wayno Posted February 10, 2022 Report Share Posted February 10, 2022 I would wedge it between two sawhorses and pour some gas in it while turning the pinion flange, squirt some in the carrier bearings also, squirt more on the ring gear and pinion gear, when the squirt bottle ran out I would fill it up again and do it again, by that time the pinion gear will be submerged, once I thought everything was clean enough I would dump it all into a bucket and blow it out with air, then if what Mike said is safe for the front seal put the ATF in there and spin the pinion flange some more, soak everything, pour it out and let it dry and it should be ready to go. I might get overzealous about how I describe things sometimes, I just don't want d.p putting it in dirty, I believe this dropout was in the 720 diesel when it had the SD22 in it, I changed it out when I found 3.3 gears for it. Quote Link to comment
Stoffregen Motorsports Posted February 10, 2022 Report Share Posted February 10, 2022 17 hours ago, mainer311 said: I had the same idea, but if the dust is stuck in those rollers and caked with old gear oil, well, who knows. Soak it in solvent (or gas if you like) and then clean it out with a brush and rinse it again. New solvent will eat even the worst of gunk. Do not replace the pinion bearings if they are not bad. There are too many pitfalls. How to tell if they are bad without tearing into it? Sound and feel. A clean diff with a light oiling on the bearings will sounds like wind. It whirrs when you spin it. If there are any clicking or grinding sounds, something is off. If you do have to replace bearings, check the gear lash before disassembly (should be about .006", but not more than .010"). And check the pattern on the ring gear with marking paint too. If the pattern changes on a used r&p set, there will be problems. Also, I always try to re-use the original pinion shim (between the bearing and pinion gear). 90% of the time, the original shim works fine, but if it isn't right, at least it should be close enough to get you in the ballpark for making adjustments. Basically, for someone who hasn't done it before, it's a pain in the ass to re-set-up an old diff, so if the pinion bearings aren't bad, keep them. Replacing the side bearings is easy though, especially if the diff has adjustable side bearing retainers. If they are shim type, it gets a little more complicated, but is still a walk in the park compared to replacing pinion bearings. Quote Link to comment
mainer311 Posted February 10, 2022 Report Share Posted February 10, 2022 Yeah, your method of checking bearings only works if the bearings are completely toast. Even moderate spalling can’t be felt at low rotation speeds. Especially when the pinion bearings are preloaded up and you’re spinning a 20lb carrier. Quote Link to comment
Stoffregen Motorsports Posted February 10, 2022 Report Share Posted February 10, 2022 Not at all. This method works great. And you're not spinning the gears from the pinion side, your grabbing hold of the ring gear and spinning it from there. Done it probably a hundred times this way. A used diff has a ton less preload than a brand new setup. Quote Link to comment
Stoffregen Motorsports Posted February 10, 2022 Report Share Posted February 10, 2022 If you must have a visual inspection, it only takes a minute to tear it apart. But don't forget to check the pattern and gear lash first. Quote Link to comment
mainer311 Posted February 10, 2022 Report Share Posted February 10, 2022 I agree though. If you’ve never dealt with a diff rebuild, you must learn the ins and outs of how to do it properly or else it’s not going to last very long. Quote Link to comment
d.p Posted February 15, 2022 Author Report Share Posted February 15, 2022 On 2/10/2022 at 4:06 PM, mainer311 said: I agree though. If you’ve never dealt with a diff rebuild, you must learn the ins and outs of how to do it properly or else it’s not going to last very long. Got to last long with how little I have been driving this fucker. Last time I got gas on October 1st. 1 Quote Link to comment
mainer311 Posted February 15, 2022 Report Share Posted February 15, 2022 All it takes is one trip down the freeway. 1 Quote Link to comment
d.p Posted February 17, 2022 Author Report Share Posted February 17, 2022 Alright so going to gas his baby up then ATF probably tomorrow since the weather is supposed to be nice. I will say that @wayno packed this baby so nice and tight. A man after my own heart with those packing skills. 1 Quote Link to comment
thisismatt Posted February 17, 2022 Report Share Posted February 17, 2022 Free bandsaw blade and T1-11?! F yes. Quote Link to comment
mainer311 Posted February 17, 2022 Report Share Posted February 17, 2022 (edited) Man, Wayno sure is crafty. But after seeing that, no way I wouldn't rebuild the whole thing. Won't hurt to give it the solvent treatment and see how good it comes out. Edited February 17, 2022 by mainer311 Quote Link to comment
d.p Posted February 17, 2022 Author Report Share Posted February 17, 2022 Called a local trans shop and going to take it over there tomorrow and see if they can give a once over. Save me the trouble. Quote Link to comment
wayno Posted February 18, 2022 Report Share Posted February 18, 2022 Just to be clear, I say that is a good gearset that just needs cleaned out. If you take it to a shop and they say it needs rebuilt I call them liars, it came out of my 720 and it was fine, it is just dirty from dust. The way shops work is if they work on them they need to give some kind of guarantee, they will not work on them unless they rebuild them, that is up to you, but I say that it is good, from the response on this thread from others I will not be selling anymore here on Ratsun, this is nonsense. Quote Link to comment
d.p Posted February 18, 2022 Author Report Share Posted February 18, 2022 (edited) Come on my man don’t take what anyone here says seriously. I doused it in gasoline just a little while ago and will shoot some air through it and hen ATF and let it dry. Spinning the gears isn’t quite, slight noise but nothing major. But never having spun a diff before I really don’t know what is normal and what isn’t. All I was going to have them do was clean it but if they say the bearings need to be replaced then so be it. I won’t hold it against you my dude. You did me a huge solid and I won’t soon forget it. Edited February 18, 2022 by d.p Quote Link to comment
thisismatt Posted February 18, 2022 Report Share Posted February 18, 2022 Wayno, I don't think anyone is disparaging you, just that the diff needs to be cleaned, and sometimes that's easier said than done without pulling things apart... 1 Quote Link to comment
d.p Posted February 18, 2022 Author Report Share Posted February 18, 2022 (edited) Fuck so washed it out gas, spun the gears, compressed air’d the shit out of it then dumped ATF in. Fucker spun nice, smooth and quietly. Cleaned up really well too and the gears look brand new. Tried to get a pick but it’s soaked in oil and draining in a bucket so I’ll snap one tomorrow morning. Edited February 18, 2022 by d.p 2 Quote Link to comment
mainer311 Posted February 18, 2022 Report Share Posted February 18, 2022 1 hour ago, wayno said: The way shops work is if they work on them they need to give some kind of guarantee, they will not work on them unless they rebuild them, that is up to you, but I say that it is good, from the response on this thread from others I will not be selling anymore here on Ratsun, this is nonsense. Wayno, there’s nothing wrong with the diff. I’m coming from the perspective that there might be some dirt in the bearings that I couldn’t get out, and therefore (if it were mine) I would replace the bearings for peace of mind. Quote Link to comment
d.p Posted February 18, 2022 Author Report Share Posted February 18, 2022 Here she is all cleaned up...not even going to bother taking it to a shop. Going to just throw it on and run with it. 1 1 Quote Link to comment
mainer311 Posted February 18, 2022 Report Share Posted February 18, 2022 Looks good to me. Flog it. 1 Quote Link to comment
Stoffregen Motorsports Posted February 19, 2022 Report Share Posted February 19, 2022 That pitting on the drive side of the ring gear may turn into a noise eventually, but it still looks good. You can tell visually because there would be a sort of smearing of metal if the wipe area were noisy or worn out. Quote Link to comment
d.p Posted February 19, 2022 Author Report Share Posted February 19, 2022 13 minutes ago, Stoffregen Motorsports said: That pitting on the drive side of the ring gear may turn into a noise eventually, but it still looks good. You can tell visually because there would be a sort of smearing of metal if the wipe area were noisy or worn out. Only a little bit of pitting on that one section. Pumped to get it installed and see what kind of difference it makes. What kind of oil should I be putting in the diff? Sta-lube? Same shit I have in my trans? Quote Link to comment
mainer311 Posted February 19, 2022 Report Share Posted February 19, 2022 Synthetic GL-5 in the diff is fine. 75W-90 1 Quote Link to comment
datzenmike Posted February 19, 2022 Report Share Posted February 19, 2022 1 hour ago, Stoffregen Motorsports said: That pitting on the drive side of the ring gear may turn into a noise eventually, but it still looks good. You can tell visually because there would be a sort of smearing of metal if the wipe area were noisy or worn out. Pitting will hold the oil better!!!! 1 Quote Link to comment
d.p Posted February 19, 2022 Author Report Share Posted February 19, 2022 One other question I have, would it make sense to throw an LSD into this thing while its out? https://www.tractionconcepts.com/Datsun-521-Limited-Slip-Truck-H190-Diff-Lsd-Kit-p/tcxda5512.htm For $350 I might as well no? Quote Link to comment
NC85ST Posted February 19, 2022 Report Share Posted February 19, 2022 Install that gear as is and make sure that’s what you’re looking for as far as your gearing. If it is then install the LSD because it’s not that hard to pull the gear back out. If it’s not the gear you want and you have the LSD installed, then you’ve spent a lot of money and it’s still not geared right. Quote Link to comment
