My 1971 521
d.p
  • Replies 4.9k
Loosen the isolators as well? ? I took the mounts off completely and lowered the engine to the point where the passenger side looked like it need to be and at that point the pan was hitting the cross member.   Ill fuck with it again tomorrow, fingers crossed I can get it seated.
No idea but the pass isolator never came off, I took the drivers side off because the but was stuck and I had to put it in a vice to get it off.  If I flip it and its higher than that would be no good, it needs to be lower to allow the pass side to seat.  Right now its nowhere close.
Edited by d.p
Look at the one on the driver's side. If the threaded stud were higher or to the right in the picture it would lift and shift the engine to the right.
8E7F0510-9F7B-4817-ABFA-08DBA4F45572.thu
The engine now hinges on the driver's side and rotates in a circle around it. As it swings counter clockwise in the picture above it would be closer to fitting and if this side 's stud were also higher and to the left even better.
That is the right oil pan, if it was wrong(620 pan) it would hit the steering linkage not the cross member.
I mentioned it was a total bitch to get them 620 mounts to work in my 521 and I used them on both sides.
I did the driver side first, then I did the passenger side, I removed the front bolt holding the motor mount onto the frame and loosened the back bolt just enough to let it twist, then I twisted the motor mount until the threaded shaft went thru the engine mount bracket, then I slowly dropped the engine while twisting the shit out of the new mount to try and line up the motor mount hole to the frame hole and I put the bolt in and then tightened everything down, I also mentioned that the motor mount did not last long, the passenger side motor mount separated from the metal piece holding it onto the frame.
The oil pan will hit the cross member if you have no motor mount to hold it up.
I would take both isolators off, put the studs through the motor brackets, loosely put the nuts on, then lower the engine down enough to get the isolator bolts started, then carefully let the engine come down and see if it plunks into place.
It’s easier to get the studs in first then just let the flat bottoms of the isolators come down to the frame.
Edited by mainer311
In this picture the motor appears to be straigh up and down.  I always try to position my lifting chain so the engine hangs with a slant in the normal bolted in position so I have to do less fighting to get it to mount to the motor monts as possible.
In my 66 520with the 80 720 chassis and the 76 620 L20B automatic transmission it leans to the passenger side of the truck.  This makes the carb mounting surface on the intake manifold level from passenger to driver side providing the truck is sitting level.
Please tell me you have the rubber isolators mounted to metal mounts as you lower in to truck. As Mike mentioned before keep everything loose, rubber islotaer to metal part mount and drop in and wiggle and jiggle it in place. Also 4 bolts and the center cross beam is out if that helps.
I drop there engine low ,twist engine to one side, mount bolts and then lower engine hoist and do other side. You will say fuck multiple times but it will happen .
Ahh fuck this thing. I cannot get the motor lined up with the mounts.  If I seat the pass side then the drivers side is off and vice versa.  No amount of twisting or turning seems to blow.
with the pass side mounted the engine is clocked to that side and to get the drivers side in it has to clock even more towards the pass side but no idea how to do that.
the only thing I am meaning if to do is duck up my nice paint job.  Thanks
There are four holes in the motor mount bushings. Two of them are for bolts, the other two are for helping you line the mounts up with the crossmember. You stick a phillips screwdriver in those holes when lowering the motor into place and then all four bolt holes line up. Do this with all brackets and bushings mounted to the engine.
Have you ever installed an I beam or watched it happen? The steel workers use a long pick or a spud wrench that goes in the holes as the beam is being muscled into place. Apply the same logic to the motor mounts.
So the motor mount bushings are the ones that came out of the truck, right? The brackets look correct to me and the holes in the block look correct also (there were blocks with multiple bolt patterns cast into the sides). The only possible issue here (assuming all the parts are correct) is muscle. Jam that fucker in there.
