jvb5577 Posted August 10, 2013 Report Share Posted August 10, 2013 video video video!!! Quote Link to comment
Eagle_Adam Posted August 10, 2013 Report Share Posted August 10, 2013 Vids! Now! Quote Link to comment
Zeusimo Posted August 10, 2013 Report Share Posted August 10, 2013 Where's The Vid!?? Quote Link to comment
Master-O-Turbonics Posted August 10, 2013 Report Share Posted August 10, 2013 How long until you blow up the diff? Lol Quote Link to comment
Z-train Posted August 10, 2013 Report Share Posted August 10, 2013 38/38 is BY FAR superior to the 32/36. I've got a hell of a lot more bottom end. My mid range has significantly improved. I come off of lights with tires spinning at quarter throttle. Not kidding here. Throttle response is instantaneous. The idle is PERFECT. I struggled to get the 32/36 idled properly. Sometimes it would idle high, sometimes low. It was never right. But the 38/38 bolted on and ran perfect. I could idle this thing down to 700RPM if I wanted to. But I idle at about 1000 for best quality. This is such a great feeling. I have a slight stumble transitioning into partial throttle from coasting. I had that with the old Weber too so I'm not sure if the two are related, or coincidental. I'm sure my issue lies elsewhere. Oh and the exhaust doesn't even sound the same...my neighbor walked over after I took it for a short drive to tell me it sounded like a rocketship. It's great that the 38 works. But there was/is something wrong with your 32/36.Keep working on the idle thing.I have no issues with my Weber. Quote Link to comment
datzenmike Posted August 10, 2013 Report Share Posted August 10, 2013 You should be able to run a B-210 carb with proper jetting. Carbs only mix gas and air but getting them right is the thing. Admittedly matching the proper size is important. The 32/36 should have run better and the random high idle suggests worn throttle plate shaft, but whatever, I think it had problems and should have ran much better. I definitely think the 38 is the right choice as you.... On occasion drive aggressively and this isn't a Ford Tore-Ass station wagon. Have a larger displacement motor that ... Has a larger cam and 'performance' head on it. Quote Link to comment
Farmer Joe Posted August 11, 2013 Report Share Posted August 11, 2013 very good.. i figured a 38 would do the trick. i had a 3236 on the Z24 and while it was torquey, it had no power.. the KA screams with the 38.. revs so quick, i fear i need a rev control of some sort... Quote Link to comment
Charlie69 Posted August 11, 2013 Report Share Posted August 11, 2013 The stumble/flat is jetting. one size larger should fix it Quote Link to comment
datzenmike Posted August 11, 2013 Report Share Posted August 11, 2013 the KA screams with the 38.. revs so quick, i fear i need a rev control of some sort... . Farmer I think this is because of the dual KA intake valves that give superior breathing. All it needs is a big carb to feed it. I'm hoping that the KA head I put on my 2.3 will rev out of sight the same way Quote Link to comment
metalmonkey47 Posted September 12, 2013 Author Report Share Posted September 12, 2013 Been a while since updating. Kinda bounced around a few issues since then the 38/38 has 145 jets, which seem to me to be too small. Skipped to 160 jets (had two of them sitting around) and the stumble went away, but it was running PIG RICH and flooding at idle. I went back to 145's. I can't get this thing to idle out properly. Seems like no matter what idle air adjustments I make, it ALWAYS idles rich. (Choke open and engine up to temp). It's been a bit of a bitch, but it's consistent. I'll figure it out, or I'll get side drafts.I'm ready to drop the trans again. LZ is leaking oil from the pan, don't know why, trans feels like it's falling apart inside, brakes get weaker no matter what I do, they seem to drag and not release. Fuck em, tired of playing. Buying Z32 conversion parts soon. Also ready to get rid of torsion bars. Ripped the key off TWICE in the last two weeks. Can't get the clip out that holds it in place so I just hammered it straight. I need to get a coilover setup on the front. Sad thing is that all this shit I wanna do I CAN'T do because I'm either working, (overtime doing nearly 50 hours a week ish) OR it's because I have to drive it the next day and can't afford to buy another car. Anyways, blah blah just figured this thread was due for an update. I need to get a lot done on my truck...I'm just not really enjoying it right now. Quote Link to comment
metalmonkey47 Posted September 12, 2013 Author Report Share Posted September 12, 2013 Quote Link to comment
metalmonkey47 Posted September 12, 2013 Author Report Share Posted September 12, 2013 New shift boot. Military aircraft overstock. Got it from an antique store today! 2 Quote Link to comment
metalmonkey47 Posted September 12, 2013 Author Report Share Posted September 12, 2013 2 Quote Link to comment
datzenmike Posted September 12, 2013 Report Share Posted September 12, 2013 Mmmm athletic. Quote Link to comment
metalmonkey47 Posted September 12, 2013 Author Report Share Posted September 12, 2013 Mmmm athletic. My LZ is pretty torquey Quote Link to comment
Farmer Joe Posted September 12, 2013 Report Share Posted September 12, 2013 have a pair of pliers like this? if you do, use the handle end as a tool to get the C clip off. set the ends of the handles on either inside of the clip, and then pop the other end of the pliers with a hammer... its easier than trying to hold 2 screwdrivers or some shit.. 2 Quote Link to comment
metalmonkey47 Posted September 12, 2013 Author Report Share Posted September 12, 2013 Fucking hell. You're saying just spin the clip backwards eh? I tried that, but didn't think of using pliers... I tried two flay heads, but it was hard to get em both in there and push evenly. Quote Link to comment
Farmer Joe Posted September 12, 2013 Report Share Posted September 12, 2013 yeah, i had to spin mine till the opening in the C was facing down. then i set the plier handles in the C. it would kinda look like this " C>< " from the side if that make any sense. with the pliers set in the C, then you can hit the other end of the pliers, and it should pop off. Quote Link to comment
mattyhacks71 Posted September 12, 2013 Report Share Posted September 12, 2013 New shift boot. Military aircraft overstock. Got it from an antique store today! Thats awesome Quote Link to comment
metalmonkey47 Posted October 2, 2013 Author Report Share Posted October 2, 2013 yeah, i had to spin mine till the opening in the C was facing down. then i set the plier handles in the C. it would kinda look like this " C>< " from the side if that make any sense. with the pliers set in the C, then you can hit the other end of the pliers, and it should pop off. You're awesome man! That worked so well it was scary. I fought for an hour one day, eventually gave up. Finally got around to fixing it again today and that little truck was amazing. Yeah, I broke it again. But never again thanks to the re-indexed torsion bar. Quote Link to comment
metalmonkey47 Posted October 2, 2013 Author Report Share Posted October 2, 2013 Also as you see, I've been working on cleaning up some Z car SU's from a 240Z that's going full race car. These carbs are so simple to straighten out it's crazy. Quote Link to comment
Dawa Posted October 2, 2013 Report Share Posted October 2, 2013 i had a tire shop fuck up mine.... not as bad as yours though holy shit Quote Link to comment
]2eDeYe Posted October 2, 2013 Report Share Posted October 2, 2013 You're awesome man! That worked so well it was scary. I fought for an hour one day, eventually gave up. Finally got around to fixing it again today and that little truck was amazing. Yeah, I broke it again. But never again thanks to the re-indexed torsion bar. Been there :lol: Nice vice :cool: Quote Link to comment
jvb5577 Posted October 2, 2013 Report Share Posted October 2, 2013 Also as you see, I've been working on cleaning up some Z car SU's from a 240Z that's going full race car. These carbs are so simple to straighten out it's crazy. How are you going to address the throttle linkage? Quote Link to comment
metalmonkey47 Posted October 2, 2013 Author Report Share Posted October 2, 2013 How are you going to address the throttle linkage? We'll see. Probably shorten the Z car linkage and weld it back together. Been there :lol: Nice vice :cool: Harbor freight :thumbup: i had a tire shop fuck up mine.... not as bad as yours though holy shit You should see my trans crossmember man. It's terrible. My fault though, forgot to tell the tire shop to watch that. Quote Link to comment
