mainer311 Posted June 4, 2021 Report Share Posted June 4, 2021 (edited) I find it strange that Nismo powdercoated their slave black. https://giphy.com/gifs/homer-simpson-the-simpsons-bush-4pMX5rJ4PYAEM Edited June 4, 2021 by mainer311 1 2 Quote Link to comment
Duncan Posted June 4, 2021 Report Share Posted June 4, 2021 The truck is looking spectacular Ray. Can't wait to take a ride in it. 2 Quote Link to comment
Stoffregen Motorsports Posted June 5, 2021 Report Share Posted June 5, 2021 20 hours ago, mainer311 said: I find it strange that Nismo powdercoated their slave black. https://giphy.com/gifs/homer-simpson-the-simpsons-bush-4pMX5rJ4PYAEM A bit on the nose there. 1 Quote Link to comment
mainer311 Posted June 5, 2021 Report Share Posted June 5, 2021 2 hours ago, Stoffregen Motorsports said: A bit on the nose there. I mean no harm. 2 1 Quote Link to comment
bananahamuck Posted June 6, 2021 Report Share Posted June 6, 2021 On 6/4/2021 at 10:03 AM, Stoffregen Motorsports said: I think all of them were the same, from 240Z to 510 to 1200, 610, 710, etc. So yeah, looks like a B210. no shit ?? Really ? . 2 Quote Link to comment
Stoffregen Motorsports Posted June 7, 2021 Report Share Posted June 7, 2021 (edited) 8 hours ago, bananahamuck said: no shit ?? Really ? . Duh... Full disclosure, I was being a smartass. So calling me out is appreciated. Edited June 7, 2021 by Stoffregen Motorsports 1 Quote Link to comment
mrbigtanker Posted June 8, 2021 Author Report Share Posted June 8, 2021 Untitled by raymond medeiros, on Flickr Mocked up, who said it was not going to work ? Or to short or whatever ? 2 Quote Link to comment
Charlie69 Posted June 8, 2021 Report Share Posted June 8, 2021 (edited) You might have problems hooking up the hose once the cab is on. Not sure as I have gotten away from running 520/521 chassis. Edited June 8, 2021 by Charlie69 2 Quote Link to comment
mrbigtanker Posted June 8, 2021 Author Report Share Posted June 8, 2021 2 hours ago, Charlie69 said: You might have problems hooking up the hose once the cab is on. Not sure as I have gotten away from running 520/521 chassis. No sir easy peasy 1 Quote Link to comment
mainer311 Posted June 8, 2021 Report Share Posted June 8, 2021 Is the slave not adjustable? 1 Quote Link to comment
mrbigtanker Posted June 9, 2021 Author Report Share Posted June 9, 2021 2 hours ago, mainer311 said: Is the slave not adjustable? No 1 Quote Link to comment
Stoffregen Motorsports Posted June 9, 2021 Report Share Posted June 9, 2021 The adjustable slave has a nub on it for a return spring. And also (obviously) an adjustable rod. If there is any interference to the frame, you could always run a banjo fitting or a 45 or 90 degree hose end. Looks like there is plenty of room though. Ironically, the first time I ever realized that the trucks had a different slave cylinder was on my 320. I had a car slave on it and the hose hit the torsion bar. Instead of finding the right one, I drilled and tapped the end of the slave for the hose, and plugged the side with a welded up old hose end. It wasn't till years later that I realized I could have just installed a truck slave. 4 Quote Link to comment
mrbigtanker Posted June 11, 2021 Author Report Share Posted June 11, 2021 On 6/9/2021 at 8:52 AM, Stoffregen Motorsports said: The adjustable slave has a nub on it for a return spring. And also (obviously) an adjustable rod. If there is any interference to the frame, you could always run a banjo fitting or a 45 or 90 degree hose end. Looks like there is plenty of room though. Ironically, the first time I ever realized that the trucks had a different slave cylinder was on my 320. I had a car slave on it and the hose hit the torsion bar. Instead of finding the right one, I drilled and tapped the end of the slave for the hose, and plugged the side with a welded up old hose end. It wasn't till years later that I realized I could have just installed a truck slave. This one has a lot of throw, but there is a OS GiKen clutch set up so wish me luck. 4 Quote Link to comment
Stoffregen Motorsports Posted June 11, 2021 Report Share Posted June 11, 2021 Good luck. 2 Quote Link to comment
mrbigtanker Posted June 26, 2021 Author Report Share Posted June 26, 2021 Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr Untitled by raymond medeiros, on Flickr Perfection with this guy is top notch.All the body lines match like a Bugatti. 2 Quote Link to comment
mrbigtanker Posted June 26, 2021 Author Report Share Posted June 26, 2021 Untitled by raymond medeiros, on Flickr It was like throwing a hot dog down hallway.lol 5 2 Quote Link to comment
Draker Posted June 26, 2021 Report Share Posted June 26, 2021 Looks like you found the right guy. Not only good work... but actual progress without sitting in the corner for a year. 3 Quote Link to comment
BrothersGarage Posted June 26, 2021 Report Share Posted June 26, 2021 wow those new panel gaps 2 Quote Link to comment
Stoffregen Motorsports Posted June 26, 2021 Report Share Posted June 26, 2021 So what did he do? Looks like he cut the sides off the hood and fabbed his own? That's great, but super labor intensive. I bet he'll have ten hours into the hood alone. This is what I call "blueprinting". Making the body the size and shape that the designers intended, but the factory could not achieve. 4 Quote Link to comment
thisismatt Posted June 26, 2021 Report Share Posted June 26, 2021 1 hour ago, Stoffregen Motorsports said: So what did he do? Looks like he cut the sides off the hood and fabbed his own? That's great, but super labor intensive. I bet he'll have ten hours into the hood alone. This is what I call "blueprinting". Making the body the size and shape that the designers intended, but the factory could not achieve. Cut the whole front off, too 1 1 Quote Link to comment
datzenmike Posted June 26, 2021 Report Share Posted June 26, 2021 Should have done half the amount on both sides to center the hood ornament. 1 Quote Link to comment
thisismatt Posted June 26, 2021 Report Share Posted June 26, 2021 55 minutes ago, datzenmike said: Should have done half the amount on both sides to center the hood ornament. He clearly did both sides 🧐 1 Quote Link to comment
datzenmike Posted June 26, 2021 Report Share Posted June 26, 2021 Old eyes. That means the gap was twice as big 1 Quote Link to comment
mrbigtanker Posted June 27, 2021 Author Report Share Posted June 27, 2021 10 hours ago, Stoffregen Motorsports said: So what did he do? Looks like he cut the sides off the hood and fabbed his own? That's great, but super labor intensive. I bet he'll have ten hours into the hood alone. This is what I call "blueprinting". Making the body the size and shape that the designers intended, but the factory could not achieve. He has less time in it. 8 hours ago, thisismatt said: Cut the whole front off, too That was also done sides and front is all new 6 hours ago, datzenmike said: Should have done half the amount on both sides to center the hood ornament. You will never see a straighter truck period, and ill put money on that. 5 hours ago, datzenmike said: Old eyes. That means the gap was twice as big The gapping was big.This guy is no run of the mill fabricator, this guy is on another level that's not really achievable. Not trying to make believers its the truth. The truck is terrible from the factory period. The body is even stretched on the dolly in a hogging manner to make the lines perfect and will be mounted on the frame the same way. He has about 6 hours if that in hood, Monday it should be done and then final full cab block sand again because he is crazy, then off to paint. The key here is subtle, if you can't see the lines, like they should be then its not worth talking about the factory would never spend the time to do it right. 5 Quote Link to comment
BrothersGarage Posted June 28, 2021 Report Share Posted June 28, 2021 On 6/26/2021 at 8:19 PM, mrbigtanker said: You will never see a straighter truck period, and ill put money on that. Nah, it's abundantly clear how mint this will be, besides, I need that shit to finish my build 😄 . 1 Quote Link to comment
