Laecaon Posted November 23, 2010 Report Share Posted November 23, 2010 Keep the manual choke and tune it so the car starts with the choke on only. Someone tried to steal my car back when the PO had it. He woke up to the door open on the car. Then he saw that the ignition was knocked off the column. When he tried to start the car it barely even clicked once. The thieves tried to hotwire it, but killed the battery cuz the car wouldnt start without the choke engaged. Quote Link to comment
Skib Posted November 23, 2010 Report Share Posted November 23, 2010 Your visegrips will work on this? which hub is that? Quote Link to comment
defdes Posted November 23, 2010 Report Share Posted November 23, 2010 which hub is that? That's the Grant hub, and it has a cap that locks over that the way the steering wheel does. Quote Link to comment
MikeRL411 Posted November 24, 2010 Report Share Posted November 24, 2010 If you have an old mechanical distributor, remove the rotor from inside the distributor cap and put it in your pocket. Worked during WW@ on the Jeep! Quote Link to comment
Logical1 Posted November 24, 2010 Report Share Posted November 24, 2010 Couple things I have to prevent theft: 1. Hidden starter button: I removed the entire circuit from my key switch ignition for my starter relay and installed a under-dash push start button. 2. Keyed battery kill switch I have a hidden battery kill switch like this one that cuts power to the whole car with a removable key: Battery Switch 3. Hidden coil ground switch I also have a hidden toggle switch that un-grounds my coil. Not easy to find that the wiring has been modified. I'm not sure of everyone's law's but I heard that in Washington the person has to actually 'start' you car for them to be convicted of GTA and that alot of the muscle car guys put the kill switch on a fuel pump so they start the car and pull away only to have it die on the street. This may lead to a conviction but I'm concerned with the least possible damage to my vehicle if a theft attempt is made! If you put your kill switch on the fuel pump and the thief gets onto the road with it and it dies so he abandons it, the car is sitting in the middle of the road while I'm asleep/gone! With my set-up I'm confidant they would get frustrated/run our of time and give up :) Quote Link to comment
Zeusimo Posted November 24, 2010 Author Report Share Posted November 24, 2010 alot of the muscle car guys put the kill switch on a fuel pump so they start the car and pull away only to have it die on the street. This may lead to a conviction but I'm concerned with the least possible damage to my vehicle if a theft attempt is made! If you put your kill switch on the fuel pump and the thief gets onto the road with it and it dies so he abandons it, the car is sitting in the middle of the road while I'm asleep/gone! With my set-up I'm confidant they would get frustrated/run our of time and give up :) Good Point I Guess I Will Also Add A Coil Switch Quote Link to comment
Laecaon Posted November 24, 2010 Report Share Posted November 24, 2010 Get rid of the left shift button!!! When you need to use shift you can use the right one. Quote Link to comment
FoxyRoadster Posted November 24, 2010 Report Share Posted November 24, 2010 a brake lock is another good one, just hide the switch for it somewhere. Quote Link to comment
john510 Posted December 1, 2010 Report Share Posted December 1, 2010 I use a hidden switch for the electric fuel pump,the Club on the steering wheel and a car cover when it sits in the driveway.If you have a 2 door 510 put some sort of bailing wire on your 1/4 window latches that seems to be an easy place to pry open a window.The two times my car has been fucked with they attempted to pry open the 1/4 windows.The first time they got them open but couldnt start the car ,there was no battery in it.The second time the 1/4 windows were wired shut and all they could do was some minor dinging and scratching near the latch. Quote Link to comment
dennis Posted December 1, 2010 Report Share Posted December 1, 2010 I bought one of these a few weeks ago. I wont install it till after the SR20 gets installed http://www.kptechnologies.com/products.php#/18 Quote Link to comment
ariascarlos1990 Posted December 1, 2010 Report Share Posted December 1, 2010 Heres a good solution. http://www.taser.com/company/Pages/trivia.aspx Quote Link to comment
JustinB Posted December 22, 2010 Report Share Posted December 22, 2010 My car is so butt ass ugly no one has even ever tried to break in. I imagine they figure if I'm so broke I drive a hoopty like that that I probably don't have anything worth stealing. However, I probably ought to do something just in case. Like that tazer club but they don't sell them anymore. Quote Link to comment
paradoxx Posted December 22, 2010 Report Share Posted December 22, 2010 If you have an old mechanical distributor, remove the rotor from inside the distributor cap and put it in your pocket. Worked during WW@ on the Jeep! Sometimes, when I dont like the place I put the rotor in my pocket too haha simple, cheap and effective. Couple things I have to prevent theft: 1. Hidden starter button: I removed the entire circuit from my key switch ignition for my starter relay and installed a under-dash push start button. 2. Keyed battery kill switch I have a hidden battery kill switch like this one that cuts power to the whole car with a removable key: Battery Switch 3. Hidden coil ground switch I also have a hidden toggle switch that un-grounds my coil. Not easy to find that the wiring has been modified. I'm not sure of everyone's law's but I heard that in Washington the person has to actually 'start' you car for them to be convicted of GTA and that alot of the muscle car guys put the kill switch on a fuel pump so they start the car and pull away only to have it die on the street. This may lead to a conviction but I'm concerned with the least possible damage to my vehicle if a theft attempt is made! If you put your kill switch on the fuel pump and the thief gets onto the road with it and it dies so he abandons it, the car is sitting in the middle of the road while I'm asleep/gone! With my set-up I'm confidant they would get frustrated/run our of time and give up :) what about hidding a switch behind the lighter? I had this installed in my car that killed the coil, when you press down the lighter it kills the coil and one more activates it. I will take some pics because I also added a blinking LED. Quote Link to comment
Dirk Diggler Posted December 22, 2010 Report Share Posted December 22, 2010 In my Z (70 240) there is a switch under the temp controlls mounted on the drivers side of the center column. It is right about where your right knee would be, completely hidden unless you are looking for it. It controls the antenna up or down, im wiring it to be a kill switch instead. I live in a low crime area, im more worried about my window being broken and stuff being stolen out of it than the car being stolen, but Im doing it just incase I ever go to a shady area. Quote Link to comment
bredatto510 Posted December 22, 2010 Report Share Posted December 22, 2010 i have shaved door handles. removable steering wheel and since i only have the ignition switch and not the lock cylinder i take that off as well... just a suggestion some people pull off the coil wire. Quote Link to comment
WAGON JON Posted December 30, 2010 Report Share Posted December 30, 2010 Place a toggle switch in the black wire with the white stripe under the dash from the ignition key unit. Trust me, this works. :D Quote Link to comment
brodster Posted January 19, 2011 Report Share Posted January 19, 2011 Finally a topic up my alley! I am in the process of designing a theft deterrent system. I will update the progress as it comes along. Basically I want it simple but unique. I thinking of incorporating accerometers (for vibration and unauthorized change in location), pressure switches, internal motion detectors, etc. Could incorporate a simple password entry or remote entry. Of course it would tie into ignition, horn, lights etc. Perhaps that is overkill, but I am paranoid and it sounds like a fun project for an uncoming electrical engineer. One side note of EXTRA paranoia, if I knew a car had an alarm system I may try to cut the main battery cable to temperarily disable electrical. Granted this would be VERY difficult in some situations, but some car alarms have a small backup battery that triggers when the main battery goes. Quote Link to comment
Bleach Posted January 19, 2011 Report Share Posted January 19, 2011 Convicting them of grand theft auto will usually never happen unless they are caught by the police while driving. If they get away with a running car, its typically gone for good. Only exception is if they are so stupid that they keep driving the car for a few days like when Dillon saw Skip's stolen 510. Just kill it good. No start. :) I did the fuel pump kill switch and it saved a Z once. Quote Link to comment
sick620 Posted January 19, 2011 Report Share Posted January 19, 2011 to prevent stealing of stereo.... glue fish hooks behind your deck.... also glue to gas cap to keep people from stealing yo gas... Quote Link to comment
Bleach Posted January 19, 2011 Report Share Posted January 19, 2011 We live in America. Thieves sue you after they hurt themselves while trying to steal your stereo; especially if your intent is to hurt a thief. :( (even though they deserve it) Quote Link to comment
INDY510 Posted January 20, 2011 Report Share Posted January 20, 2011 Place a toggle switch in the black wire with the white stripe under the dash from the ignition key unit. Trust me, this works. :D I wouldn't reccomend that for anyone with a EFI motor swap ........ ... .. Most of my KA harness is powered by that wire My old 510 had a toggle switch for the ground at the coil ....... or the ground to the dizzy...... if it's a matchbox I like the classic... "take the rotor out of the dizzy ......... put it in your pocket . ........ and then put the dizzy cap back on, so it looks normal" I want a 45 second timer on my fuel pump ........ :cool: Quote Link to comment
Laecaon Posted January 20, 2011 Report Share Posted January 20, 2011 For stereos most stereos have have a screw hole in the back because some cars mount the stereo like that. Well make a bracket and screw teh stereo in. Quote Link to comment
brodster Posted January 20, 2011 Report Share Posted January 20, 2011 For stereos most stereos have have a screw hole in the back because some cars mount the stereo like that. Well make a bracket and screw teh stereo in. I agree that would be a good idea, but some piece of trash broke into my car years ago. It was screwed in. When he couldn't pry it out with a screw driver he got mad at me and just jammed the screw driver in the CD slot and broke it. What a jerk I was not to let him take it with ease. Quote Link to comment
HRH Posted January 20, 2011 Report Share Posted January 20, 2011 Just make sure whatever theft deterrent you make, don't post pictures or explain too well, or it may be self-defeating! :D I like my system. A myriad of toggle switches to turn on various items, no key, a push button start, and a hidden main ignition cut that piggybacks off the main switch. If you don't know where to look for it, you ain't going to find it. 1 Quote Link to comment
Logical1 Posted January 21, 2011 Report Share Posted January 21, 2011 Just make sure whatever theft deterrent you make, don't post pictures or explain too well, or it may be self-defeating! :D I like my system. A myriad of toggle switches to turn on various items, no key, a push button start, and a hidden main ignition cut that piggybacks off the main switch. If you don't know where to look for it, you ain't going to find it. X2! Quote Link to comment
