datzenmike Posted November 7, 2020 Report Share Posted November 7, 2020 2 hours ago, mainer311 said: Wife or husband? Make up your mind. I carried my L20b the other day, but it didn’t have a head on it. I’m only half the size of Ray. Me too but I was 25. No head and likely no flywheel. Be-built it on the kitchen table. A complete (manifolds, carb, oil pan, head, flywheel) L20B is 285. 1 Quote Link to comment
mrbigtanker Posted November 7, 2020 Report Share Posted November 7, 2020 1 hour ago, datzenmike said: Me too but I was 25. No head and likely no flywheel. Be-built it on the kitchen table. A complete (manifolds, carb, oil pan, head, flywheel) L20B is 285. Its awkward but that's not heavy. Fuck im 48 and I can lift up and carry it. But a fork lift is much easier.lol 1 Quote Link to comment
datzenmike Posted November 7, 2020 Report Share Posted November 7, 2020 It's do-able. My spine creaks just talking about it. 2 Quote Link to comment
mrbigtanker Posted November 7, 2020 Report Share Posted November 7, 2020 6 minutes ago, datzenmike said: It's do-able. My spine creaks just talking about it. Mike if I make a stroker block out of my L20B I got the Nissan NOS long rods, what pistons do I buy ? The wrist pin needs to be moved up correct. 1 Quote Link to comment
datzenmike Posted November 7, 2020 Report Share Posted November 7, 2020 Are you saying you are going to a different stroke?? I would need to know the new stroke. 1 Quote Link to comment
d.p Posted November 7, 2020 Author Report Share Posted November 7, 2020 Can some explain to me what these 3 connections are on my 4 speed and where they go on the 5 speed which doesn’t appear to have as many threaded holes. I figure on is reverse but what are the other two? 1 Quote Link to comment
d.p Posted November 7, 2020 Author Report Share Posted November 7, 2020 Here is my 5 speed which appears to only have one place for those sensor wire thingamajigs. 1 Quote Link to comment
thisismatt Posted November 7, 2020 Report Share Posted November 7, 2020 Did you try looking on the other side? 1 Quote Link to comment
mainer311 Posted November 7, 2020 Report Share Posted November 7, 2020 All you need is the reverse. The other 2 are 3rd gear and neutral switches. 1 Quote Link to comment
d.p Posted November 7, 2020 Author Report Share Posted November 7, 2020 (edited) Thanks Mainer. Which one is the reverse switch ? damn oil keep those wires looking new. And yes Matt nothing on the other side of that 5 speed. Edited November 7, 2020 by d.p 1 Quote Link to comment
d.p Posted November 7, 2020 Author Report Share Posted November 7, 2020 (edited) Never mind I found it in the Haynes manual. Edited November 7, 2020 by d.p 1 Quote Link to comment
thisismatt Posted November 7, 2020 Report Share Posted November 7, 2020 Red Black is the reverse 1 Quote Link to comment
d.p Posted November 8, 2020 Author Report Share Posted November 8, 2020 (edited) Sealing an oil pan with a cork gasket is that enough or should I use a bead of permatex gasket maker?? Edited November 8, 2020 by d.p 1 Quote Link to comment
mrbigtanker Posted November 8, 2020 Report Share Posted November 8, 2020 1 hour ago, d.p said: Sealing an oil pan with a cork gasket is that enough or should I use a bead of permatex gasket maker?? Yes use a silicone also on both sides. nice smooth even amount. 1 Quote Link to comment
datzenmike Posted November 8, 2020 Report Share Posted November 8, 2020 Yes, a smooth even small amount. Then pinched tight it will just squeeze out as well as in. Just look at any chevy intake manifold. You don't want that shit plugging up your oil pick up tube screen. 1 Quote Link to comment
d.p Posted November 8, 2020 Author Report Share Posted November 8, 2020 Ty. Cork + permatex I can do that. 1 Quote Link to comment
mrbigtanker Posted November 8, 2020 Report Share Posted November 8, 2020 2 hours ago, d.p said: Ty. Cork + permatex I can do that. And about 6-8 lbs only. Don’t be like me and try to put the bolts through the block. 1 Quote Link to comment
d.p Posted November 9, 2020 Author Report Share Posted November 9, 2020 10-4 playboy. 2 Quote Link to comment
Charlie69 Posted November 9, 2020 Report Share Posted November 9, 2020 I put my Datsun engine gaskets together dry, never had a problem. 1 Quote Link to comment
d.p Posted November 10, 2020 Author Report Share Posted November 10, 2020 Got some more parts for my truck. Dual mikuni throttle cable from Taka. I think I just need a shift knob for my 5 speed and I’ll be good to go. 3 Quote Link to comment
d.p Posted November 13, 2020 Author Report Share Posted November 13, 2020 When I swap the 5 speed and L20B can I reuse my release bearing from my 4 speed? I ask because I don't have one for my 5 speed. Are they interchangeable? Quote Link to comment
datzenmike Posted November 13, 2020 Report Share Posted November 13, 2020 The release bearing collar is matched to the clutch it is used on. You can only use it if you put you present clutch on the L20B. You will need to know what clutch you are going to be using on the L20B. If the L20B is from a car the diameter will be 200mm, a truck L20B is always a 225mm. If you buy a new clutch often the release collar comes with it. If you know exactly what year engine and what it's out of I can get you the part number. Quote Link to comment
d.p Posted November 13, 2020 Author Report Share Posted November 13, 2020 (edited) Engine is out of a early 610 so its a car L20B which is 200mm which is what I bought as well. Buuuuuuuut I just checked what I bought and it says it came with a new release bearing but no collar? So seeing as its a 200mm clutch on the an L20B flywheel I can then reuse my 521 release collar as its all 200mm no? https://www.ebay.com/itm/Datsun-Roadster-Exedy-Clutch-Kit-w-HD-600kg-Cover-fits-1600-2000-PL-510-521-620/233202857988?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 What's in the Box: NSC581 Exedy Heavy Duty 600kg Clutch Cover NSD026 Exedy Clutch Disc (formerly Exedy Daikin Part Number SA276) BRG002 Koyo Release Bearing 32202-30000 Bronze Pilot Bushing PT03 Clutch Alignment Tool Edited November 13, 2020 by d.p Quote Link to comment
d.p Posted November 13, 2020 Author Report Share Posted November 13, 2020 (edited) Or do I need to buy this: https://www.nissanpartsdeal.com/parts/nissan-sleeve-clutch~30501-k0400.html ? Edited November 13, 2020 by d.p Quote Link to comment
banzai510(hainz) Posted November 13, 2020 Report Share Posted November 13, 2020 (edited) We went thru this before its a 200mm roadster set up so use the 510/521 throw out sleeve. from your 4 speed. if the L20b flywheel is a 200mm all else is the same only the clamping force is better. but really if people just use the 510/521 clutch fork with the adjustable 510/521 threaded rod slave cylinder with it you could mismactch it and make it work cause of the adjustability of the 510/521 system. Edited November 13, 2020 by banzai510(hainz) Quote Link to comment
