320 Newb Posted August 5, 2019 Author Report Share Posted August 5, 2019 Gas filler neck question. I'm assuming the overflow tube is turned to the bottom so gas drains out if it is filled up the neck. Correct? When I rotate my filler neck with the overflow on the bottom side it points the gas cap towards the back of the truck. To have the cap sit in the position that looks the best the overflow tube is oriented to the top. Can anyone post pics of their filler neck one with the cap on and one with the cap off? 1 Quote Link to comment
wayno Posted August 5, 2019 Report Share Posted August 5, 2019 I believe the vent tube goes on the top, that allows the air to escape the tank while the fuel is being put into the tank, if the tube was on the bottom there would be a chance that fuel could get in it while filling the tank and it would get spit out the vent tube and possibly at you. 1 Quote Link to comment
320 Newb Posted August 5, 2019 Author Report Share Posted August 5, 2019 23 minutes ago, wayno said: I believe the vent tube goes on the top, that allows the air to escape the tank while the fuel is being put into the tank, if the tube was on the bottom there would be a chance that fuel could get in it while filling the tank and it would get spit out the vent tube and possibly at you. Aaah that makes sense! That orients the cap in the right direction. 1 Quote Link to comment
wayno Posted August 5, 2019 Report Share Posted August 5, 2019 This is just all about how i think, I cannot say with certainty that what I said is right, it just seems like that is how it would work. When I do an engine conversion I put a tee in that vent line if the tank has no return line barb in it, it works fine plumbed that way for me. 1 Quote Link to comment
320 Newb Posted August 6, 2019 Author Report Share Posted August 6, 2019 I'm searching for temp sending unit stuff on the forum but can't find what I'm looking for. Do I remember correctly that early Roadster temp sending units are compatible with the 320 temp gauge? 1 Quote Link to comment
wayno Posted August 6, 2019 Report Share Posted August 6, 2019 I do not know if the early positive ground Roadster had a temp gauge, and the later neg ground part would possibly make the gauge work backwards. 1 Quote Link to comment
thisismatt Posted August 6, 2019 Report Share Posted August 6, 2019 A thermistor shouldn't care about polarity, but early gauges did tend to be the opposite range of later, with corresponding senders 1 Quote Link to comment
stevecar Posted August 6, 2019 Report Share Posted August 6, 2019 The Roadster fuel neck rubber will work in the L320. That is what I used. The 1500 Roadster uses the same temp sender as the truck. It has been discussed quite a bit in another thread. Here is a picture of the rubber I put in. I made one continuous piece and added some guides on the side to front part. 1 Quote Link to comment
320 Newb Posted August 6, 2019 Author Report Share Posted August 6, 2019 Wow that rubber looks great. Do you have a link to the item and where you purchased it? 1 Quote Link to comment
stevecar Posted August 7, 2019 Report Share Posted August 7, 2019 Did you get my email about the service sticker? Here is the link: https://www.ebay.com/itm/Rubber-Seal-for-Doors-Hatches-Lockers-Enclosures-Cabinets-C011-Per-Foot/141056177863?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 1 Quote Link to comment
wayno Posted August 7, 2019 Report Share Posted August 7, 2019 As I mentioned, I bought 8 feet of that stuff and it is supposed to arrive in 2 days. 1 Quote Link to comment
320 Newb Posted August 7, 2019 Author Report Share Posted August 7, 2019 27 minutes ago, wayno said: As I mentioned, I bought 8 feet of that stuff and it is supposed to arrive in 2 days. Give us a review when it comes in! Steve, can you detail how you made that profile around the vent screen? 1 Quote Link to comment
stevecar Posted August 7, 2019 Report Share Posted August 7, 2019 Here is a pic. I don't have any that show better detail. The front end extends inward and the rear extends down to hold it in place. 1 Quote Link to comment
320 Newb Posted August 7, 2019 Author Report Share Posted August 7, 2019 Nice work! 1 Quote Link to comment
320 Newb Posted August 8, 2019 Author Report Share Posted August 8, 2019 Has anyone found a replacement cork gasket for the 320 glass bowl fuel filters? 1 Quote Link to comment
difrangia Posted August 8, 2019 Report Share Posted August 8, 2019 I believe that you can get some parts to rebuild the original fuel filter with, maybe even the glass bowl, at 'Tractor Supply'. Maybe some other industrial or other agricultural suppliers ?? I've got an image saved somewhere, just gotta find it. Zed1 in Dallas area was source of this knowledge. Maybe I'll find it or he'll chime in. 1 Quote Link to comment
320 Newb Posted August 8, 2019 Author Report Share Posted August 8, 2019 Wow that's great! I've got a Tractor Supply here in town I'll check it out. Here's a dumb question... Can anyone tell me or post a pic of where the temp sensor is on a Nissan J motor? 1 Quote Link to comment
wayno Posted August 8, 2019 Report Share Posted August 8, 2019 It's on the head just under the upper radiator hose connection on the passenger side. 2 Quote Link to comment
320 Newb Posted August 8, 2019 Author Report Share Posted August 8, 2019 9 hours ago, wayno said: It's on the head just under the upper radiator hose connection on the passenger side. Here? I take it I need a bushing that holds the sensor with a connection for the wire? 1 Quote Link to comment
wayno Posted August 8, 2019 Report Share Posted August 8, 2019 There appears to be some differences between our heads but yes in that general area. 2 Quote Link to comment
320 Newb Posted August 9, 2019 Author Report Share Posted August 9, 2019 Has anyone converted to Dot 5 synthetic brake fluid? Thinking about doing it to preserve my paint. I'll cry if Dot 3 drips down my firewall. 1 Quote Link to comment
wayno Posted August 9, 2019 Report Share Posted August 9, 2019 (edited) OK, I received that weather seal today, it appears to be a good product. I test fit it on the L320 I painted recently, I tried the seal both ways, this direction first. Here is a photo of why I don't like it in this direction, I can see the gasket thru the louvers. Then I put it on the other way which is the way I like even though there may be arguments for the other way. You cannot see the gasket in the louvers this way. The gasket touches the hood when the hood is closed all the way across as far as I can tell. This gasket will not work for around the screen unless one adds an upright for the gasket to slide onto like Steve did in his photos on his Tuesday posts. Now the thing for me is why doesn't the gasket go all the way across, this baffles me, but the NL320 and U320 are that way also even though the gasket is almost completely gone on both sides I can tell there was no gasket in the middle, it seems to me that it should go all the way across, but I have not seen any photos of the engine compartment of a new 320 that I can see this area, maybe I need to search more, I have seen a few 320s with new gasket material and none have it all the way across. By the way, I ordered 8 feet and they sent me 10 feet. Edited August 9, 2019 by wayno 1 Quote Link to comment
stevecar Posted August 10, 2019 Report Share Posted August 10, 2019 10 hours ago, wayno said: Now the thing for me is why doesn't the gasket go all the way across, this baffles me, but the NL320 and U320 are that way also even though the gasket is almost completely gone on both sides I can tell there was no gasket in the middle, it seems to me that it should go all the way across, but I have not seen any photos of the engine compartment of a new 320 that I can see this area, maybe I need to search more, I have seen a few 320s with new gasket material and none have it all the way across. Here is a pic out of the intro to 320 manual. You can see that it doesn't go straight across the middle. Quote Link to comment
Conner Posted August 10, 2019 Report Share Posted August 10, 2019 Moses-- I just looked through my service manual. To return to your question about the gas pedal pad: I found two pictures of the pedals in the Owners Manual from Alan Bent's Datsun 320 CD where the accelerator pedal was bare. See below. I wonder if they may have come that way originally. Quote Link to comment
