'73 1200 Coupe Project, aka Timmy
  • Replies 1.9k
Never been a hug fan of the plastic coupe grill, and since I've always wanted to use the sedan grill I had collecting dust for 10+ years...
I like the way the headlight surrounds fit a little more flush. Thankfully the mounts for these are on the coupe even though they aren't used for anything...
The mounts for the sedan grill, not so much...   ^_^
Added some L brackets to the top to line up with the coupe grill mounts, and made some brackets to attach the bottom...
I really do prefer the look of the sedan grill. Tim says it's because it makes it look more like a 510...   :rofl:
  • Like 3
Getting antsy for my new wheels to show up. Remembered I had one wheel that is the same width and offset as my new fronts so I gave it a bash...
Fairly aggro fit...
Looking straight down, the lip is about 2-3mm inside the flare lip (what you see in the photo is the bottom wheel lip)...   B)
So I think the -25 offset will be perfect for the front. Just hoping the -50 isn't too aggro for the back...   :rofl:
No, I said you prefer it because it (the "Grands Pa's" grille) looks like a 510's (grille).  There's nothing in the world which will make the gorgeous 1200 Coupe look like a recycled old Fiat... oops, I mean a 510.
This topic is now closed to further replies.
