mainer311 Posted March 21, 2022 Report Share Posted March 21, 2022 Drew, what did you ever end up with for an alternator? My remanufactured Remy is shitting the bed already. I'm considering rebuilding it myself. I wish I could find something new to replace it with. KA24E maybe? Quote Link to comment
d.p Posted March 21, 2022 Author Report Share Posted March 21, 2022 That same Remy that you have. I don’t even want to consider an alternative with all the shit I went through with the 200SX ones. If it shits the bed I’ll just buy another of the same. Quote Link to comment
mainer311 Posted March 21, 2022 Report Share Posted March 21, 2022 Rock auto sells decent brand bearings for it, but then I have to rip the whole thing apart. I’m considering a new alternator for a late 90’s D21 and then just doing the VR bypass. These remanned alternators are just complete trash. Quote Link to comment
d.p Posted March 21, 2022 Author Report Share Posted March 21, 2022 7 minutes ago, mainer311 said: Rock auto sells decent brand bearings for it, but then I have to rip the whole thing apart. I’m considering a new alternator for a late 90’s D21 and then just doing the VR bypass. These remanned alternators are just complete trash. Let me know what you do and how it fits. My biggest complaint is finding one that truly fits in that tight as space. I’ve seen some people mention moving it to the drivers side where there’s a lot more room but never actually seen it done. Quote Link to comment
datzenmike Posted March 22, 2022 Report Share Posted March 22, 2022 Snapped my block mounting bolts of my '71, that was is '76? A friend relocated it to the distributor side. So it has been done and it does work. Likely the earliest example of it too. The KA alternator is pretty big and going to be a tight fit. Good choice on the D21 alternator it still has the V pulley. The bad is it's only 70 amp still twice what the 521 has. Quote Link to comment
d.p Posted March 23, 2022 Author Report Share Posted March 23, 2022 Alright got the group 25 AGM battery which still weighs 50lbs. Fine with the weight but still need to figure how to tie it down because the aluminum tie down I bought isn't long enough to go sideways. Also got this trick threaded funnel from Kyusha Speed in Australia: 2 Quote Link to comment
d.p Posted March 23, 2022 Author Report Share Posted March 23, 2022 I ordered this: https://www.etrailer.com/Accessories-and-Parts/Deka/DW06159.html Which should fit like a glove in the stock battery tray location. 1 Quote Link to comment
Stoffregen Motorsports Posted March 23, 2022 Report Share Posted March 23, 2022 That funnel is way cool. I sometimes stick a small clear hose down the funnel when filling, but what a great idea to build it into the funnel. That battery hold down should work fine. But if you want something more stock looking, you're gonna have to make it. Quote Link to comment
thisismatt Posted March 23, 2022 Report Share Posted March 23, 2022 You said you got a group 25 but bought a group 24 tie down? Quote Link to comment
d.p Posted March 23, 2022 Author Report Share Posted March 23, 2022 1 hour ago, thisismatt said: You said you got a group 25 but bought a group 24 tie down? Say what now? I just need a way to attach the j hooks to the tie down I bought which is too short to go lengthwise. And although that tray says group 24 its measurements are perfect for the stock 521 battery location. So I will use that group 24 tray, my group 25 battery and my group whatever tie down then go bang your mom. Quote Link to comment
thisismatt Posted March 23, 2022 Report Share Posted March 23, 2022 33 minutes ago, d.p said: Say what now? I just need a way to attach the j hooks to the tie down I bought which is too short to go lengthwise. And although that tray says group 24 its measurements are perfect for the stock 521 battery location. So I will use that group 24 tray, my group 25 battery and my group whatever tie down then go bang your mom. My mom is old Quote Link to comment
d.p Posted March 27, 2022 Author Report Share Posted March 27, 2022 Well I got the tray, cut the tabs off the sides and then zip tie'd to the stock battery frame for now. Will bolt/weld it in at some point in the future I guess but for now seems to be ok. 1 Quote Link to comment
d.p Posted March 27, 2022 Author Report Share Posted March 27, 2022 Oh I also cut the J part of the J hooks short as they were protruding into the battery. Quote Link to comment
thisismatt Posted March 27, 2022 Report Share Posted March 27, 2022 The J hooks usually point/hook away from the battery. I thought that frame was for the top...? Quote Link to comment
d.p Posted March 27, 2022 Author Report Share Posted March 27, 2022 1 minute ago, thisismatt said: The J hooks usually point/hook away from the battery. I thought that frame was for the top...? Maybe? I don't see how it would work on top because there is no holes on the front/back of the stock battery tray, only the sides. This tray is tight against the battery and tight against the fender side so the j hooks would either protrude into the battery or the fender on that side. I could switch it on the drivers side but for the most part this all works. Quote Link to comment
thisismatt Posted March 27, 2022 Report Share Posted March 27, 2022 4 minutes ago, d.p said: Maybe? I don't see how it would work on top because there is no holes on the front/back of the stock battery tray, only the sides. This tray is tight against the battery and tight against the fender side so the j hooks would either protrude into the battery or the fender on that side. I could switch it on the drivers side but for the most part this all works. J hooks through the looped metal you took off the hold down ends, through the holes in the stock diagonal supports? Quote Link to comment
d.p Posted March 27, 2022 Author Report Share Posted March 27, 2022 Just now, thisismatt said: J hooks through the looped metal you took off the hold down ends, through the holes in the stock diagonal supports? yes if I had a tie down wide enough to reach lengthwise across the battery which I don’t. Quote Link to comment
thisismatt Posted March 27, 2022 Report Share Posted March 27, 2022 18 minutes ago, d.p said: yes if I had a tie down wide enough to reach lengthwise across the battery which I don’t. The thing you bought is for going around the top... 1 Quote Link to comment
d.p Posted April 8, 2022 Author Report Share Posted April 8, 2022 Lost a bolt to my front brake caliper and cussed the caliper to float and make contact with the inner part of the wheel. Got another bolt but it appears the bracket got bent or stretched and now the caliper holes don’t line up with the bracket. Zip tied the caliper to the strut just to get home. Beebani’s doesn’t have another one and isn’t setup to make any so I am not sure what I am going to do. Guess my only option is try to massage it back into place but not sure how I feel about that. I’ve got to do something as the truck is DOA until I fix it. Quote Link to comment
d.p Posted April 8, 2022 Author Report Share Posted April 8, 2022 Roadside fix. Lucky some passerby gave me a ride home so I could get some tools and bush fix it home. 1 Quote Link to comment
d.p Posted April 8, 2022 Author Report Share Posted April 8, 2022 Oh and a flywheel bolt is the same thread and pitch as those caliper bolts if you’re ever in a pinch. Quote Link to comment
thisismatt Posted April 8, 2022 Report Share Posted April 8, 2022 Beebani has such great support! Quote Link to comment
wayno Posted April 9, 2022 Report Share Posted April 9, 2022 I actually have a set of his brackets that were made wrong(clocked wrong), that they even exist is a shame, if I had made them wrong I would have made good ones and replaced them myself, but that guy did not do that, I guess he chose to ignore they existed. Quote Link to comment
gene knight Posted April 9, 2022 Report Share Posted April 9, 2022 beebani sells crap Quote Link to comment
