d.p Posted February 7, 2021 Author Report Share Posted February 7, 2021 35 minutes ago, mainer311 said: Stutter might as well have. @Charlie69acting like I or someone caved in the firewall on purpose? 1 Quote Link to comment
john510 Posted February 7, 2021 Report Share Posted February 7, 2021 11 hours ago, d.p said: Duck it then I’ll just use what I got as it’s not charcoal and both sides?? Yes,several light coats. 1 1 Quote Link to comment
Stoffregen Motorsports Posted February 7, 2021 Report Share Posted February 7, 2021 I don't like those gaskets with the siamesed middle exhaust ports, but it's super hard to find one that has them separated these days. The Remflex gaskets look good, but are super thick and I wonder if this could lead to manifold warpage or cracking. 1 Quote Link to comment
d.p Posted February 7, 2021 Author Report Share Posted February 7, 2021 I switched to the cardboard + copper spray and put that one to bed. I then had to the beat the shit out of my exhaust to get it to clear the trans and torsion bar but it still doesn't mate to the rear section. I think at this point I am just going to have to leave it and take it to an exhaust shop once its running. But when doing all this I noticed a fairly large puddle under my truck right under the slave and brake tee but I couldn't figure out where it was coming from. There was liquid up on the firewall and behind the head so whatever leaked had enough pressure to get that high up. There is only brake fluid in the truck and the only thing I did was top off the rear master cylinder reservoir. Neither of the 2 brake reservoirs or the clutch reservoir were empty so I really don't know what happened. Both the clutch and the brake pedal still have pressure so at a loss as to where it came from. 1 Quote Link to comment
mainer311 Posted February 7, 2021 Report Share Posted February 7, 2021 2 hours ago, Stoffregen Motorsports said: I don't like those gaskets with the siamesed middle exhaust ports, but it's super hard to find one that has them separated these days. The Remflex gaskets look good, but are super thick and I wonder if this could lead to manifold warpage or cracking. It takes very little to crush the gasket. It’s layered graphite. The whole point of their gasket is that is seals off imperfections better than other gaskets. Neil and I run them and have had good luck with them. 2 Quote Link to comment
Charlie69 Posted February 8, 2021 Report Share Posted February 8, 2021 On 2/6/2021 at 3:07 PM, d.p said: 2 lone hoses... Remove the valve and use the tank line as a fuel return line this helps keep fuel temp down and helps to avoid vapor locking. 1 Quote Link to comment
Charlie69 Posted February 8, 2021 Report Share Posted February 8, 2021 (edited) 22 hours ago, mainer311 said: Stutter Stutter is Northern Studder is southern. Spell check likes either. Straighten your firewall. Edited February 8, 2021 by Charlie69 Quote Link to comment
d.p Posted February 13, 2021 Author Report Share Posted February 13, 2021 (edited) Making progress on the mfer. Just need to mount the alternator, oil pump, battery and make some spark plug cables. I also need to figure out what I am going to do about my exhaust but will probably have it towed to an exhaust shop and have them figure it out. Edited February 13, 2021 by d.p 1 Quote Link to comment
d.p Posted February 13, 2021 Author Report Share Posted February 13, 2021 Oh and does anyone know what thread and pitch a KOYO radiator has for a temperature sender? It’s not 1/8 NPT I know that. 1 Quote Link to comment
datzenmike Posted February 13, 2021 Report Share Posted February 13, 2021 You mean the temperature sensor for the electric fans? 1 Quote Link to comment
MikeRL411 Posted February 13, 2021 Report Share Posted February 13, 2021 On 2/7/2021 at 9:45 AM, Stoffregen Motorsports said: I don't like those gaskets with the siamesed middle exhaust ports, but it's super hard to find one that has them separated these days. The Remflex gaskets look good, but are super thick and I wonder if this could lead to manifold warpage or cracking. I have the same problem with the R1600 engine in my RL411 [ and will also apply to the 1600 roadsters ] so I got some good gasket material. cut a patch and fixed it in place with a dab of muffler sealant, The open exhaust hole of the gasket fits around the patch and works well. 2 Quote Link to comment
d.p Posted February 13, 2021 Author Report Share Posted February 13, 2021 1 minute ago, datzenmike said: You mean the temperature sensor for the electric fans? Autometer water temp gauge but guess I don’t really need it if the stock one works? Can you even use both? Or can I tee of the stock wire to an aftermarket guage? 1 Quote Link to comment
datzenmike Posted February 13, 2021 Report Share Posted February 13, 2021 Reading temperature of the rad is... meaningless. You want something inside the engine. Some thermostat housings have multiple threaded holes for sensors or senders. 280z/zx do. 1 Quote Link to comment
d.p Posted February 13, 2021 Author Report Share Posted February 13, 2021 4 minutes ago, datzenmike said: Reading temperature of the rad is... meaningless. You want something inside the engine. Some thermostat housings have multiple threaded holes for sensors or senders. 280z/zx do. Goddamn it I have the two threaded lower t-stat housing that I took off to install the single threaded housing because I didn’t think I needed two threaded holes. fuck me. 1 Quote Link to comment
d.p Posted February 14, 2021 Author Report Share Posted February 14, 2021 Anyone know the thread and pitch of the second threaded hole on these housings? It’s the one facing away from the block towards the drivers side fender. Circled in red below is the one I am trying to figure out as the other bigger one accepts the standard adapter and sender. 1 Quote Link to comment
datzenmike Posted February 14, 2021 Report Share Posted February 14, 2021 It's fir the L20B TVV if that helps. I plugged mine with a bung from a KA intake... 1 Quote Link to comment
d.p Posted February 14, 2021 Author Report Share Posted February 14, 2021 What is TVV? 1 Quote Link to comment
datzenmike Posted February 14, 2021 Report Share Posted February 14, 2021 Thermal vacuum valve. When cold it is open, bleeding off the vacuum advance and ERG vacuum signal. When warmed with engine heat the wax inside melts and blocks the leak and vacuum advance and EGR are allowed. 1 Quote Link to comment
Crashtd420 Posted February 14, 2021 Report Share Posted February 14, 2021 13 hours ago, d.p said: Anyone know the thread and pitch of the second threaded hole on these housings? It’s the one facing away from the block towards the drivers side fender. Circled in red below is the one I am trying to figure out as the other bigger one accepts the standard adapter and sender. Probably bspt..... my guess is 1/4... 1 1 Quote Link to comment
datzenmike Posted February 14, 2021 Report Share Posted February 14, 2021 Amazon has thread gauges for under $10. This thread question has been asked a lot. 1 Quote Link to comment
d.p Posted February 14, 2021 Author Report Share Posted February 14, 2021 11 minutes ago, datzenmike said: Amazon has thread gauges for under $10. This thread question has been asked a lot. If everyone got their Datsun information from somewhere else what would you have to post about Mike? 1 Quote Link to comment
mainer311 Posted February 14, 2021 Report Share Posted February 14, 2021 The thread on the thermostat outlet is a special thread called DIADA. They usually come in brass. 1 1 Quote Link to comment
d.p Posted February 14, 2021 Author Report Share Posted February 14, 2021 37 minutes ago, mainer311 said: The thread on the thermostat outlet is a special thread called DIADA. They usually come in brass. Say what now? 1 Quote Link to comment
datzenmike Posted February 14, 2021 Report Share Posted February 14, 2021 Just wrap with Teflon tape. 1 1 Quote Link to comment
d.p Posted February 14, 2021 Author Report Share Posted February 14, 2021 7 hours ago, Crashtd420 said: Probably bspt..... my guess is 1/4... this man is right so I just ordered a 1/4” BSP male to 1/8” NPT female reducer. https://zcardepot.com/products/adaptor-bpt-to-npt-thread-coolant-line-240z-510 1 Quote Link to comment
