canby 2017 parts
  • Replies 60
You probably already plan on it but bring all the little 320 goodies you have.
I need a A12 flywheel if anyone can bring one to Canby... i'll bribe a Canadian to bring it north.
HOGIE, any A12 stuff in stock?
Have a 720 round tach and matching clock for '83 and on. They are plug and play.
Two primo 620 fuse boxes.
Late L16 / L18 SSS dual Hitachi 38mm SUs flattops on K14 intake. I never used them and they still have the original choke cables that were cut off when the engine was pulled in Japan. Haven't even been 'desmogged' and there is a vacuum advance port and a PCV valve.  It's a shame they haven't been used.
Only found on the earier 1200 and later 210. The A12 flywheel is unique to the A12.
Yes there would probably be room down around that corner in front of main building  but you gotta pay to set up table.. The swap usually goes around corner but i have seen it reach all the way into that far corner and i assume it could reach the far gate by the showers if there was enough sellers.
  I think Ted has his spot pretty full as of now.
