dainja97 Posted November 28, 2013 Report Share Posted November 28, 2013 I have been looking around everywhere trying to find a way to put stereos in my 521 without disrupting the classic look please post pics of your 521 headunits, speakers, where you have hid them. thank you! Quote Link to comment
wayno Posted November 28, 2013 Report Share Posted November 28, 2013 I put a console in and install the stereo in it, and all my doors were cut so far for speakers, I did not cut them, so your going to have to get inventive for the speakers, maybe under the dash, half way under the dash, tuck them up there. Quote Link to comment
MikeRL411 Posted November 28, 2013 Report Share Posted November 28, 2013 "I posted this on 7 Oct 2010, still applies Go to a local swap meet and look for early Radio Shack units, usually AM/FM with a built-in speaker on top [which says no FM Stereo]. They have proper shaft spacing and location to fit factory dashes when the Radio Delete plate is removed. The 520, 521, 410 and 411 didn't really have provision for external speakers. Some of these early Radio Shack units did have connections for external speakers but as might be expected don't think of shaking the sheet metal with them. " Also JC Whitney had a "Universal" unit that individually placed On/Off, Tuning and Display units that mounted in any dash since they were separate modules. The main electronics box could be mounted in the dash of anywhere in the vehicle. I posted the info on the "universal" unit many moons ago, maybe "search" could resurect it, I don't need it so I leave any search to your discretion or desire. Quote Link to comment
DanielC Posted November 28, 2013 Report Share Posted November 28, 2013 There is not a lot of options in a 521, not a lot of space. I have mounted 6x9 speakers in the lower front part of the door, requires cutting a hole in the door. you may need to space the speaker away from the door panel, if the speaker magnet hits the door skin. If you take out the bench seat, you can use a sheet of plywood, just above the transmission tunnel to mount bucket seats on. This gives You the option of putting speakers behind the bucket seats, firing up. You could also mount speakers on the front of the bucket seat support, using the cavity under the seat base for the "box" of the speaker. Putting an expensive head unit in the dash is inviting to thieves. A locked door just means broken glass. Maybe leave the stock radio, or delete plate in the dash, and put the head unit in the glove box area, behind the closed door, so it is not as obvious you have the expensive head unit in there. The good news, because the cab is so small, you do not need a lot of power to get it loud in the cab. Quote Link to comment
dainja97 Posted November 28, 2013 Author Report Share Posted November 28, 2013 thank you guys ! Quote Link to comment
mrbigtanker Posted November 28, 2013 Report Share Posted November 28, 2013 I am running 4 10" subs behind my seat and 3 sets of seperates in the door panels and kick panels all powered with 1200 watts at 1 ohm load.wait a minute i grew up out of that.haha there is some room to be creative but not that much room. Quote Link to comment
datson4life Posted November 28, 2013 Report Share Posted November 28, 2013 my tachs are taking the stereo spot, so i might install stereo inside glove box, use to have amp with 10 inch sub but these trucks are old and everything vibrates and rattles too much Quote Link to comment
oldskoolvws Posted December 4, 2013 Report Share Posted December 4, 2013 My way. Sorry for the huge pictures but not sure how to resize with the new imageshack. Anyway, going to redo the whole system one more time. Going to change the faces on these and go to 6.5 separates and put one or two 8" bass boxes under the seat. No cut doors and everything still functions. One problem I have is getting the package tray to work, but I'll figure it out. I might also put some highs in the corner of the cab to get some spacial tones. Going to run the new Alpine amps to save space. The head unit will be factory 521 with Bluetooth & aux function, likely in mono. 1 Quote Link to comment
datson4life Posted December 4, 2013 Report Share Posted December 4, 2013 i see some nice tachs got installed 1 Quote Link to comment
oldskoolvws Posted December 4, 2013 Report Share Posted December 4, 2013 Shhhhhhh. 1 Quote Link to comment
uberkevin Posted December 4, 2013 Report Share Posted December 4, 2013 I was looking at the tachs more then the speakers. Sweeet place for them.. speakers and gauges 1 Quote Link to comment
fryanbacon Posted October 16, 2020 Report Share Posted October 16, 2020 On 11/27/2013 at 6:37 PM, wayno said: I put a console in and install the stereo in it, and all my doors were cut so far for speakers, I did not cut them, so your going to have to get inventive for the speakers, maybe under the dash, half way under the dash, tuck them up there. Where did the console come from? 1 Quote Link to comment
wayno Posted October 16, 2020 Report Share Posted October 16, 2020 9 minutes ago, fryanbacon said: Where did the console come from? That is a Datsun/Nissan 720 console, they come in different lengths, even though it does not look like it that console is from a 720 with a longshaft 5spd in it that has a coin tray in front of the shifter hole, they made them without a coin tray in the 1985+ regular cab/sort box trucks, they made them in black, blue, and tan. 1 Quote Link to comment
yenpit Posted October 16, 2020 Report Share Posted October 16, 2020 I have a blue 720 console up on eBay now. They are what I call "real plastic", like an old AMT Revell etc model, that CAN be easily prepped & painted to suit your needs (newer cars are polypropylene plastic, which paint does not adhere to long term). TJ 1 Quote Link to comment
Greaser2 Posted October 19, 2020 Report Share Posted October 19, 2020 Don’t have any fancy speakers but have a $400 RetroSound W/Bluetooth head and a face plate from something. If you didn’t know, it looks original. 2 Quote Link to comment
Greaser2 Posted October 19, 2020 Report Share Posted October 19, 2020 (edited) Couple of 4x10’s tucked under the dash affixed to the kick panels. Edited October 19, 2020 by Greaser2 2 Quote Link to comment
mrbigtanker Posted October 20, 2020 Report Share Posted October 20, 2020 Untitled by raymond medeiros, on Flickr Go big or go home, Cut the dash put what you want. Take notice of my door panels. 3 Quote Link to comment
katfish Posted October 27, 2021 Report Share Posted October 27, 2021 fancv and i like it 🎯 1 Quote Link to comment
banzai510(hainz) Posted October 27, 2021 Report Share Posted October 27, 2021 geting a radio in a 521 is a mofo. Use your I phone headsets. plus nobody wants a AM radio and wont break your window. Matter of fact they will throw another Hatchi radio in your truck if you leave the doors unlock or in the bed of the truck 2 Quote Link to comment
datzenmike Posted October 27, 2021 Report Share Posted October 27, 2021 Yup. You don't need to see the 'head unit' anyway. Bolt under seat out of sight and use the remote. Put amp under the other seat. 521 engine and drive train will last a lot longer if you can hear it without sound system. Quote Link to comment
mrbigtanker Posted October 27, 2021 Report Share Posted October 27, 2021 3 hours ago, datzenmike said: Yup. You don't need to see the 'head unit' anyway. Bolt under seat out of sight and use the remote. Put amp under the other seat. 521 engine and drive train will last a lot longer if you can hear it without sound system. Well I have all the vitals tracked on the dash and no 521 stock shit for me. 1 Quote Link to comment
mrbigtanker Posted October 27, 2021 Report Share Posted October 27, 2021 By the way who revived this dead thread ? 1 Quote Link to comment
mainer311 Posted October 27, 2021 Report Share Posted October 27, 2021 The answers from the "old timers" are always completely useless. Quote Link to comment
datzenmike Posted October 27, 2021 Report Share Posted October 27, 2021 Somewhat like yours. Quote Link to comment
mainer311 Posted October 27, 2021 Report Share Posted October 27, 2021 1 hour ago, datzenmike said: Somewhat like yours. I wasn’t answering his question. Mike ate too much poutine and listened to the tune of his farts all the way to his keyboard. 1 Quote Link to comment
