Royal Sierra Posted August 8, 2012 Author Report Share Posted August 8, 2012 I didnt have to cut anything. It fit just right. I hate it when I let off the brakes the truck wont roll. even on a hill. hopefully it will be fine like that to and from work tomorrow. then adjust them!! Quote Link to comment
mklotz70 Posted August 8, 2012 Report Share Posted August 8, 2012 Most likely, the m/c pushrod didn't fit quite right and it's keeping the piston pushed in. When it does that, it won't let fluid back into the reservoir....so the system stays pumped up which causes the brakes to drag. They're going to get HOT!!! Make sure that when the pedal is up(at rest), there's a small amount of play in the push rod. You should be able to push the pedal down about 3/8" before the rod quits wiggling. If you can't wiggle it, it's adjusted too tight. Keep the clevis off the old m/c if you can. Then, if/when you upgrade to a dual reservoir m/c, it will be easier to make the new push rod. Quote Link to comment
banzai510(hainz) Posted August 8, 2012 Report Share Posted August 8, 2012 Dude WTF I say??????? Its the correct one as I have this one also. I said you have to, cut the shaft. Look how long it is. When you installed it, didnt you notice the shaft was probably 1/4 way pushed the master in cause the pedal arm is a certain distance and not releasing on the 2nd stroke or soemthing like that, holding pressure. Look closly at the photo. If the pedal arm goin inbetween the fork it will hit the shaft. Notice the old one how much space is in there. Your going to cut at least a half inch or more off the end. What I do is flip the fork on the other way and thread it on. then cut the shaft and when you remove the fork to put it back on the otherway it will clean the threads up. The front wheel could be just sticky or a bad wheel cylinder is making it sticky.If its only one whell that is holding. The brake bleed you might have to go to the dealer. the bleed screw: be careful 521 used alot of SAE thread sizies so if it dont go in right then you could have a metric thread bleed. Like a 510 its all metric. 521s used alot of BOTH. Can get confusing. 1 Quote Link to comment
Royal Sierra Posted August 8, 2012 Author Report Share Posted August 8, 2012 Ok well im taking it back out now. It just sucks the bleeder on the right rear is broken so we gotta figure that out. Putting in new wheel cylinders while we are at it Quote Link to comment
wayno Posted August 8, 2012 Report Share Posted August 8, 2012 Ok well im taking it back out now. It just sucks the bleeder on the right rear is broken so we gotta figure that out. Putting in new wheel cylinders while we are at it Does someone near you have a 521 that's not running, or have that bleeder part on an unused rearend that you can snag? I have what you need, but you are a ways away from me. Quote Link to comment
banzai510(hainz) Posted August 8, 2012 Report Share Posted August 8, 2012 I recently got introduced to PB Blaster. Hopefully it can break screw loose for you if you plan ahead and soak it Quote Link to comment
Royal Sierra Posted August 8, 2012 Author Report Share Posted August 8, 2012 I was told its part of the wheel cylinder. Is it not? Quote Link to comment
Royal Sierra Posted August 8, 2012 Author Report Share Posted August 8, 2012 What size are the bolts that thread into the brake drum on the rear to remove them? Quote Link to comment
wayno Posted August 8, 2012 Report Share Posted August 8, 2012 I was told its part of the wheel cylinder. Is it not? No it's not part of the wheel cylinder, at least I don't think it is. Quote Link to comment
Royal Sierra Posted August 9, 2012 Author Report Share Posted August 9, 2012 Shit. I know someone in milwaukie but have no way there. Id throw $20 your way. If you dont mind other wise dont wprry abput it Quote Link to comment
an_orange_s2k Posted August 13, 2012 Report Share Posted August 13, 2012 just went through the entire thread, great updates. im about to pick up a 521 and its good to see other peoples progress Quote Link to comment
Royal Sierra Posted August 13, 2012 Author Report Share Posted August 13, 2012 Cant wait to see it! This is how mine sits as of now. Waiting to get paid. Got a better paying job and have already got a bunch of overtime so itll a nice check. This is what it took to get my drums off. A few hard wacks with the non sharp end and they came right off. 1 Quote Link to comment
wayno Posted August 13, 2012 Report Share Posted August 13, 2012 I have felt like using that on my truck a few times, but not on the drums. :lol: :lol: I controlled myself though. :sweat: Quote Link to comment
Royal Sierra Posted August 14, 2012 Author Report Share Posted August 14, 2012 Also, Wayno, about that bleeder part, I ordered wheel cylinders today and the guy said it comes with a new bleeder piece. Thats some good news..also after all this time I got it registered in my name. I would have put it off more but the Judge said Id better do it by the 13th or Id pay more fines haha. When the registration is up in October If everything goes well Im gonna get the Pacific Wonderladn plates. Quote Link to comment
Royal Sierra Posted August 14, 2012 Author Report Share Posted August 14, 2012 Heres my shock mounts up front..rears were cut out by the PO and then this pin was hangin down. Wires run towards the cab..what could this be Quote Link to comment
mrbigtanker Posted August 14, 2012 Report Share Posted August 14, 2012 Heres my shock mounts up front..rears were cut out by the PO and then this pin was hangin down. Wires run towards the cab..what could this be cb hook up not sure did you trace it yet make sure to its not going to power,that looks just like my truck sat for 3 months. :thumbup: Quote Link to comment
Royal Sierra Posted August 14, 2012 Author Report Share Posted August 14, 2012 It looks different than any other ive seen haha. Anyways. I Made a deal with my dad and hes gonna pay for my all my parts if they come in tomorrow. Turned drums, shoes and wheel cylinders. Just need to cut the master cyl and put it all back together. Then it needs a new carb and to service the diff. Quote Link to comment
mrbigtanker Posted August 14, 2012 Report Share Posted August 14, 2012 dad is a good man. Quote Link to comment
Royal Sierra Posted August 17, 2012 Author Report Share Posted August 17, 2012 Well after a few days of going back and fourth to the autoparts store I finally got all the right stuff. And thanks again to Wayno for that brake bleeder valve/adapter. If all goes well, should be up and stopping tomorrow- Quote Link to comment
jon521 Posted August 17, 2012 Report Share Posted August 17, 2012 nice job! :thumbup: Quote Link to comment
jrock4224 Posted August 17, 2012 Report Share Posted August 17, 2012 nice when your done there i can copy your shit ...my rears are fucked after driving to portland and back....to be fair they started acting fucked up 5 minutes into the trip... i just ratsuned my way down to blue lake and back...all hot wheeled and boiling brake fluid like....looking good ... high five your dad from ratsun for the hook up... Quote Link to comment
mrbigtanker Posted August 17, 2012 Report Share Posted August 17, 2012 Well after a few days of going back and fourth to the autoparts store I finally got all the right stuff. And thanks again to Wayno for that brake bleeder valve/adapter. If all goes well, should be up and stopping tomorrow- looks like your ready for JCCS. Quote Link to comment
Royal Sierra Posted August 17, 2012 Author Report Share Posted August 17, 2012 JCCS? Quote Link to comment
DatWifey Posted August 17, 2012 Report Share Posted August 17, 2012 Japanese Classic Car Show in Long Beach, CA http://community.rat.../page__hl__jccs Quote Link to comment
mrbigtanker Posted August 17, 2012 Report Share Posted August 17, 2012 JCCS? Sorry bro thought you new about it,it would be a road trip though. Quote Link to comment
