d.p Posted April 9, 2022 Author Report Share Posted April 9, 2022 Well I got it lined up by massaging the bracket albeit probably not ideal but at least I can drive it now. What I do from here I don’t know. I have hubs for Mikes kit but I know my rotors won’t work and not sure my calipers will either. Quote Link to comment
mainer311 Posted April 9, 2022 Report Share Posted April 9, 2022 (edited) Do you have Mike's aluminum brackets? I don't think he's making anymore. Only other option is that Wilwood kit from Silvermine motors, but it's $855! They also claim you need a 16" wheel, which is bunk. Edited April 9, 2022 by mainer311 Quote Link to comment
d.p Posted April 9, 2022 Author Report Share Posted April 9, 2022 Doesn’t that silver mine kit require 16” wheels? And mikes kit is still on his website but I don’t know if he still has sone left or what. I asked him. Quote Link to comment
thisismatt Posted April 9, 2022 Report Share Posted April 9, 2022 (edited) I like that nyloc that isn't engaged Edited April 9, 2022 by thisismatt Quote Link to comment
mainer311 Posted April 9, 2022 Report Share Posted April 9, 2022 43 minutes ago, thisismatt said: I like that nyloc that isn't engaged It's DP, what did you expect? 1 Quote Link to comment
d.p Posted April 9, 2022 Author Report Share Posted April 9, 2022 Man STFU that bolt is backed out because I took the picture once I got it lined up. I still had to go and buy more washers and a shorter bolt and brake fluid to bleed the fronts. Quote Link to comment
d.p Posted April 9, 2022 Author Report Share Posted April 9, 2022 And eat some waffles for breakfast. Quote Link to comment
thisismatt Posted April 9, 2022 Report Share Posted April 9, 2022 2 hours ago, mainer311 said: It's DP, what did you expect? Occasional progress whose kinks eventually get ironed out; more than I get done 😅 Quote Link to comment
d.p Posted April 9, 2022 Author Report Share Posted April 9, 2022 Truck is all back together losers. Drove it around and brakes are working just fine. Now I will wait for the next thing to break. Quote Link to comment
d.p Posted April 9, 2022 Author Report Share Posted April 9, 2022 Still looks good broken down on the side of the road. Quote Link to comment
d.p Posted April 9, 2022 Author Report Share Posted April 9, 2022 Also was putting it to good use when it shit the bed. Quote Link to comment
mainer311 Posted April 9, 2022 Report Share Posted April 9, 2022 Fixed it right in the middle of the road? Ballsy. Quote Link to comment
d.p Posted April 10, 2022 Author Report Share Posted April 10, 2022 2 hours ago, mainer311 said: Fixed it right in the middle of the road? Ballsy. Was in a turn lane into a park and my M3 was parked right behind my truck (after a Good Samaritan gave my wife and I a ride home). Luckily we were less than 5 minutes away from our house. I will say this truck has never left me stranded far from home, stranded but not far. Quote Link to comment
d.p Posted April 10, 2022 Author Report Share Posted April 10, 2022 Oh and Mike still makes thr 521 disc brake kits but only to order. Quote Link to comment
mainer311 Posted April 10, 2022 Report Share Posted April 10, 2022 Interesting. He always did make a better product. Quote Link to comment
d.p Posted April 10, 2022 Author Report Share Posted April 10, 2022 11 hours ago, mainer311 said: Interesting. He always did make a better product. He said his kit extends the wheels out 5/8". Quote Link to comment
d.p Posted April 13, 2022 Author Report Share Posted April 13, 2022 Anyone seen this oil spray bar setups? https://www.dpracing.co/engine?fbclid=IwAR2QE5HLlAZ2mlPyD4IuzVnMOl1wDq0M7Lf4kcaZTsAxEj0Osk8RI9omYiE Quote Link to comment
datzenmike Posted April 14, 2022 Report Share Posted April 14, 2022 Uses a T and external supply line. Have to drill hole in valve cover. The Z car till half way through the '77 model year used a spray bar that can be shortened for use on a 4 cylinder. You'll also need two of the cam towers that are drilled for the oil supply. Jan '77 and on 280x and all 280zx used a hollow cam that is pressurized with oil and holes drilled into the cam lobes for oil to the rockers. This all said... do you really need one as the cam self oils itself now anyway???? Perhaps if full race where the engine never ran below 7,000 and had insanely stiff springs for the insanely high lift cam. L4 aren't known for cam failures. Definitely use a KA oil pump to make up for the pressure loss from all the openings. Your oil pressure gauge will read lower because of the pressure drop caused but the extra oil being dumped on the lobes with that external hose attached right beside the sender. All that oil fog under the valve cover.... can't help wondering if you'll have more oil blowing out the valve cover vent hose. An oil cooler, also not really needed, would be more useful than a spray bar. Quote Link to comment
mrbigtanker Posted April 14, 2022 Report Share Posted April 14, 2022 1 hour ago, d.p said: Anyone seen this oil spray bar setups? https://www.dpracing.co/engine?fbclid=IwAR2QE5HLlAZ2mlPyD4IuzVnMOl1wDq0M7Lf4kcaZTsAxEj0Osk8RI9omYiE So its a cool setup as I have one now with my Robello stroker as he installs them when built. That guy DP racing is down the street from me or about 25 mlies away. Unless racing I was advised not to run an oil cooler as I thought that would be a good idea as these fuckin L series engines run a little hot if you ask me. Quote Link to comment
d.p Posted April 14, 2022 Author Report Share Posted April 14, 2022 Alright I’ll pass on it. Just always looking for cool things to do with this fucker. Quote Link to comment
datzenmike Posted April 14, 2022 Report Share Posted April 14, 2022 I got the oil cooler set up from a 280zx automatic. Ran high pressure hoses out front of the radiator and used a cooler from a Ford 350 Diesel? Only once the oil temp on the hottest day just touched 90C. That's only 194 F and barely above the coolant temperature. Runs in the 70s so I would say probably not needed but I will join the ends of the hoses and try it without the cooler to see what is normal for an L20B. I thought oil temperatures were 220 or something.... maybe they are and this is how much they do cool. Another source said that oil lubricates best when hot, not overly hot, but 'hot'. Another thing... it takes a long long long time to warm the oil up. Over half an hour close to 45 min before it stops going up. Ten minutes for the coolant in the summer. Quote Link to comment
d.p Posted April 14, 2022 Author Report Share Posted April 14, 2022 I see some dudes with oil coolers mounted on the front of the truck and I think that’s a bit much. Besides I don’t have an oil temp gauge and I would absolutely have to add one to compliment it. Quote Link to comment
datzenmike Posted April 14, 2022 Report Share Posted April 14, 2022 A turbo or SC or some other big power adder that makes more heat, sure. Oil coolers on the front were a fad 10-15 years ago like rising sun hoods. Quote Link to comment
thisismatt Posted April 14, 2022 Report Share Posted April 14, 2022 9 hours ago, datzenmike said: A turbo or SC or some other big power adder that makes more heat, sure. Oil coolers on the front were a fad 10-15 years ago like rising sun hoods. No, I mean slap on a turbo as the next thing 1 Quote Link to comment
