mrbigtankers 521
mrbigtanker
  • Replies 7.1k
51125928127_468988fdce_4k.jpgUntitled by raymond medeiros, on Flickr
That we all mounted on a trick custom bracket mounted to the right side of engine block. All concealed below the Manifold not to be seen. By the way that is a fuel pressure sender as well, in case any one was wondering.
Also dropped off my my Blow off valve and Wastegate to TurboSmart which low and behold are right up the street from my house. Having them all prettied up.
Edited by mrbigtanker
  • Like 4
51166742973_3ac8359f31_3k.jpg by raymond medeiros, on Flickr
Fuel lines are all pre Fabbed. Will get them crimped on Monday and call the fuel system good. That thing sticking out of the regulator is a fuel pressure sending unit. Also I will change the T out to a male male to female at flex fuel sensor. The reason why I am running the line this way if you are wondering issss, I can cheat from having the return line on front side of fuel rail which I hate. This idea is the next best thing to sliced bread.
