Charlie69 Posted December 14, 2020 Report Share Posted December 14, 2020 15 hours ago, Charlie69 said: you need more angle and someone under the truck to guide the transmission in and position a jack to lift trans up over the cross member. do not try to lift it over by hand in case the chain slips and the angle changes. Put the the chain directly into the hoist hook and also shorten the mounting of the chain to get maximum lift needed to get the motor in. 1 Quote Link to comment
Charlie69 Posted December 14, 2020 Report Share Posted December 14, 2020 20 hours ago, mrbigtanker said: Untitled by raymond medeiros, on Flickr Here is what it will look like when installed. lol That is beautiful!!! Nice work Mr Tanker this is what we have grown to expect from you, perfection and quality! 2 Quote Link to comment
mainer311 Posted December 14, 2020 Report Share Posted December 14, 2020 1 hour ago, Charlie69 said: That is beautiful!!! Nice work Mr Tanker this is what we have grown to expect from you, perfection and quality! More like irrational and deep pockets. 1 2 Quote Link to comment
Charlie69 Posted December 14, 2020 Report Share Posted December 14, 2020 Still beautiful and some fine workmanship has gone into this truck. 1 Quote Link to comment
d.p Posted December 15, 2020 Author Report Share Posted December 15, 2020 Got the aftermarket motor mount and they 4mm or so taller than the stock ones. Whether that is so to age of the stock ones who knows. Hard to get a good picture of the difference being so little. 1 Quote Link to comment
d.p Posted December 15, 2020 Author Report Share Posted December 15, 2020 Another. 1 Quote Link to comment
NC85ST Posted December 15, 2020 Report Share Posted December 15, 2020 That looks like the same Harbor Freight crane that I have and yes you need to get the front of the truck up on jack stands far enough to get the legs of the crane under the control arms. At least that’s what I had to do with my 720. By the way, you can put the engine and trans in together. It is tight and you have to have the right angle to do it. Start by shorting the chain you have attached to the engine and attach the hook closer to the front. Once you have the engine in the air, you will need to lift the back of the trans over the rad support. Once in the engine compartment, use a floor jack to slowly maneuver the trans over the crossmember. It can be done without messing up the rad support or anything else. I know, because I’ve done it on my ‘70 521. It has an L20b with a 280z 5-speed. To give you more clearance, you could remove the balancer pulley. 3 Quote Link to comment
datzenmike Posted December 15, 2020 Report Share Posted December 15, 2020 5 or 6 why would you ask this? 1 Quote Link to comment
d.p Posted December 15, 2020 Author Report Share Posted December 15, 2020 Yeah it’s harbor freight 1 ton. I thought about trying to weasel it in there as one but the last thing I want to do is get it stuck and have to fight it back out. I think my problem is the low ceiling. Move the front bolt to the front fuel pump bolt hole? Leave the back chain on the last exhaust stud? l20b and 280zx 5speed is what I am putting in as well. 1 Quote Link to comment
mainer311 Posted December 15, 2020 Report Share Posted December 15, 2020 (edited) 18 minutes ago, datzenmike said: 5 or 6 why would you ask this? You missed the whole conversation. Nothing important. That new motor mount looks like it has an angle built into it as well. Edited December 15, 2020 by mainer311 2 Quote Link to comment
Crashtd420 Posted December 15, 2020 Report Share Posted December 15, 2020 Just now, mainer311 said: That new motor mount looks like it has an angle built into it as well. I was just thinking that same thought.... Quote Link to comment
NC85ST Posted December 15, 2020 Report Share Posted December 15, 2020 Where you have the chain attached is fine, but where you have 6-8” of chain above the cam, it needs to be more like 2-3”. Should give you the needed ceiling clearance as well. Quote Link to comment
Charlie69 Posted December 15, 2020 Report Share Posted December 15, 2020 I would remove the crank pulleys and the water pump before installing motor and trans. Quote Link to comment
d.p Posted December 15, 2020 Author Report Share Posted December 15, 2020 (edited) Don’t know at this point if I even want to fuck with mating the trans to the engine out of the truck. I probably lifted the trans 50 times and jacked the engine up and down another 50 yesterday trying to get It to mate. Chain was shorter but I found it caused the engine to lean forward and it made it a complete bitch to get level with the trans. It sucked all around. At this point I think I am just going to do them separately. Maybe I’ll regret it though trying to do it in the truck. I think the mount looks like it has an angle because of the little nub on the bottom. Hard as shit to get a good picture comparing the two. The new one is bigger that’s for sure. Edited December 15, 2020 by d.p 1 Quote Link to comment
d.p Posted December 17, 2020 Author Report Share Posted December 17, 2020 (edited) I went and bought 2 pilot bushings from Nissan and they slip right over the input shaft like butter. So at this point just to be safe I am going to swap out the bushing that came with my clutch and install one of these Nissan ones. The Nissan ones aren't chamfered like the one I got from the clutch kit. Edited December 17, 2020 by d.p 1 Quote Link to comment
greenthumb Posted December 17, 2020 Report Share Posted December 17, 2020 Good call. That’s the way it should be. Shouldn’t need to struggle to get the input shaft engaged. 1 Quote Link to comment
datzenmike Posted December 17, 2020 Report Share Posted December 17, 2020 The pilot may shrink very slightly when pounding it into the crankshaft, it's very soft. Nissan part would be the best. 1 Quote Link to comment
mainer311 Posted December 17, 2020 Report Share Posted December 17, 2020 2 hours ago, d.p said: I went and bought 2 pilot bushings from Nissan and they slip right over the input shaft like butter. So at this point just to be safe I am going to swap out the bushing that came with my clutch and install one of these Nissan ones. The Nissan ones aren't chamfered like the one I got from the clutch kit. I had the exact same experience with the bushing that came in my Exedy kit. Went to local dealer and got a few of theirs. 2 Quote Link to comment
Charlie69 Posted December 18, 2020 Report Share Posted December 18, 2020 I use an old imput shaft to install my pilot bushings. light hammer tapping on the imput shaft keeps it round and does not egg shape either. 2 Quote Link to comment
d.p Posted December 19, 2020 Author Report Share Posted December 19, 2020 Back at this today on tis freezing cold Saturday. Got to replace the pilot bushing and then install the trans and drop the engine in ....hopefully. I did get new bumper rubbers from Jake and they are titties. The dude does some amazing work. Super easy to install and nice and tight. 1 Quote Link to comment
thisismatt Posted December 19, 2020 Report Share Posted December 19, 2020 6 minutes ago, d.p said: I did get new bumper rubbers from Jake and they are titties. But are they as soft as? 1 Quote Link to comment
d.p Posted December 19, 2020 Author Report Share Posted December 19, 2020 Lol man. when I reinstall this pilot bushing do I need to lube it all? 1 Quote Link to comment
Stoffregen Motorsports Posted December 19, 2020 Report Share Posted December 19, 2020 A tiny smear of grease wouldn't hurt, but no, you don't need to lube it. 1 Quote Link to comment
d.p Posted December 19, 2020 Author Report Share Posted December 19, 2020 I replaced the pilot bushing and now onto getting the trans in place. I put it from the pass side with just the rubber mount attached to the trans but now wondering Should I install it with both mounts on before I stab it in? Seems like a bitch to get the cross member mount on with the trans installed. 1 Quote Link to comment
