q-tip Posted September 28, 2016 Report Share Posted September 28, 2016 I still have that big brake kit for a king pin truck if your interested... Quote Link to comment
jrock4224 Posted September 28, 2016 Author Report Share Posted September 28, 2016 Well? \ sourcing a driveline ... one was dangled at me but i have a line on another one ... some times piece of mind is worth more then your project ...... and i was out of town last weekend ... 3 Quote Link to comment
tdaaj Posted September 28, 2016 Report Share Posted September 28, 2016 Piece of mind is important 1 Quote Link to comment
DaBlist Posted September 28, 2016 Report Share Posted September 28, 2016 Piece of mind is important 3 Quote Link to comment
jrock4224 Posted October 3, 2016 Author Report Share Posted October 3, 2016 All the hydraulics are bled and done ...brakes need a little break in ... and peddle adjustment ... .... re brakes were never adjusted so they are brand new ... not even sure they were making contact...... they are now .... had to fix my prop valve ... but its all good again ... now for a drivelne and wheels ... then to fix the tail lights ... they are completely wired oddly...will load some pics .. 1 Quote Link to comment
jrock4224 Posted October 3, 2016 Author Report Share Posted October 3, 2016 oics loaner vc and wheels to see where rear ride height will be ... infintis are 18 .. it will run 17's .... should be good height ... for a lady driver ... i will prolly enjoy this more then my truck... 7 Quote Link to comment
mrbigtanker Posted October 4, 2016 Report Share Posted October 4, 2016 Dude lose that canby15 front plate. I would set that on fire. Quote Link to comment
flatcat19 Posted October 4, 2016 Report Share Posted October 4, 2016 Dude lose that canby15 front plate. I would set that on fire. Or just hang it upside down. Probably a better representation of what this truck had been through. 3 Quote Link to comment
datzenmike Posted October 4, 2016 Report Share Posted October 4, 2016 That poor truck...... 2 Quote Link to comment
jrock4224 Posted October 4, 2016 Author Report Share Posted October 4, 2016 need some bmw flag mirrors bad ... any leads ... 2002 ti mirrors ... thanks d mike ... it is not looking good on those wheels 1 Quote Link to comment
DanielC Posted October 4, 2016 Report Share Posted October 4, 2016 I supplied the tail lights for the Canby truck. The tail lights were tested on my bench, and worked. I also plugged then into a spare body, or bed wiring harness for the back of a 521, and made sure the tail lights worked by applying power to the six pin connector, that is by the starter on a 521, that connects the bed or body wiring harness to the engine room wiring harness. I took the tail lights, and wiring harness, and other parts to Eugene, but could only spend a day there, and did not install the wiring harness, or the tail lights on the truck. I believe the bed wiring harness was not changed to the one I tested with the tail lights, but I am not sure. It is very common for 521 tail lights to lose grounds. The lamp sockets are mounted on plastic, and the sockets are only grounded to the tail light frame. The tail light frame should ground to the bed sheet metal, and the bed sheet metal should ground to the truck's frame. But often those grounds go away after 45 years. Run a wire directly from the tail light frame to the frame of the truck, and also make sure the trucks frame is grounded to the engine. 1 Quote Link to comment
jrock4224 Posted October 4, 2016 Author Report Share Posted October 4, 2016 we need to talk cause someones re routed hacked the harness and shit i was assuming i was a gound issue too from the wiring but i had to just jerk half the wonky stuff out.. they worked ... i jsut want to clean up the work around ,.,, 1 Quote Link to comment
DanielC Posted October 4, 2016 Report Share Posted October 4, 2016 I would be glad to talk to you. PM will be sent soon. Quote Link to comment
jrock4224 Posted October 10, 2016 Author Report Share Posted October 10, 2016 Frank came over ... well got there before me ... beat on his lagoon and added more block ... clearanced some shit ... sits lower now and leveler.... i just tinkered ont he can'tby truck ... installed a driveline i got from wayno ... gonna rebuild the other one i got from him and swap drivelines later .. then do the same for my truck too ... installed starter... messed with the torsion bars some... ride height kinda set ... set the toe with our ghetto gauge... installed starter adn some other misc engine stuff that was still off... shifter.... fuel line ... fun fact swapped lugs since m12 x 125 are 510 lugs not 521 Al !!!!!!..... thanks for once again proving i haven't found it all but the simplest of things aren't a care to u. took the infinits off and put hard bodies on to set ride height..... the do not clear the front calipers... truck wont roll but we didnt want it to .....need the ebrake stuff from the handle to the mechanism...... then the tail lights ... sheesh .. this sat that will be the least fun ... spoke to daniel a little looks like his work was all reversed .,... gonna remove the patches and start fresh and use factory plugs again .... he looks to be right that a simple ground issue was turned into a spaghetti feed .... ay way some pics ... \ 8 Quote Link to comment
mrbigtanker Posted October 10, 2016 Report Share Posted October 10, 2016 How much drop you think that is total. Quote Link to comment
mklotz70 Posted October 11, 2016 Report Share Posted October 11, 2016 we need to talk cause someones re routed hacked the harness and shit i was assuming i was a gound issue too from the wiring but i had to just jerk half the wonky stuff out.. they worked ... i jsut want to clean up the work around ,.,, I provided a non-molested harness from front to back.......so if the truck has a hacked harness, that means mine never made it on it. I'd be a bit irritated if that's the case. Anyway... 1 Quote Link to comment
Rick-rat Posted October 11, 2016 Report Share Posted October 11, 2016 The unmolested harness was not put on the truck, I do know where it went 1 Quote Link to comment
mklotz70 Posted October 11, 2016 Report Share Posted October 11, 2016 About the lugs.....it would have ended up with metric up front and imperial in the rear with my disc setup up front.....but you took that off and went back to kingpin. Do you have a pic of the drum hub you used? If you put a 620 drum hub on there, it uses metric lugs. You weren't real clear in your post as to which were wrong....fronts, rears....all? If it's the rears that are metric now, then maybe they were changed to match the 720 hubs that were on the front. Anyway.....it may have been completely intentional and not an F'up, but either way, they metric lugs are from a later truck, not a 510......although they may have used the same studs.....no clue. :) The metrics studs are bigger......I'm not sure you can go back to the 7/16".......will be interesting to see. :) Quote Link to comment
mklotz70 Posted October 11, 2016 Report Share Posted October 11, 2016 The unmolested harness was not put on the truck, I do know where it went hmmm.....that seems to have happened with a handful of nice stuff I sent down. If he didn't use it, it would have been nice to get it back. Oh well......never again! 1 Quote Link to comment
datzenmike Posted October 11, 2016 Report Share Posted October 11, 2016 I provided a non-molested harness from front to back.......so if the truck has a hacked harness, that means mine never made it on it. I'd be a bit irritated if that's the case. Anyway... The unmolested harness was not put on the truck, I do know where it went So some donated parts were never put on the build? just wow..... just how would anyone expect this to not come to light? 2 Quote Link to comment
flatcat19 Posted October 11, 2016 Report Share Posted October 11, 2016 Um...Al sold me a 521 engine harness that seemed to be in really good shape about a month or so prior to Canby. Is this the harness you speak of Rick? 1 Quote Link to comment
datzenmike Posted October 11, 2016 Report Share Posted October 11, 2016 I'm sure the money was donated to the build. 2 Quote Link to comment
flatcat19 Posted October 11, 2016 Report Share Posted October 11, 2016 Sure it was. I just hope unsuspecting participants got to drink a few beers off that money. 2 Quote Link to comment
tdaaj Posted October 11, 2016 Report Share Posted October 11, 2016 I know at least one of the parts i donated didn't get put on the truck. 2 Quote Link to comment
thisismatt Posted October 11, 2016 Report Share Posted October 11, 2016 I know at least one of the parts i donated didn't get put on the truck. Truck nuts aren't really appropriate for a family event :D 4 Quote Link to comment
