Skib Posted September 28, 2010 Author Report Share Posted September 28, 2010 Are you running the SU's?? Is the throttle cable housing still ok, or close? ya I am. the metal part that bolts to the firewall? thats still intact but Idk how the cable comes out of it, the cable itself is fuck tho go to kregan and get a universal braided on 25 bucks and its brand new how do you have it run on the gas petal side? I have a few cables around that may be useable (one ends been cut off so its just bare cable) but idk how to hold it from moving at the petal side :( Link to comment
yello620 Posted September 28, 2010 Report Share Posted September 28, 2010 How does you cable attach to your firewall? Cable screw onto firewall or bolt on with two bolts? Link to comment
Skib Posted September 28, 2010 Author Report Share Posted September 28, 2010 How does you cable attach to your firewall? Cable screw onto firewall or bolt on with two bolts? its got the metal plate with the tube on that that bolts to the fire wall with two 10mm bolts but the cable in it is just to screwed up to use anymore, its already broken on me twice. Link to comment
Farmer Joe Posted September 28, 2010 Report Share Posted September 28, 2010 is the cable sheath still good? if it is, just take some bicycle cable and run it in the same sheath. find a cable thats got the little soldered end, and use that at the pedal. and then the other end you can use a crimp to make a loop or whatever you gotta do... it'd get ya by til somethin better came along... Link to comment
Skib Posted September 28, 2010 Author Report Share Posted September 28, 2010 is the cable sheath still good? if it is, just take some bicycle cable and run it in the same sheath. find a cable thats got the little soldered end, and use that at the pedal. and then the other end you can use a crimp to make a loop or whatever you gotta do... it'd get ya by til somethin better came along... thanks Ill try that. Link to comment
Farmer Joe Posted September 28, 2010 Report Share Posted September 28, 2010 oh another thing you can do to make that bicycle cable last a little longer. if youve got some chain lube/wax, slather the cable in that before you slide it in the cable sheath. a little fresh lube never hurt lol... Link to comment
bonvo Posted September 28, 2010 Report Share Posted September 28, 2010 how do you have it run on the gas petal side? I have a few cables around that may be useable (one ends been cut off so its just bare cable) but idk how to hold it from moving at the petal side :( it comes with a bunch of different end pieces you find the one that will work the best for your application i used one that fit over the pedal and was held in place with a bolt Link to comment
Braden Posted September 28, 2010 Report Share Posted September 28, 2010 that u20 is a stock l20b camshaft, i think it came out in the u60 l20b's in the early 610's? someone correct me if im wrong, i have a brand new one out in the garage if you need me to take any measurments. Link to comment
mike Posted September 28, 2010 Report Share Posted September 28, 2010 On the Bicycle cable use the metal end on the carb side and figure something out to mount it to the pedal (A bolt off of an old bicycle bolt will work well and is adjustable/non permanent so youll get more than one shot) Adjust your cable to the carb into the center of its range before you affix the mount to the pedal. If it doesnt bind it should last a LONG time... If it does bind either make it so that it doesnt, or carry an extra cable with you at all times. Link to comment
Skib Posted September 28, 2010 Author Report Share Posted September 28, 2010 that u20 is a stock l20b camshaft, i think it came out in the u60 l20b's in the early 610's? someone correct me if im wrong, i have a brand new one out in the garage if you need me to take any measurments. ya I know its an L20 cam but Im thinking it may be a regrind because the stamps on the back arnt all factory. Link to comment
78kingcab Posted September 28, 2010 Report Share Posted September 28, 2010 ya it a regrind ...i know matt the guy who put that motor together....if i can get ahold of him ill ask him about it...hardly every see him anymore ,but he sales stuff on craigslist all da time Link to comment
]2eDeYe Posted September 28, 2010 Report Share Posted September 28, 2010 go to kregan and get a universal braided on 25 bucks and its brand new How long is that out of the box? Link to comment
bonvo Posted September 28, 2010 Report Share Posted September 28, 2010 2eDeYe' date='28 September 2010 - 04:44 PM' timestamp='1285717444' post='360022']How long is that out of the box? i font remember to be honist i had to cut mine in half so there should be plenty there Link to comment
sick620 Posted September 29, 2010 Report Share Posted September 29, 2010 skib im so excited you got a 620, seeing you got one makes me love mine even more. haha Link to comment
I'm BLUE Posted September 29, 2010 Report Share Posted September 29, 2010 ^^^ optional 620 "Skib Edition ---" or "Sick Edition ---" EMBLEM'S ??? :lol: :D Link to comment
Skib Posted September 29, 2010 Author Report Share Posted September 29, 2010 ^^^ optional 620 "Skib Edition ---" or "Sick Edition ---" EMBLEM'S ??? :lol: :D good note to bring this up on I guess :rofl: its going to be a Fitch edition ;) should have seen this coming if you didnt already :lol: no rattle can this time, theres one ding to fix in the bed and the mirror holes to weld up and then itl be off to the painter. Link to comment
bonvo Posted September 29, 2010 Report Share Posted September 29, 2010 skib not using rattle can :o Link to comment
Skib Posted September 29, 2010 Author Report Share Posted September 29, 2010 skib not using rattle can :o this shits strait, Im gonna do it proper Link to comment
sick620 Posted September 29, 2010 Report Share Posted September 29, 2010 rising sun bra and all? Link to comment
78kingcab Posted September 29, 2010 Report Share Posted September 29, 2010 glad to hear about a real paint job... :) Link to comment
bonvo Posted September 29, 2010 Report Share Posted September 29, 2010 thats good to hear just kind of a shock your the ratsun rattlecan god lol did you get the throttle cable sorted out? Link to comment
]2eDeYe Posted September 29, 2010 Report Share Posted September 29, 2010 Fucking sweet... :cool: Link to comment
datzenmike Posted September 29, 2010 Report Share Posted September 29, 2010 its going to be a Fitch edition ;) should have seen this coming if you didnt already :lol: Y'know skib, these Fisch Edition Datsuns (body by skib) will be collector cars in a hundred years. Link to comment
MicroMachinery Posted September 29, 2010 Report Share Posted September 29, 2010 good note to bring this up on I guess :rofl: its going to be a Fitch edition ;) should have seen this coming if you didnt already :lol: no rattle can this time, theres one ding to fix in the bed and the mirror holes to weld up and then itl be off to the painter. Can I put the bullet holes in the side of it? ;) Link to comment
The Dat-side Posted September 30, 2010 Report Share Posted September 30, 2010 I think I heard this guy say you love VWs. Better teach him a lesson :D 620 Link to comment
