demo243 Posted June 13, 2019 Report Share Posted June 13, 2019 2 hours ago, Crashtd420 said: Unfortunately this wasnt suppose to be an oil debate, it was supposed to be a drain plug opinion question .... And yes we definitely need to get together..... Hahah yea... ratsun at its best! I've been running the copper crush washers from nissan on my KA. Won't run the nissan filters though.... the rubber seal is too small and had one blow out on me... so I run the Bosch filters. I've run all manner of cheap plastic and fiber washers before with success. Although the plastic ones always seem to deform to much for my liking and not uniformly leaving the potential for leaks. I like the fiber looking ones I use on my Tacoma from Toyota. 3 Quote Link to comment
Charlie69 Posted June 13, 2019 Report Share Posted June 13, 2019 I run the Shell Rotella T4 15W-40. I can do 3 oil changes for the cost one oil change of the Royal Purple. I tried synthetic and synthetic blend and both seeped from the seals on older engines. Even on my rebuilt engines I run the Rotella oil. It is also a good choice for new cam break in oil. 1 Quote Link to comment
Crashtd420 Posted June 16, 2019 Author Report Share Posted June 16, 2019 Hanging out at a car show today.... Unfortunately started raining.... Still here..... Only other datsun was an original with 24k .... 2 Quote Link to comment
Crashtd420 Posted June 16, 2019 Author Report Share Posted June 16, 2019 Here's a cool one.... And for some reason my wife likes this... 3 Quote Link to comment
mainer311 Posted June 16, 2019 Report Share Posted June 16, 2019 That van is pretty cool. She clearly has better taste than you. Today was our monthly cars and coffee but it got postponed due to weather. 1 Quote Link to comment
Crashtd420 Posted June 16, 2019 Author Report Share Posted June 16, 2019 Didnt say I didn't like it, I thought it was a cool van.. I Ment it doesnt fit her style.... out of all the vehicles at the show she really liked the van..... she couldnt believe the motor was basically inside the passenger compartment.... 1 Quote Link to comment
mainer311 Posted June 16, 2019 Report Share Posted June 16, 2019 I mean, all you need is some Scooby snacks. 1 Quote Link to comment
Crashtd420 Posted June 16, 2019 Author Report Share Posted June 16, 2019 13 minutes ago, mainer311 said: I mean, all you need is some Scooby snacks. Funny you say that.... didnt take a pic but there was a 92 dodge caravan at the show painted like the mystery machine.. 1 Quote Link to comment
Crashtd420 Posted June 17, 2019 Author Report Share Posted June 17, 2019 On 6/11/2019 at 6:49 PM, wayno said: When I have a chronic oil pan leak issue I generally just use another oil pan. Well you called this right...... Nothing seemed to seal the drain plug and tonight I finally saw it.... I crawled under the oil pan and watched... sure enough I think I found a tiny crack, the paint has been hiding it..... i have probably been making it worse because I've been messing with it lately.... So the obvious fix is to replace the pan but I'll have to see what someone wants for one and if I can get one and how soon.. but I could be in the same mess with another pan.... I also have a friend who can tig weld it and fix it up..... which is probably what I will end up doing.... But Is there a temporary fix ? Can I use jb weld or will that not hold because of the oil? Should I even both trying? or should I just pull the pan and weld it up, and fix it right? Unless someone can say 100% ya the jb weld will work for 6 month or so till winter time without an issue I'll probably yank the pan tomorrow.... I'm trying to minimize datsun down time but I like the idea of keeping the oil in the engine better.... 1 Quote Link to comment
wayno Posted June 17, 2019 Report Share Posted June 17, 2019 The last pan I had to change out was a SD25 diesel engine pan that had a oil temp sensor welded into the pan, it was weeping around the edges of the weld. The one before was a 1980 L20b oil pan that I had bought that the wrecking yard had punched a hole in to empty the oil instead of removing the drain plug, they do it that way now, I pound the punched hole as flat as I can and weld the rest of the hole shut with a mig welder, I am not the greatest welder and was weeping in the middle of the weld, I believe I took that pan off and re-welded it, but don't recall for sure how I fixed it. Your pan was not likely welded on so that is strange, I will say this, I seriously doubt you can weld on it and fix it in position, it will likely need to be removed, thoroughly cleaned, repaired, and then installed again as you likely do not have an extra oil pan. I have a few extras for a Datsun 521 with an L block, but they are used and I don't recall specifics about any of them except the one front sump modified one I pulled out of a 521, and it has a shitload of welding done to it, PM me if your interested in one and I will take a look at what I have. 2 Quote Link to comment
Crashtd420 Posted June 18, 2019 Author Report Share Posted June 18, 2019 Thanks wayno I'll let you know.... The crack I found is at the edge of the drain plug.... I assume there is a welded in bung where the drain plug goes.... basically that weld is cracking from over tightening..... Other than that the pan is is good shape... 1 Quote Link to comment
thisismatt Posted June 18, 2019 Report Share Posted June 18, 2019 It will definitely need to be removed and thoroughly cleaned in order to tig it. 2 Quote Link to comment
Crashtd420 Posted June 18, 2019 Author Report Share Posted June 18, 2019 Ya I decided I'm not even gonna mess around..... I have already drained the oil, so I am just gonna pull the pan and fix it right.... 2 Quote Link to comment
Crashtd420 Posted June 18, 2019 Author Report Share Posted June 18, 2019 Friend at work is on board to do the welding for me..... I dont trust my ability with my mig welder to do it because of the need to hold back the oil..... Hopefully between tonight and tomorrow I can get it off and cleaned up... trying to give it to him on Thursday so I'll have it back for the weekend...... Unfortunately I think I'll be missing a car show Saturday but this needs to be fixed.... 1 Quote Link to comment
datzenmike Posted June 18, 2019 Report Share Posted June 18, 2019 I don't see why this isn't working. What about the oil pan mating surface?... only thing left. Is it cracked or marred in any way? that the ring seal can't d it's job? 1 Quote Link to comment
Crashtd420 Posted June 18, 2019 Author Report Share Posted June 18, 2019 9 hours ago, Crashtd420 said: The crack I found is at the edge of the drain plug.... I assume there is a welded in bung where the drain plug goes.... basically that weld is cracking from over tightening..... I think you missed this post.... 1 Quote Link to comment
Crashtd420 Posted June 18, 2019 Author Report Share Posted June 18, 2019 I crawled under the oil pan and watched... I found a tiny crack, the paint has been hiding it..... i have probably been making it worse because I've been messing with it lately.... 1 Quote Link to comment
Crashtd420 Posted June 19, 2019 Author Report Share Posted June 19, 2019 I was able to get home from work and get the oil pan off.... I've got that process down to about 30 minutes...... As I was cleaning it up with some lacquer thinner the crack became even more apparent.... flowed right through, the crack... Hard To get a good picture of the problem... I'll get this to my friend tomorrow and hopefully have it back in a day..... Only pic I got... upskirt of the engine.. 1 Quote Link to comment
Crashtd420 Posted June 19, 2019 Author Report Share Posted June 19, 2019 I managed to get the oil pan cleaned up and washed out ready to go home with my friend to weld it up..... Where the pen is pointing is where the leak is..... 2 Quote Link to comment
mainer311 Posted June 19, 2019 Report Share Posted June 19, 2019 I'd throw a bead all the way around that bung, and then machine/file it flat afterwards if needed. It looks high enough that you shouldn't need to. 3 Quote Link to comment
Crashtd420 Posted June 19, 2019 Author Report Share Posted June 19, 2019 13 minutes ago, mainer311 said: I'd throw a bead all the way around that bung, and then machine/file it flat afterwards if needed. It looks high enough that you shouldn't need to. That's basically how he described what what hes gonna do, just gonna let him do what he does... Hes a pretty talented guy.... still in the military and does welding and machining for them so I think I am in good hands..... He has his own little work shop at home where he does welding and some machining and 3d printing.... 2 Quote Link to comment
mainer311 Posted June 19, 2019 Report Share Posted June 19, 2019 Sounds pretty rad. That reminds me, I need to buy a decent mig/gas setup. 1 Quote Link to comment
Crashtd420 Posted June 20, 2019 Author Report Share Posted June 20, 2019 Got the oil pan back..... Very happy..... He welded inside too... I barely tightened the drain plug and filled with denatured alcohol..... No leak ..... 2 Quote Link to comment
greenthumb Posted June 20, 2019 Report Share Posted June 20, 2019 2 thumbsup for persistence! 1 1 Quote Link to comment
