Zonargx Posted April 28, 2021 Author Report Share Posted April 28, 2021 ? They seem to be working for me I can also see other peoples pics too 1 Quote Link to comment
mklotz70 Posted April 28, 2021 Report Share Posted April 28, 2021 If you have too much trouble finding a rubber line, you can get generic SS line with adapters. About a third of the way down, you'll find examples of what I'm talking about. You can get any end you need. http://www.bluehandsinc.com/caliper-options.html On the trans output seal.....when I had the '64 NL320, I looked at the seal. I found that every truck trans from it, up into the HB's had the same output seal 2 Quote Link to comment
Zonargx Posted April 28, 2021 Author Report Share Posted April 28, 2021 I guess koning209 measurement about the driveshaft being 51 inches the common lengths was right I seem to have the same length 2 Quote Link to comment
Zonargx Posted April 28, 2021 Author Report Share Posted April 28, 2021 My fuel pump is really quite I can barely hear it priming up. I can show pictures later of where I have it located 1 Quote Link to comment
Zonargx Posted May 3, 2021 Author Report Share Posted May 3, 2021 (edited) What do people with 521 do about fixing the front windshield. My ruber seal is straight trash and leaks a lot of water when it rains I was trying to find out what to do to fix it Edited May 3, 2021 by Zonargx 1 Quote Link to comment
Crashtd420 Posted May 4, 2021 Report Share Posted May 4, 2021 11 hours ago, Zonargx said: What do people with 521 do about fixing the front windshield. My ruber seal is straight trash and leaks a lot of water when it rains I was trying to find out what to do to fix it The windshield seal should be available.... should be an easy fix... It's not a glued in windshield.... Put the seal on the window and do the old rope trick to pull the seal around the metal of the truck.... Hopefully the metal is still solid... 1 Quote Link to comment
Crashtd420 Posted May 4, 2021 Report Share Posted May 4, 2021 https://vintagerubber.com/datsun-nissan/521-truck/ Bottom of the page.... 2 Quote Link to comment
banzai510(hainz) Posted May 4, 2021 Report Share Posted May 4, 2021 https://vintagerubber.com/datsun-520-pick-up-window-scrapers-inner-and-outer-pair-1965-1971/ I been looking for these!!!!!!!!!!!!!!!!!!!!!!!!! 3 Quote Link to comment
Zonargx Posted May 4, 2021 Author Report Share Posted May 4, 2021 @Crashtd420 any link to how to do the rope trick for the windshield? 1 Quote Link to comment
Crashtd420 Posted May 5, 2021 Report Share Posted May 5, 2021 4 hours ago, Zonargx said: @Crashtd420 any link to how to do the rope trick for the windshield? No but its pretty simple... Damn I just wrote something and deleted the whole damn thing..... I'm usually bored at work I'm sure I could find you a good how to if no one else does..... I'll check in tomorrow.... 1 Quote Link to comment
d.p Posted May 5, 2021 Report Share Posted May 5, 2021 Find an independent windshield shop and I am sure they’d help you. They did me and charged me $60 to install and seal using the rope trick. 1 Quote Link to comment
Zonargx Posted May 5, 2021 Author Report Share Posted May 5, 2021 Nice I’ll take it in and see what they can do. Also I driving my truck now but it feels like it lacks power while on gear I can’t give it full throttle or it back fires and slows down like you stems on the brakes. Any ideas of what could be causing this? I have the ka24de and running on ob2. Should I be running two??. Any help is appreciated . ps I feel it could also be the fuel pump but not sure 1 Quote Link to comment
wayno Posted May 5, 2021 Report Share Posted May 5, 2021 This guy in the southern CA area had good 521 windshield gaskets that do not crack in a couple years, I was buying them and selling them to people on Ratsun, don't know what he charges for them now but you only need to buy one as I have had them on my trucks for close to ten years now without issues. http://www.kottoautoglass.com/ He is located at 861 Glencliff St, Unit 58, La Habra, CA 90631 1 Quote Link to comment
banzai510(hainz) Posted May 5, 2021 Report Share Posted May 5, 2021 ask Icehouse again on this if one has issues. He seen the most of these and gives you the fastes respones if hes on here 1 Quote Link to comment
Crashtd420 Posted May 5, 2021 Report Share Posted May 5, 2021 17 hours ago, Zonargx said: @Crashtd420 any link to how to do the rope trick for the windshield? I doubt you need to pay to do this... you just did the engine swap faster than most, so I'm sure your capable. Here's a good link to the process.... 1 Quote Link to comment
Stoffregen Motorsports Posted May 5, 2021 Report Share Posted May 5, 2021 13 hours ago, Zonargx said: Nice I’ll take it in and see what they can do. Also I driving my truck now but it feels like it lacks power while on gear I can’t give it full throttle or it back fires and slows down like you stems on the brakes. Any ideas of what could be causing this? I have the ka24de and running on ob2. Should I be running two??. Any help is appreciated . ps I feel it could also be the fuel pump but not sure Full throttle backfire. Sounds like something didn't get hooked up correctly. Maybe AFM/MAF or TPS. Have you scanned it for codes? Do you have access to any tuning software? I have HP Tuners on my laptop which I use to tune LS swaps, but I can also plug into any OBDII port on any car and see some real time telemetry on a "dash board". Watching fuel curves or spark control or even ECU voltage in real time can be helpful. 1 1 Quote Link to comment
d.p Posted May 5, 2021 Report Share Posted May 5, 2021 2 hours ago, Crashtd420 said: I doubt you need to pay to do this... you just did the engine swap faster than most, so I'm sure your capable. Here's a good link to the process.... Yeah he wasted no time swapping it. Post some pics man. 2 Quote Link to comment
420n620 Posted May 5, 2021 Report Share Posted May 5, 2021 20 hours ago, Zonargx said: @Crashtd420 any link to how to do the rope trick for the windshield? 2 1 Quote Link to comment
Zonargx Posted May 5, 2021 Author Report Share Posted May 5, 2021 36 minutes ago, d.p said: Yeah he wasted no time swapping it. Post some pics man. Will do I just been tires working on it but I’ll be posting some today 1 Quote Link to comment
Zonargx Posted May 5, 2021 Author Report Share Posted May 5, 2021 (edited) @Stoffregen Motorsports yo I think I fucked up plugged the tps wrong I look up pictures on the web Ans they show the brown plug on the top port and the grey on the bottom. I have my plugs the wrong wrong way. ps. Nevermind it was correct Edited May 5, 2021 by Zonargx 2 Quote Link to comment
Zonargx Posted May 5, 2021 Author Report Share Posted May 5, 2021 I’ll be changing them later today. And thanks for the videos I guess your right @Crashtd420 if I just did a swap I can probably do that too haha 2 Quote Link to comment
Zonargx Posted May 5, 2021 Author Report Share Posted May 5, 2021 (edited) Looks pretty easy just need to get me the rope and gasket i also still need to figure out the e brake situation out cuz I do like to have that working Edited May 5, 2021 by Zonargx 1 Quote Link to comment
Zonargx Posted May 5, 2021 Author Report Share Posted May 5, 2021 Could that be if my timing is off? I set it to top dead center when I was putting it back together but apparently your suppose to put it on 20 degrees and I didn’t do that??? 1 Quote Link to comment
Zonargx Posted May 5, 2021 Author Report Share Posted May 5, 2021 (edited) On my way to work right now I was on fifth if I have it full throttle it would boog down and slow down like if I was pressing the brake and at times backfire. If I rev it up really slow it would work fine but not go up in rpms. I need to check my tach I hooked it up but it’s not working so I can’t tell up to what rpms it does that but it seem around 2-3k Edited May 5, 2021 by Zonargx 1 Quote Link to comment
Zonargx Posted May 9, 2021 Author Report Share Posted May 9, 2021 (edited) sorry I’ve been busy I’ll post some pics and videos on the truck I timed it and made sure the tps and maf are good. I currently have one week injector I’ll be replacing soon Edited May 9, 2021 by Zonargx 1 Quote Link to comment
