q-tip Posted October 13, 2015 Report Share Posted October 13, 2015 So does it do anything but sit there? It's actually a well built well balanced car, it just doesn't get out much. Quote Link to comment
datzenmike Posted October 13, 2015 Report Share Posted October 13, 2015 Maybe if it got out more it would get out more. I suspect this car is making a 10 the hard way and you could have got the same or better with a turbo V6 that actually fit. Now if this had a GTR drive train.... 2 Quote Link to comment
paradime Posted October 13, 2015 Report Share Posted October 13, 2015 It's been said that anything over 270HP in a 510 is a waste of power. If you build a hand make chassis so you can lug around a V8 in a 510 shell, and still can't keep up with a turbo 4 cylinder, isn't that a waste of power, money, and effort? Don't get me wrong, I Love the sound of a V8 as much as the next guy, but I don't get stuffing one into a loosing configuration. You want a fast drag 510? There are 6 second SR20 Datsuns out there. You want a fast solo/track car? A well built turbo KA 510 will smoke any V8 dime out there. That being said, if it's about novelty, than to each his own, but don't make the mistake of justifying it with the notion of actual performance. 1 Quote Link to comment
Burabuda Posted October 19, 2015 Report Share Posted October 19, 2015 http://sandiego.craigslist.org/nsd/cto/5224804448.html Quote Link to comment
DISLEXICDIME Posted October 19, 2015 Report Share Posted October 19, 2015 U G L Y you ain't got no alibi you ugly! girl you ugly! 2 Quote Link to comment
DaBlist Posted October 19, 2015 Report Share Posted October 19, 2015 http://sandiego.craigslist.org/nsd/cto/5224804448.html Cast iron exhaust manifolds, iron heads & an automatic. Needs dual battery's up front to keep with the theme 1 Quote Link to comment
paradime Posted October 19, 2015 Report Share Posted October 19, 2015 http://sandiego.craigslist.org/nsd/cto/5224804448.html What he said: "Needs front suspension work, shakes above 40, due to poor geometry setup". What he meant: "I'm a moron who made a bunch of assumptions rather than researching his build, so now I have a chopped up half ass POS abortion I'm trying to unload. Turns out, the stock 510's Mcpherson strut suspension can't handle a small block 350. Oh yah, one of those odds and ends I mentioned is it needs is a custom built chassis to make it drivable". What he said: "Bottom line is: it's a super clean *reliably running* V8 Swapped 510 for $6000" What he meant: "I fucked this thing up a tree so bad, now it's not even worth the expense of actually making it *reasonably drivable*. So I'm fishing for the next moron sucker who's always dreamed of shoehorning a V8 into a Dime to take it off my hands". This is a perfect example of why trying to convert a $0.10 into a Camero is a waste of power, money, effort, and a very well designed classic Japanese 4 cylinder car. The sad thing is, this 510 would still be worth $6000 had he just kept his fucking hands off it. Now he couldn't make $3K parting it out. 1 Quote Link to comment
russaroll Posted December 15, 2015 Report Share Posted December 15, 2015 thought i would share. this thing is a handful. inside not mine BTW. PROS - huge smile. Quote Link to comment
q-tip Posted December 15, 2015 Report Share Posted December 15, 2015 thought i would share. this thing is a handful. inside not mine BTW. PROS - huge smile. See how far back it is? That will actually work, and handle decently. Quote Link to comment
thisismatt Posted December 15, 2015 Report Share Posted December 15, 2015 See how far back it is? That will actually work, and handle decently.That's not important. What's important is how many times you can dimple die a given plane of sheet metal. 3 Quote Link to comment
paradime Posted December 15, 2015 Report Share Posted December 15, 2015 Cons - you put a V8 in a 510 2 Quote Link to comment
q-tip Posted December 15, 2015 Report Share Posted December 15, 2015 Cons - you put a V8 in a 510 You're very close minded for a the rapist. Quote Link to comment
datzenmike Posted December 15, 2015 Report Share Posted December 15, 2015 See how far back it is? That will actually work, and handle decently. You mean it will handle better than if the extra 300 pounds were closer to the front? Or handle decently in a straight line? Quote Link to comment
russaroll Posted December 15, 2015 Report Share Posted December 15, 2015 See how far back it is? That will actually work, and handle decently.Maybe if it would grab. It's basically a donut machine. 1 Quote Link to comment
datzenmike Posted December 15, 2015 Report Share Posted December 15, 2015 Maybe if it would grab. It's basically a donut hole machine. Quote Link to comment
paradime Posted December 15, 2015 Report Share Posted December 15, 2015 You're very close minded for a the rapist. As the rapist, and a 510 owner, I'm mandated to act if you are a danger to yourself, or your Datsun. Clearly, both are threatened in this case. Any more back sass, and I'll 5150 your ass straight to the Toyota forum. :P 1 Quote Link to comment
datzenmike Posted December 16, 2015 Report Share Posted December 16, 2015 Any more back sass, and I'll 5150 your ass straight to the Toyota forum. :P Render unto Mod that which is the Mod's prerogative..... 1 Quote Link to comment
paradime Posted December 17, 2015 Report Share Posted December 17, 2015 Hell hath no fury like the circumvented Mod. Quote Link to comment
KoHeartsGPA Posted December 17, 2015 Report Share Posted December 17, 2015 L series with dual SUs is the most beautifully setup dime on the planet, hence Joel's goon. 1 Quote Link to comment
q-tip Posted December 17, 2015 Report Share Posted December 17, 2015 L series with dual SUs is the most beautifully setup dime on the planet, hence Joel's goon. That's cheating. 1 Quote Link to comment
logicali Posted June 5, 2016 Report Share Posted June 5, 2016 I haven't seen a discussion about a 510 V8 swap in a while. The common complaint is that it will make the car nose heavy and only good as a trailer queen........not so. It is possible to install a V8 into a 510 and still have a daily driver and a fun autocross car. My car now has over 50,000 miles on it with a Ford 5.0 and Corvette rear end. Front to rear weight bias: front 51% rear 49%, which is better that the stock 56% front bias. It is not an easy swap, but it does make a fun car to surprise the odd Beemer and Porsche on the freeway. Here are some pics: The car is run at the San Diego Qualcomm SCCA solo meets mostly ever month. We need more San Diego 510 participation at the events as I am usually the only 510 running. These cars are meant to have fun with, not just to look at them. Come on down, have some fun! Matt Guzzetta WHO DID YOUR SWAP? IM IN LOS ANGELES , TRYING TO GET A V8 SBC PROPERLY FIT INTO A 510 Quote Link to comment
datsunfreak Posted June 6, 2016 Report Share Posted June 6, 2016 WHO DID YOUR SWAP? IM IN LOS ANGELES , TRYING TO GET A V8 SBC PROPERLY FIT INTO A 510 FYI, his is a Ford V8, thus smaller and lighter. Don't expect a Chevy V8 to be as balanced and handle as well as his car. 3 Quote Link to comment
datzenmike Posted June 6, 2016 Report Share Posted June 6, 2016 51% front and 49% rear is only 100 pounds moved to the rear on a stock 2,200 lb weight 510. The front could be 100 pounds heavier and still be 51% of a vehicle weight of 2,600 pounds. Then again it's an auto cross car so I imagine it's not carrying any spare wasted weight and has been lightened. That all said 51/49 is a good number. Quote Link to comment
paradime Posted June 6, 2016 Report Share Posted June 6, 2016 No doubt this is a very special car. Hell the rear end alone shows the kind of high art craftsmanship that goes into building a functional V8 dime and few have the skill to do something like that right. The fact that this car has plates truly makes my head spin. I would love to ride shotgun in that beast through Sunrise Highway. Quote Link to comment
banzai510(hainz) Posted June 6, 2016 Report Share Posted June 6, 2016 BIG MONEY!!!!!!!!!!!!!on the rear diff alone this is out of most 510 owners leauge 1 Quote Link to comment
