mainer311 Posted May 10, 2022 Report Share Posted May 10, 2022 Nice. I need to get around to doing this. I installed NOS rear leaf bushings this winter on one side, and still haven't even gotten to the other side yet. Quote Link to comment
thisismatt Posted May 10, 2022 Report Share Posted May 10, 2022 Doesn't seem like much grease, but I haven't done these before so I could be wrong 😄 Quote Link to comment
d.p Posted May 11, 2022 Author Report Share Posted May 11, 2022 1 hour ago, thisismatt said: Doesn't seem like much grease, but I haven't done these before so I could be wrong 😄 You and me both. Quote Link to comment
d.p Posted May 13, 2022 Author Report Share Posted May 13, 2022 Making progress. just need to make a couple hard lines, hook up the parking brake and bleed these fuckers. 2 Quote Link to comment
mainer311 Posted May 14, 2022 Report Share Posted May 14, 2022 It’s nice to see that your balls finally descended. 1 1 1 Quote Link to comment
gene knight Posted May 14, 2022 Report Share Posted May 14, 2022 4 hours ago, d.p said: Making progress. just need to make a couple hard lines, hook up the parking brake and bleed these fuckers. d.p : where did you get the rear disc brake setup? Quote Link to comment
d.p Posted May 14, 2022 Author Report Share Posted May 14, 2022 (edited) This man: https://www.facebook.com/kielbasavw lol to my balls descending. They are so low they hit my knees…..oh wait that’s my dong. Edited May 14, 2022 by d.p 1 Quote Link to comment
thisismatt Posted May 14, 2022 Report Share Posted May 14, 2022 Is that like "Kyle" or KeyL? Did someone say dong? Quote Link to comment
Crashtd420 Posted May 14, 2022 Report Share Posted May 14, 2022 (edited) 14 hours ago, d.p said: Making progress. just need to make a couple hard lines, hook up the parking brake and bleed these fuckers. Cant tell from the picture are the calipers facing front or back? What side of the truck is this? Edited May 14, 2022 by Crashtd420 Quote Link to comment
Crashtd420 Posted May 14, 2022 Report Share Posted May 14, 2022 Oh one other question... Did you do anything with the master cylinder? If the master was setup for front disc rear drums you need to swap the residual valve out.... Or remove it and you can add one inline on the brake line.... Discs are only 2lbs Drums are 10lb valves.. 1 Quote Link to comment
d.p Posted May 14, 2022 Author Report Share Posted May 14, 2022 Back and that is the passenger side. What is and where can I get a new residual valve? And what happens if I don’t do anything with it? One half of the parking brake mount because this stupid website complains about file size so much. 1 Quote Link to comment
Crashtd420 Posted May 14, 2022 Report Share Posted May 14, 2022 1 hour ago, d.p said: Back and that is the passenger side. What is and where can I get a new residual valve? And what happens if I don’t do anything with it? One half of the parking brake mount because this stupid website complains about file size so much. I think if you do nothing it's just keeps extra pressure on the pads... I'm guessing premature pad wear... I dont know if you can buy a replacement valve for the master or if you just need to get it from another master cylinder... I used an inline one from Amazon... I think stroffgren said it doesnt matter where you put it .. basically just need to be after the master but before the tee that splits the rear... 1 Quote Link to comment
Crashtd420 Posted May 14, 2022 Report Share Posted May 14, 2022 Wilwood Engineering 260-13783 Residual with Fittings (2Lb), Blue https://www.amazon.com/dp/B01GVIM8G8/ref=cm_sw_r_cp_apan_i_D9D1M03A27PM1XX47M5S 1 Quote Link to comment
d.p Posted May 14, 2022 Author Report Share Posted May 14, 2022 I just bought that one. Do I have to remove the one in there now? 1 Quote Link to comment
Stoffregen Motorsports Posted May 14, 2022 Report Share Posted May 14, 2022 26 minutes ago, d.p said: I just bought that one. Do I have to remove the one in there now? Yes. It should be inside the outlet port on the MC. Usually a small pick will get it out. It can be black or white plastic, or sometimes black rubber. Quote Link to comment
Stoffregen Motorsports Posted May 14, 2022 Report Share Posted May 14, 2022 Google "residual valve inside master cylinder" and look at the pics. It can be in various places. Quote Link to comment
d.p Posted May 14, 2022 Author Report Share Posted May 14, 2022 Assuming I would just need to take the one out for the rear reservoir or does a single valve serve the front and back? Quote Link to comment
d.p Posted May 14, 2022 Author Report Share Posted May 14, 2022 Brakes all done except for that valve. Had to extend the parking brake cleavis way out so I could attach them on both sides. In the end not so bad except for the axels which cost me $125. I think all in it was around $500 give or take for everything. More with the flaring tool and brake line straightener but those don’t count. 3 Quote Link to comment
mainer311 Posted May 14, 2022 Report Share Posted May 14, 2022 The dual-res masters have a residual valve in each outlet. In our case, the front is setup for disc, while the rear is setup for drum. The drum valve needs to be removed, and replaced with the one Neil sent. 1 Quote Link to comment
d.p Posted May 14, 2022 Author Report Share Posted May 14, 2022 6 hours ago, Stoffregen Motorsports said: Yes. It should be inside the outlet port on the MC. Usually a small pick will get it out. It can be black or white plastic, or sometimes black rubber. outlet port that goes to the rear brakes? Meaning where the hard line terminates on the MC? Quote Link to comment
datzenmike Posted May 14, 2022 Report Share Posted May 14, 2022 Disc brake residual valves need about 1/6 the pressure (2 lb.) vs. a drum brake (12 lb.)so it will be like driving around with foot resting on the brake. They are going to get HOT. If this is a Datsun/Nissan master cylinder just ask around for the front residual valve from a spare that someone has. BTW the front circuit is at the rear of the master, rear is at the front. I did this with my 4 wheel disc 15/16" zx master. Put my '76 rear drum residual into it for my rear drums. Don't mix them up impossible to tell which is which... 1 Quote Link to comment
d.p Posted May 15, 2022 Author Report Share Posted May 15, 2022 Thanks @datzenmike the rear reservoir outlet is on the front of my master. I thought I could get the valve out with the master in the truck but it’s tough trying to break that huge nut loose with the column right there. Guess I’ll just have to pull it tomorrow. Quote Link to comment
d.p Posted May 15, 2022 Author Report Share Posted May 15, 2022 (edited) Oh what do I remove in that pic? Jus the spring and smaller black piece? And if I don’t have any residual valve in that would that be bad? Meaning I remove the 10lb fucker and don’t out 2lb back in or inline somewhere? Edited May 15, 2022 by d.p Quote Link to comment
d.p Posted May 15, 2022 Author Report Share Posted May 15, 2022 I read this as well .. ”Disk brakes must not use a Residual Valve, but only need a weak pressure which naturally results from the M/C being mounted high on the firewall. However, some all-disc Master Cylinder use a low-pressue check valve, so check the application.” also says “If the RV is left in place, the brakes will still work OK, but will wear faster than normal.” So do I really need any RPV as our masters are high enough up? http://datsun1200.com/modules/mediawiki/index.php?title=Residual_Valve Quote Link to comment
datzenmike Posted May 15, 2022 Report Share Posted May 15, 2022 I looked back about 4 pages but missed what master you are using so assumed Nissan. Well Nissan saw fit to use a residual valve even on disc brake vehicles. That 2 PSI keeps the pads against the rotor just enough to keep it clean yet produce negligible drag. It it were water, you would need a vertical column 4.6 feet high to get 2 PSI at the bottom. Now brake fluid is lighter than water so it would be even higher. I would run the disc brake residual valve. 1 Quote Link to comment
