wayno Posted July 28, 2019 Report Share Posted July 28, 2019 I originally thought the strip pointed up went all the way across from one fender to the other fender, now I am wondering as my NL320 and U320 have a gap where the vent is. Here is what the end of the gasket looks like. My U320 vent assembly is in very good shape considering it's from a 62. You can see in the second photo how the ends where the screen goes are flat, there is nothing to connect the gasket too except the screen itself, this is why I do not think the gasket I ordered will work on the screen, but I do think it will work for the hood strip although it doesn't look original. 1 Quote Link to comment
320 Newb Posted July 28, 2019 Author Report Share Posted July 28, 2019 Was there gasket material also along the seams that run from front to back on either side of where the hood comes down? 1 Quote Link to comment
wayno Posted July 28, 2019 Report Share Posted July 28, 2019 I don't think so, I think it just had the 2 bumpers on each side and a couple bumpers in the front right by the top grill attachment screws, but them holes could be for something else, my guess is bumpers. 1 hour ago, 320 Newb said: Was there gasket material also along the seams that run from front to back on either side of where the hood comes down? 1 Quote Link to comment
320 Newb Posted July 29, 2019 Author Report Share Posted July 29, 2019 According to my measurements this fuel neck filler grommet should would. I just bought want and will report back once it comes in: https://www.ebay.com/itm/For-Mopar-A-B-C-Body-64-74-Fuel-Gas-Tank-Filler-Neck-Tube-Rubber-Grommet-Seal/123792302687?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20160908110712%26meid%3D27e03d04671649038830069e6aa90313%26pid%3D100677%26rk%3D3%26rkt%3D8%26sd%3D362644800734%26itm%3D123792302687%26pg%3D2385738&_trksid=p2385738.c100677.m4598 Quote Link to comment
Stoffregen Motorsports Posted July 29, 2019 Report Share Posted July 29, 2019 (edited) McMaster-Carr sells a few different profiles of that type or seal. When trying to figure out how to keep the weather out of the floor mounted auto trans shifters I use on the LS swaps, I took a look at their site, not expecting to find anything, but sure enough, they had it. I buy a lot of stuff from them. They call them "push on rubber edge seals". Edited July 29, 2019 by Stoffregen Motorsports Quote Link to comment
difrangia Posted July 30, 2019 Report Share Posted July 30, 2019 McMaster Carr's website has always seemed pretty user friendly to me. Pretty good search facility too. I leaned on them pretty extensively when I put a microbrew system together 20-25 years ago. I didn't have the internet back then and spent hours in their big thick yellow book and the 'Thomas Register'. I've used them innumerable times since Al Gore invented the internet and really appreciate their site. 2 Quote Link to comment
320 Newb Posted July 30, 2019 Author Report Share Posted July 30, 2019 (edited) I made a Tune Up Spec Sticker for my build and have a handful extra if anyone's interested. $5 shipped. I blew up a photo and cleaned it up in photoshop so it's a very good copy. It preserves all the crudeness of the original. It's not a modern font approximation. Working theory on these stickers is dealerships had them and most didn't put them on. But they've been spotted on 222s, 320s, 210s, Bluebirds... I recently saw a ratty one on an unmolested 320 in a guy's backyard. Edited July 30, 2019 by 320 Newb 4 Quote Link to comment
320 Newb Posted July 30, 2019 Author Report Share Posted July 30, 2019 Just a heads-up I'm out of stickers. Wayne and Steve I've got stickers set aside for you but that's it. FaceBook cleaned me out. 2 Quote Link to comment
320 Newb Posted August 1, 2019 Author Report Share Posted August 1, 2019 I got that MOPAR fuel filler neck grommet and it seems to fit OK. I wish it was a little snugger but it'll work for sure. It's been so long since I pulled of my stock fuel grommet. Was there a little play in it where the neck comes through or was it a snug fit? 2 Quote Link to comment
Stoffregen Motorsports Posted August 1, 2019 Report Share Posted August 1, 2019 I bet there isn't anyone alive that remembers how a "new" 320 fuel filler neck grommet was supposed to fit. 1 Quote Link to comment
320 Newb Posted August 1, 2019 Author Report Share Posted August 1, 2019 3 minutes ago, Stoffregen Motorsports said: I bet there isn't anyone alive that remembers how a "new" 320 fuel filler neck grommet was supposed to fit. What's your experience with fuel necks? Do they usually fight tight in the grommet or is there a little wiggle room? Quote Link to comment
Stoffregen Motorsports Posted August 1, 2019 Report Share Posted August 1, 2019 I have seen both. Some are loose and some are tight. Usually, the thinner and more flexible the rubber grommet, the tighter they fit. That's my experience. Quote Link to comment
Stoffregen Motorsports Posted August 1, 2019 Report Share Posted August 1, 2019 Once you finish this restoration, you will need to change your moniker. You won't be a newb anymore. 1 1 Quote Link to comment
320 Newb Posted August 1, 2019 Author Report Share Posted August 1, 2019 A local guy gave me a 1960 211 Sedan fuse box cover in pretty pristine condition and it's exactly the same as the 320 cover. Below I have it on a 320 fuse box. My goal is 3D print a replica complete with a 320 fuse box diagram sticker. I'm not sure how much it'll cost but would anyone else be in the market for one? 3 Quote Link to comment
difrangia Posted August 2, 2019 Report Share Posted August 2, 2019 (edited) Sticker is different than a 320 sticker. Box looks the same. The cover flips top to bottom to go on the base. The two fuse holders below the fuse box in the photo were added by me. One is for the mechanical brake switch that I added on the pedal and I don't remember what the other one is without digging into it. Edited August 2, 2019 by difrangia 1 Quote Link to comment
320 Newb Posted August 2, 2019 Author Report Share Posted August 2, 2019 The sticker is different but the lid pictured clicks right into the 320 fuse box. 2 Quote Link to comment
Stoffregen Motorsports Posted August 2, 2019 Report Share Posted August 2, 2019 If only life were that simple again. Four fuses... 1 Quote Link to comment
difrangia Posted August 2, 2019 Report Share Posted August 2, 2019 (edited) ^ ^ ^ Yup, Matt, freaked me flat out to the point that I had to add a couple of freestander fuses. ^ ^ ^ The engineroom was so drab and boring, but the two extra fuses jazz it up real good !! Chek it out MT, I just put the tune-up sticker on. Love it and thanx !! Edited August 3, 2019 by difrangia 3 Quote Link to comment
Stoffregen Motorsports Posted August 2, 2019 Report Share Posted August 2, 2019 I saw that. Way to put your foot down. 1 Quote Link to comment
320 Newb Posted August 4, 2019 Author Report Share Posted August 4, 2019 Has anyone found a rubber pedal pad that fits the accelerator pedal? Quote Link to comment
Conner Posted August 4, 2019 Report Share Posted August 4, 2019 2 hours ago, 320 Newb said: Has anyone found a rubber pedal pad that fits the accelerator pedal? I believe 46431-04100 is the right part, still available from Nissan for around $6. Quote Link to comment
66Fairlady Posted August 4, 2019 Report Share Posted August 4, 2019 1 hour ago, Conner said: I believe 46431-04100 is the right part, still available from Nissan for around $6. That number is for the clutch and brake pedal pads. Gas pedal pad is glued on. Cut a rubber piece from a similar thick/pattern donor mat. Quote Link to comment
320 Newb Posted August 4, 2019 Author Report Share Posted August 4, 2019 The brake and clutch are no sweat. VW pads also fit. I was hoping to find the right gas pedal pad but if not I'll modify a break pedal pad to work. Quote Link to comment
Conner Posted August 4, 2019 Report Share Posted August 4, 2019 Perhaps this reproduction part for a roadster would work for you: https://www.datsunparts.com/1990. 1 Quote Link to comment
320 Newb Posted August 5, 2019 Author Report Share Posted August 5, 2019 If anyone does a cab off before to do the wiper assembly and motor before the dash goes in. And do the brake/clutch pedals before the steering column goes back in. I'm learning the hard way. 1 Quote Link to comment
