Drag Wag.
Filthy_
  • Replies 302
Yeup, pretty simple. The dude who sells them uses some pretty nice shit though, its definitely not out of my laziness and time crunch to spend a hundo on all of that goodness. Sourcing all of those parts, some of which appear to be machined... not at the moment.
After thinking on it, and what it would cost to build, might be cheaper/easier just to buy that...   :rofl:
E865CC73-7E43-41FB-8BB3-A941404DC33A_zps
So the Volvo end links showed up. When I looked at them online I wasn't sure wtf these were for, but they are mis-alignment bushings. I honestly didn't even know the kit came with them, but holy shit am I glad it did.
8637F65B-36EC-4092-957B-6AE6E77BF50C_zps
I scrapped the original idea to put the hime joint into the control arm. It was just a tad large, And i would have had to completely disassemble the front end to cut some shit off of my already powdercoated lower arms.
Ended up putting the bushings facing down, with the joint at the top.
B034507C-4E73-49FA-B34E-65A14F4ABB46_zps
At ride height, the alignment was pretty goddamn good.
B637111A-3352-4FAC-AA04-1856B85F17F2_zps
Ended up zipping about an inch off the end of the sway bar. This photo shows the mis-alignment when the vehicle is slammed.
C8D5D3C2-1D32-423B-80A7-8DC7B630C32F_zps
Had these 1/8 inch tabs floating around from some other project. Drilled the holes out to fit the joint perfectly, and bought some fancy stainless hardware.
7BFC1049-7FBE-42D9-B431-94F9D2498140_zps
It was a blessing in disguise that the bushings were different sizes as well. I took the thick ones and turned them down until I got the thickness of both tabs, and the joint to roughly the same width as the sway bar (like an inch).
3CB19583-8763-4C12-BF93-78F6A5D3CEF9_zps
The tires still bottom out on the frame rail...
80933A27-6377-4D8A-815C-BE5111EFFAE8_zps
And the sway bar clears the rod, no rubbing anywhere and the alignment on the end link looks manageable. Also, I will never drive it at this height since the goddamn tires hit the frame, so it's not like I'm going to be taking turns or bumps like this. The tabs are just tack welded in this photo to make sure this shit was even going to work.
9139325E-BA13-4F57-917E-12E755BDCC84_zps
Another shot of the clearance. I'm sure when the weight of the car is on everything the tire may compress a bit and they will touch... but  I honestly don't have a care, just happy that it's all fitting in there.
C5BEB2DA-CBBB-452D-9A34-BE1A46225156_zps
Decided against trying to tig weld this due to the gaps from trying to weld flat things to round things. Hit it with a quick grind to make it look slightly less redneck.
50DA5098-A379-433D-A5FB-3D2E953401C3_zps
Blasted it with paint and installed it once and for all. I'm nervous to set the car on it though... I'm sure it will be fine, but I've only jacked up one wheel at a time to see if it can do it. I'm mostly worried that it wont go low for some reason, probably because that's why I took it off in the first place.
B0EF0744-C161-4593-8A97-968F3383892F_zps
Got both of these panels in. Now all that's left is the rear panel over the fuel tank.
E6DE38F2-A142-4F6B-8761-4F1735E31AAC_zps
other side. Still gotta finish stitching everything and then clean it up. I'm hoping that the seam sealer will smooth everything out a bit. I also have 8 cans of undercoat to blast everything with, top and bottom.
80D747A2-87E4-4E69-ACC7-5943E7C76873_zps
Speaking of fuel tanks, here's the THIRD one this build. They get nicer and more expensive everytime... fml. It's the one though, fits better than the other two, and has a baffled sump thing and a goddamn pump in it. one hose in, one hose out. Does anybody have any experience with AN fittings? I have some questions.
94D542E2-310B-4F33-A7E5-0F8B5D12A2F0_zps
Also, this. I can't believe I bought this thing for this car. It's going to be awhile before I have another project I think... At least anything like this retarded car.
Seriously starting to question what the fuck I'm doing with my life. Commitment is fucked up.
  • Like 4
whats your question on the AN fittings? i work with them in aircraft but im sure the knowledge can transfer
Well, for starters i'm not sure what size line would suffice for this setup. I was thinking -6, but again, unsure.
The fittings on my tank are -8, if i want to run -6 should I just get an adapter from -8 to -6?
can you go from a slip fitting style into an AN fitting? My fpr i think just has a slip on style fitting, but all of the bungs on the tank are AN.
Just basic shit i guess... just want to clarify some stuff before I dump a couple hundo on lines and fittings.
22666A8F-4389-4B4B-97D5-BFC2A5CC9C7D_zps
Got some brackets made for these. Just took off the sliders and static mounted both as close to the driving position as possible. The mounts I made are preeeeeaty ghetto, but super strong and utilize some of the factory mount reinforcment in the floor, which is nice. I honestly just drilled holes in the bottom of the car to access the hardware. Once I get around to welding up all of the other holes in the floor I'll go pick up some rubber and plug them up for future use, makes taking the seat out so retarded easy.
B7CB693D-66E5-4C16-B6C4-447369DBA458_zps
actually really impressed with the amount of room I have behind the seats. Will be nice for stashing guns and drugs. Also that panel behind the seat isn't welded up yet. I wanted to tack it to the tunnel before welding it in on the far sides of the vehicle.
84AA5968-4A32-4217-A775-DA90667193A5_zps
Man a part of me really doesn't want to build a dash into this car. I think if I sand on the firewall a bit and give it a nice coat of paint it wont look as bad to me. It doesn't feel like a car when you sit in it... there's so much room. A nice little one for my switches and guages might be in order. I'll have to meditate on that.
What kind of seats are those? I love your wagon man. The work is amazing and deeply admired. I wish I could be that good at welding and fabrication. Much respect and keep up the hard work
Awesome stuff going on here , loving the work and the theme .....I had a 72 goon wishing I kept it now , I also find it a blast to work with metal and create what on your mind , sweet ride , hang in there and soon you will be behind the wheel and it will all make sense .....cheers Fast720
They are pro car seats, I don't know the model.
My friend bought a total'd e30 to get the gearbox out of it and these seats were in it, they cost me 100 bucks.
45928D4E-4200-42E7-B9DC-BB1A3DF0E1CE_zps
Got a handful of hours in today. Took down the fuel cell and battery mounts.
F8EB326E-4D13-4831-B336-3067BA6B17A4_zps
Made it so the tank could easily be dropped from beneath the vehicle. I purchased a rubber floor mat to use as the strap rubber, and built it all out of scrap at the shop.
722465F6-4158-4FB9-A1C9-6F911F8C16CD_zps
Had to hang it about a half an inch lower than i wanted to for clearence with the rear floor supports, but it doesn't hang out the ass too badly. I think I can hide it with some form of bumper.
6D93B001-F856-4393-88FF-A0B03ED94807_zps
One more floor panel and It's almost time to paint this bitch and get serious on the dance floor!
I think I would run a foot or so of -8 braided line from the tank to the hard line and then just use a -6 to -8 connector to get to a -6 stainless hard line.
Whats your opinion on just running braided the entire way from the tank to the motor and back? That was my plan.
Been a bit, been trying to get this thing back together.
Found out recently that the lease on our shop will not be getting re-signed... so it's game time to get this thing together enough to go to someone elses place for a little.
240D8D35-8D10-450C-89D7-EB523C233D2C_zps
Checking the air tank fitment. Seems to look alright.
0BA5A65C-1655-4BA1-AE2D-94F454C5D503_zps[/url]
spent probably 7 hours getting the best polish I could on the cage. I'm sure I could have gotten it much more polished, but I'm only one man, and the car is ratty. I like how it looks.
95685C77-7F8F-4DEF-A4CC-ABD2E61D2E13_zps
E8D5ACB0-2D01-404A-8404-79740B33A40A_zps
Went to the wood store and found this nice piece of walnut for the dash.
25845D8E-984C-4DB7-9A2E-C0C9DAD99330_zps
Good sized plank with a small bit of live edge. The live edge is a funny detail, but it was the only rough cut they had in the size I needed so I'm embracing it.
B01D6323-D3B0-424C-8BE9-1C568C0696EC_zps
built my second roll cage.
3F366011-6E94-4628-ADC2-23EBD542C761_zps
I swiped the vents from the original dash. If anyone needs any interior pieces let me know, I have most of it intact still.
767F9A21-A96F-4C04-A3B1-E9E1E5724095_zps
Starting to get the dashboard to fit. It's pretty basic, but it's gonna look nice all stained up. I tried to salvage the factory dash topper that I had, but when I went to notch it for the cage and then take it in and out, and in and out, trying to make it perfect, the corners basically just desintigrated. I have some thicker walnut board i'm going to make the top out of, and then the oringinal dash vent pieces fill the gap to the windshield.
A4195D08-BE7D-4A5E-BD31-4DE8BE44E0A0_zps
Was able to just weld a couple of tabs to the dash bar and bolt it right up. This is not the hardware i'll end up using, but even with just 3 bolts on the bottom, I think it's more than enough to hold up.
3BDB6BDF-755F-441E-9ED5-313E3193537A_zps
made it to the fun part. I screwed up big time on one of the AC vents, which sucks. I'm hoping I can get my hands on a different router bit to fix it though.
7E669E1F-B23C-46D2-9109-640B79520710_zps
This is the vent that I didn't mess up. The mess up isn't really that big of a deal, I just feel like a moron. What happened was... I had to notch the rear of the dash for the oe vents to fit down into the hole, because of the tabs on it, and in doing so, forgot to make the router cuts on both vent holes first. When I went to router the goddamn holes the router slipped into the notch for the tabs and fubared the outer diameter a tiny bit. Again, hopefully fixable with a more aggressive router bit.
CEC94211-D0FB-4EC8-A887-27560D4DA7BF_zps
That second cage I was talking about...
A4B8795B-0316-4AD9-B0FD-D6319CC52CAC_zps
for this shit box... hahaha.
FAFF6471-9982-4FB1-9CCB-D79366584455_zps
It's actually pissed, high compression motor. My friend is just waiting on some rediculous 4500.00 dollar coil overs to show up from belgium or something crazy... I dont know.
5483410D-1171-4245-8F10-94745F103686_zps
Switch panel in the dash.
D88FE08D-DC78-44A0-BBD9-3145A044DCE1_zps
Decided to throw a little datsun emblem in the dash. I wanted to mount it the factory way but there just wasn't a spot it looked nice, So I chiseled out a little spot for it in the center of the dash. Upside down datsun cross, because... man honestly I dont know but it was like 3 am when that happened, metal as fuck or whatever.
838A79FC-D884-4A1F-8F71-330CA0C20816_zps
Wiped this thing down to prepare for clear.
DF25D50F-1ABA-4F76-990F-D9CEA3CA6C80_zps
And then this happened. I think i rushed it a hair because the clear chipped off in a few places, but it's much easier to mask off the panels than the bars, so I'll fix it later.
7646A538-A63E-47A6-889A-AA6537472A26_zps
I seam sealed everything from the underside, and then por-15'd the entire bottom, it's basically the shittiest thing ever if you've never tried it. I have por 15 in my hair, and on my face, but it's almost finished. The bottom is going to get a coat of rubberized as well, and then I can throw the axle back in!
01E99111-378E-4B61-AE15-24242FECD3FF_zps
It's not perfect, but I'm happy with how it looks. As soon as the paint is finished I can start running wires and lines for the bags, and then It's off to Scotty's for intercooler piping and a fuel system!
Working on it everyday, almost there.
  • Like 10
LOL I MADE A WOODEN DASH TOO! I thought I was original but your car is so much cooler you put me to shame. I already finished mine awhile ago just need post pics. Regardless awesome job and it's badass. Don't stop man
C205C029-83D3-4647-88FB-D3F44DB460CC_zps
I have a clutch.
A701A1AE-B28C-4853-A280-EC91186340BA_zps
finished cleaning and spraying the cabin. I pretty much just sanded and cleaned as best I could with solvents and rags. I painted the firewall with BBQ paint flat black. I'm not a very good painter, but for what I'm going for it should be fine.
D3BB9F2D-9E61-4F3A-9924-DE566A454704_zps
Let that Dry and then just went full force. For a home depot color match it's pretty close to the unfaded color of the interior. I really tried to be aware of the patina, so the door sills and such are still original.
4196DCF1-5B95-4201-9059-CD4F19230CD1_zps
threw some foam down on the floor and test fit the carpet, it's pretty weird.
95C66F05-C35D-4D11-B1F8-7485E2B893EA_zps
I wan't sure about painting everything a crazy bright color, but it's really growing on me. I think there's a piece of masking tape on the rear bar in that photo.
AD7F6451-8264-4F87-AE2A-405CD0F35D53_zps
Spent most of yesterday painting and re-painting the entire underside of the car with por-15 and undercoat. It was pretty dry this morning so I tossed the axle and all of the suspension back in today. Kind of aligned it with a tape measure. I torqued it in though, and it looks legit, I hope it works!
7C031C2C-CFCF-48B1-A5DE-F7038A45847E_zps
forgot to mock up the front valence for this photo. Dug out all of my interior tin and trim. Put in a good effort on the dash topper, but I ruined it... trying to cut notches for the cage with the tubing notcher. My friend Hugo is talking about engraving my air tank for me, but we'll see if that happens. We talked about it at the bar so maybe he was just buzzed up, I definitely can't pay for that right now.
Hopefully update soon with an air system...
  • Like 8
