it is level with the tranny and use the dolly to move it into place. I hope that you used a spline tool before you tightened the pressure plate. Quote Link to comment
d.p Posted December 13, 2020 Author Report Share Posted December 13, 2020 Yeah I used a clutch alignment tool so pretty sure the clutch is centered. I can always take the pressure plate and clutch off to make sure but I’m pretty sure it’s ok. This is the closet I can get it. If it’s not supposed to be this hard then maybe my pilot bushing is fucked up or the wrong id? does the trans even reach the pilot bushing before it engages the splines? Quote Link to comment
