OneFastRat Posted June 5, 2014 Report Share Posted June 5, 2014 I guess maintenance isn't a big deal. Every car needs it at some point or another. Going to be doing an l28 swap at the most Link to comment
I'm BLUE Posted June 5, 2014 Report Share Posted June 5, 2014 Anything I need to look out for when buying a 240z as a daily? I'm only driving a few thousand miles a month This time I'm actually serious about buying a datsun *Fuse-box - clean it out or replace it. They melt. *Headlight switch - stop working , solder melts , wiring plug starts to get hot/burnt/melt --- Buy headlight relay harness upgrade to regulate voltage. *Diff mount may be ripped ... not that big of a deal , but yet it is. *U-joints on the half-shafts , and driveline go out. It's not a big deal at all if you do that kind of work obviously. *Clutch Slave cylinder , and master cylinder... just replace them both if you have the money or at LEAST the slave cylinder. 71- and earlier have a 3-piece trans case. *Windshield leaks - Not big a deal right ? Well... becomes a pain in the ass. *Windshield wipers - From factory are "slow" it's an old car as well. Upgrades can be done for a newer faster engine. *Head gaskets - They are just part of the normal maintenance routine now with age. Electrolysis isn't our friend nor is a car sitting and rotting. *Intake Manifold gaskets - same as head gaskets. Front and rear studs my break/fight you. It's VERY common in the L6's. *Brakes - Make sure they hold pressure. Keep a bottle of break fluid with until verified good at home. *Carbs - If it hasn't been driven much or just sitting ... can build up shit or varnish over inside ... can be a slight pain , or be just fine .. roll of the dice. *Floor pans , frame rails , underneath battery tray , rear rocker/dogleg lips .... rust areas that are common. *Ignition Switchs - The electrical consumable part goes bad hear or there. Just replace it without question or have a spare on hand. *SU round top carbs - May or may not have leaking throttle shafts .... domes maybe sticking .... float adjustment .... needle individual conditon (bent/worn) ... blah blah blah Z-therapy in Salem,OR will hook you up for around $750 with throttle shafts machined for their roller bearings , cleaned carbs , replaced parts , and rebuilt. *Distributor - Break plate may or may not be stuck/frozen. It's pretty common. Worn bushings as well. Points and condensors have to be adjusted more often just depends on things. Points/Condensors go out (common sense) *Blown struts inserts = very common. *Sagging suspension springs = very common. *Crapped up brake calipers or wheel cylinders = common enough. *Differential whine ... common ... don't use poly bushings in the mustache bar if you can't stand "cabin gear whine" .... makes it sound like you have more problems than you do without a lot of insulation in the car .....had some with pinion bearings go out , but most usually are "fine" if you just drive em *Gas tanks sometimes need the re-conditioning more than others... some will push a steady stream of light rust inwards. *Mechanical fuel pumps usually are rotten or failed. That's pretty obvious though. *Relays at the kick panel ... sometimes give trouble ... work with it or replace it kinda deal. *Ignition tumblers get worn .... just the way it is. (careful.... the thin keys get bent ... don't leave weighted key rings in the ignition while driving) Pretty much an old car. Fun little cars. Still old though. I can't type much more have to go. Good luck Link to comment
RatVonDude Posted June 5, 2014 Report Share Posted June 5, 2014 I would always read and try to understand this before entering the 240z market 1 Link to comment
r0p0doe Posted June 5, 2014 Report Share Posted June 5, 2014 I don't even know what the fuck to say about this man, not only do I gotta worry about boys going after my little girls now I gotta worry about young fuckers tying to bang my grandma -_- Link to comment
bananahamuck Posted June 6, 2014 Report Share Posted June 6, 2014 wait for it wait for it..... If i had a dollar store ,,that is exactly the security guy(?) i would frickin hire.. People wouldn't shop lift as much if they knew it was gonna get all crazy up in here.. :rofl: 2 Link to comment
r0p0doe Posted June 6, 2014 Report Share Posted June 6, 2014 If i had a dollar store ,,that is exactly the security guy(?) i would frickin hire.. People wouldn't shop lift as much if they knew it was gonna get all crazy up in here.. :rofl: Yea dude went nuts literally lol every time I watch it 1 Link to comment
datzenmike Posted June 6, 2014 Report Share Posted June 6, 2014 I don't even know what the fuck to say about this man, not only do I gotta worry about boys going after my little girls now I gotta worry about young fuckers tying to bang my grandma :sleep: I fucked a grandmother before. It were very good... very good. Link to comment
tr8er Posted June 6, 2014 Report Share Posted June 6, 2014 NSFA??? Anyone, Anywhere, Anything! Link to comment
r0p0doe Posted June 6, 2014 Report Share Posted June 6, 2014 I fucked a grandmother before. It were very good... very good. But she wasn't a great grand mother or a great great, this brings a whole new meaning to mother fucker lol :rofl: Anyone, Anywhere, Anything! Gotcha Link to comment
flatcat19 Posted June 6, 2014 Report Share Posted June 6, 2014 Mike is the Grand Mother Fucker. Time for a title change. 3 Link to comment
RatVonDude Posted June 6, 2014 Report Share Posted June 6, 2014 I fucked a grandmother before. It were very good... very good. oh kay #1 one thing never to say on a dating site 1 Link to comment
q-tip Posted June 6, 2014 Report Share Posted June 6, 2014 Mike is the Grand Mother Fucker. Time for a title change. I second that motion Link to comment
datzenmike Posted June 6, 2014 Report Share Posted June 6, 2014 Mike is the Grand Mother's mother Fucker. 1 Link to comment
datzenmike Posted June 6, 2014 Report Share Posted June 6, 2014 oh kay #1 one thing never to say on a dating site "OK, put your hands down, I'm done" 1 Link to comment
hang_510 Posted June 6, 2014 Report Share Posted June 6, 2014 I fucked a grandmother before. It were very good... very good. so have i. she was younger than me. and i'm younger than GMFmike 2 Link to comment
TENDRIL Posted June 6, 2014 Report Share Posted June 6, 2014 when im 91 i sure as hell would want a 31 year old lady blowing me 1 Link to comment
tr8er Posted June 6, 2014 Report Share Posted June 6, 2014 Hello My Name Is: GMFMike. 2 Link to comment
hobospyder Posted June 6, 2014 Report Share Posted June 6, 2014 oh kay #1 one thing never to say on a dating site why does it look like she's given up at the end? Link to comment
uieluck Posted June 6, 2014 Report Share Posted June 6, 2014 NSFA=Not Safe For Anyone Link to comment
Fat510 Posted June 7, 2014 Report Share Posted June 7, 2014 If anyone likes spicy chips, I advise you to try Chile con queso Pringles Link to comment
tr8er Posted June 7, 2014 Report Share Posted June 7, 2014 I've been obsessed with roasted garlic lays. Link to comment
TENDRIL Posted June 11, 2014 Report Share Posted June 11, 2014 http://youtu.be/JHixeIr_6BM Link to comment
flatcat19 Posted June 11, 2014 Report Share Posted June 11, 2014 If anyone likes spicy chips, I advise you to try Chile con queso Pringles Those were gross. I recommend the buffalo Doritos though. Bueno. Link to comment
