cruznude Posted May 31, 2013 Report Share Posted May 31, 2013 What did the motor come out of and what did you have done in the block? Is there no smog issues where you live? Quote Link to comment
Kirden Posted June 1, 2013 Report Share Posted June 1, 2013 Most areas of Georgia do not have to worry about smog. Its only 13 counties(?) around ATL that currently have smog restrictions, and even then there is a year exemption for vehicles older than 25 years. Luckily that means even in ATL the Datsuns can run free without going to the sniffer stations :thumbup: Really liking the build man. Stupid gym dues hit me hard this check but I should be picking up my Z22 block next weekend if it is still in the yard. I'll also be in the market for an open chamber U67 if you know of anyone who may have one. Are you planning to make the next ATL meet? Quote Link to comment
metalmonkey47 Posted June 1, 2013 Author Report Share Posted June 1, 2013 About the valve cover, it literally doesn't line up with the head! Strangest thing I've ever seen. It's off by a few millimeters. I'll post oics.... I have them. The motor did not get finished today. We ran into some issues, and even though they were resolved we had no more daylight left. It's only small stuff left to do, then break in the motor. What did the motor come out of and what did you have done in the block? Is there no smog issues where you live? No smog here. It's a Z20E block, probably from a 200sx. It's got an 86mm bore which is about .30 over bore. Long rods, Z22 crank, 4G63 forged pistons with fully floating wrist pins, etc. Lots of stuff! Really liking the build man. Stupid gym dues hit me hard this check but I should be picking up my Z22 block next weekend if it is still in the yard. I'll also be in the market for an open chamber U67 if you know of anyone who may have one. Are you planning to make the next ATL meet? Thanks man! Sucks that I didn't check this thread first, I offered my U67 head for cheap to a friend. If he backs out or changes his mind, it's all yours!! Quote Link to comment
metalmonkey47 Posted June 1, 2013 Author Report Share Posted June 1, 2013 FYI, the motor is in the truck.... just gotta button it up. Quote Link to comment
TENDRIL Posted June 1, 2013 Report Share Posted June 1, 2013 those intakes ..... :frantics: 1 Quote Link to comment
converted_to_datsun Posted June 1, 2013 Report Share Posted June 1, 2013 you haven't relocated the oil dip stick? how you plan on checking the oil? :confused: Quote Link to comment
Spoona_Jay21 Posted June 1, 2013 Report Share Posted June 1, 2013 out of curiosity, i have heard there is a gap between the timing cover and head on a setup like yours, this correct info? and if so how did you go about filling it? Quote Link to comment
bonvo Posted June 1, 2013 Report Share Posted June 1, 2013 from what ive heard the gap is only there when using a z24 block Quote Link to comment
metalmonkey47 Posted June 1, 2013 Author Report Share Posted June 1, 2013 you haven't relocated the oil dip stick? how you plan on checking the oil? :confused: We moved the dipstick :P If you bend the dipstick tube slightly, you can bring it out right past the header. I don't think it would work with a manifold though since it's larger. With an L pan, the dipstick is too long and misses the sump, so you have to trim an inch or so to get it right. out of curiosity, i have heard there is a gap between the timing cover and head on a setup like yours, this correct info? and if so how did you go about filling it? from what ive heard the gap is only there when using a z24 block ^^^This. The Z20 block and L20 block are nearly identical in every way. Just minor differences. There are a few holes in the block that need to be plugged, but other then that it's pretty much perfect. Quote Link to comment
metalmonkey47 Posted June 1, 2013 Author Report Share Posted June 1, 2013 Pulling the head by metalmonkey47, on Flickr L20B Coming Out by metalmonkey47, on Flickr L20B Funk by metalmonkey47, on Flickr Quote Link to comment
metalmonkey47 Posted June 1, 2013 Author Report Share Posted June 1, 2013 Dat Monster Energy by metalmonkey47, on Flickr U67 Worn the fuck out! by metalmonkey47, on Flickr _DSC0163Oil PanStud by metalmonkey47, on Flickr A87 Peanut by metalmonkey47, on Flickr Dat purp by metalmonkey47, on Flickr LZ22 by metalmonkey47, on Flickr LZ22 Install by metalmonkey47, on Flickr 1 Quote Link to comment
bonvo Posted June 1, 2013 Report Share Posted June 1, 2013 an electric cherry picker? you lazy man lol 1 Quote Link to comment
I'm BLUE Posted June 1, 2013 Report Share Posted June 1, 2013 Vise , engine block , jack , load-leveler , and engine hoist ... ALL BLUE !!! :hyper: Quote Link to comment
TENDRIL Posted June 1, 2013 Report Share Posted June 1, 2013 and his truck is yellow... Quote Link to comment
Z-train Posted June 1, 2013 Report Share Posted June 1, 2013 I'm a fan of "studs where i can".Having said that,studs on the oil pan will make you want to shoot yourself if you ever have to pull the pan in the vehicle. Quote Link to comment
Kirden Posted June 1, 2013 Report Share Posted June 1, 2013 That head is so sloppy :P Definitely let me know if your buddy passes on it. Quote Link to comment
Eagle_Adam Posted June 2, 2013 Report Share Posted June 2, 2013 Done yet ? It's tomorrow... Quote Link to comment
Master-O-Turbonics Posted June 2, 2013 Report Share Posted June 2, 2013 https://www.facebook.com/photo.php?v=10151623081054266 Quote Link to comment
metalmonkey47 Posted June 3, 2013 Author Report Share Posted June 3, 2013 Done yet ? It's tomorrow... Quote Link to comment
Master-O-Turbonics Posted June 3, 2013 Report Share Posted June 3, 2013 lope... Because Racer Brown Quote Link to comment
I'm BLUE Posted June 3, 2013 Report Share Posted June 3, 2013 Sounds heathly and good ! :D :D great job Monkey :thumbup: :thumbup: Quote Link to comment
Dirttrack510 Posted June 3, 2013 Report Share Posted June 3, 2013 Nice! Sounds good :) it sounds a little like my L16 grenade race engine. awesome job :) ;) Quote Link to comment
converted_to_datsun Posted June 3, 2013 Report Share Posted June 3, 2013 Sounds like a monster dude! Good job Quote Link to comment
metalmonkey47 Posted June 3, 2013 Author Report Share Posted June 3, 2013 Thanks guys! The credit all goes to Master-o-turbonics! This dude built me a KILLER MOTOR!!! Now for the latest, FUCK MY LIFE... I pressed the clutch and bam, straight to the floor. Bled it and it got worse. Absolutely NOTHING. Pulled out the clutch master and started disassembling it to check everything out inside and found that the piston was jammed inside of the bore and wouldn't budge about 1/2 way through. Put some air pressure on it and POP... came out. And this is the spring. Nice right? Fuck me this is stupid. I just want to drive my truck! Quote Link to comment
Spoona_Jay21 Posted June 3, 2013 Report Share Posted June 3, 2013 noooo!!!!!!!!!!! glad you finally got the motor in though! Quote Link to comment
