DatDoug Posted May 17, 2011 Report Share Posted May 17, 2011 I thought of this while putting my L20 into my 620 truck today. I want to share it with you all. When putting in the motor the oil pan hits the steering link before you can engage it to the tranny. Instead of taking it out just turn the wheel all the way to one side & you get just the rite amount of clearence. it also helps to have the truck jacked up a little as well as the tranny jacked up all the way to the firewall. Another one is for getting to the pesky bellhousing bolt on the top driversside :angry: Jack up truck get under with a ratchet with all your extentions (about 2 feet worth) and a swivel on the end. Go up thru the tranny tunnel & have some one up top guide you on. Now share your lil tricks :D Quote Link to comment
wayno Posted May 17, 2011 Report Share Posted May 17, 2011 On the 720 series truck, I just unbolt the idler arm and drop it down on that side, and bolt it back in position after the engine is in. Isn't it funny how none of this stuff is in the way when your pulling the engine. Quote Link to comment
datzenmike Posted May 17, 2011 Report Share Posted May 17, 2011 If only changing the head gasket leave manifolds and carb on, saves several PITAs and lots of time. Quote Link to comment
HRH Posted May 17, 2011 Report Share Posted May 17, 2011 Annoyed with upper bellhousing bolts on D21s? Just use a hole saw inside the cab! :D It's way quicker, but I still don't recommend it unless a race truck. Quote Link to comment
DAT510 Posted May 17, 2011 Report Share Posted May 17, 2011 try going through all the smog shit! Quote Link to comment
datzenmike Posted May 17, 2011 Report Share Posted May 17, 2011 To fill tranny oil get kitchen funnel at dollar store and about 3 feet of garden hose. Run hose down beside rear of motor and into the fill hole, stick funnel into other end. It's slow but steady. Quote Link to comment
elmerfudpucker Posted May 17, 2011 Report Share Posted May 17, 2011 have some one up top guide you on. You sound like you have done that before.... ;) :D :lol: When running new wire to your doors or where ever, use car audio 9 conductor line, then you can add to it without needing to rerun more wire and it is weather and wear resistant. Quote Link to comment
DatDoug Posted May 17, 2011 Author Report Share Posted May 17, 2011 Good stuff guys. Keep it coming :D Quote Link to comment
Duke Posted May 17, 2011 Report Share Posted May 17, 2011 On a 510 sedan, replace the studs that mount the mustache bar to the diff cover with bolts. Makes removing the diff much easier in the future. That is the only one that I can think of that is universal. I have so many little tricks that I use that are specific to my car and setup it's not even funny. I guess that is what you get when you have pulled the engine and tranny as many times as I have had to. :blink: Quote Link to comment
datsunaholic Posted May 17, 2011 Report Share Posted May 17, 2011 To remove the stock Hitachi carb (or reinstall) buy the cheapest Chinese 12mm combination wrench and bend the open end over 45 degrees. To remove/install the lower manifold bolts (especially on the 78-80 L20Bs) get a 12mm swivel socket (one with a built in universal) Crank pulley nut won't budge? If the engine is still completely together in the car, put a breaker bar on the bolt and crank it over with the starter. On a 78-81 510, if you break off the hood prop rod retainer, there's a spare behind the grille holding the hood release cable (also useful when junkyarding) Quote Link to comment
wayno Posted May 17, 2011 Report Share Posted May 17, 2011 I fill my transmissions by purchasing one of them fluid moving pumps that you operate with a drill, and a couple feet of clear hose on each end, put one end in the gear lube and the other in the tranny hole, and pull the trigger. Yea, i know they are not for petrolium products, but it beats the @#%& out of using one of them siphon pumps, and a half hour of my time, and the pain in my neck. They last a couple years before the fluids eat the pump out, and I keep the system in a 3 1/2 gallon bucket up on a high shelf out of the way. Quote Link to comment
Wide14u Posted May 17, 2011 Report Share Posted May 17, 2011 here is a trick get your buddy's to do it :rofl: Quote Link to comment
Jayden71 Posted May 17, 2011 Report Share Posted May 17, 2011 here is a trick get your buddy's to do it :rofl: :lol: :lol: Quote Link to comment
Logical1 Posted May 17, 2011 Report Share Posted May 17, 2011 On a 510 sedan, replace the studs that mount the mustache bar to the diff cover with bolts. Makes removing the diff much easier in the future. X2! Just did this when I put my LSD in. My question is there any tangible reason for the studs over bolts? Quote Link to comment
KA620KC Posted May 18, 2011 Report Share Posted May 18, 2011 The best trick I've learned is that if you are a new Datsun owner, JOIN RATSUN!!! 1 Quote Link to comment
Rob W. Posted May 18, 2011 Report Share Posted May 18, 2011 Best trick by far this forum rocks. Read Ratsun drive a better Datsun Quote Link to comment
]2eDeYe Posted May 18, 2011 Report Share Posted May 18, 2011 X2! Just did this when I put my LSD in. My question is there any tangible reason for the studs over bolts? Studs provide more clamping force than just a bolt. Easy way to get to those pesky 620 upper dash bolts. Thats a large phillips bit in the socket. :) Quote Link to comment
Hoosier77 Posted May 18, 2011 Report Share Posted May 18, 2011 When installing a rear main seal on an L series engine go to lowes and get a pvc 4" pipe thread in cap (like you would use on the rear of a potato gun) it fits the seal perfect, and you can hit it hard without it breaking! 1 Quote Link to comment
OMGNOWAI! Posted May 21, 2011 Report Share Posted May 21, 2011 i love this forum already. 1 Quote Link to comment
FoxyRoadster Posted May 21, 2011 Report Share Posted May 21, 2011 2eDeYe' date='18 May 2011 - 11:11 AM' timestamp='1305735117' post='478187']Studs provide more clamping force than just a bolt. Easy way to get to those pesky 620 upper dash bolts. Thats a large phillips bit in the socket. :) Cant fit one of those in the roadster so I ground down a phillips bit and used a pair of vice grips. Quote Link to comment
FoxyRoadster Posted May 21, 2011 Report Share Posted May 21, 2011 also the cardboard beer (dr pepper also) boxes make good transmission and various gaskets Quote Link to comment
Jayden71 Posted May 22, 2011 Report Share Posted May 22, 2011 Crank pulley nut won't budge? If the engine is still completely together in the car, put a breaker bar on the bolt and crank it over with the starter. Just used this trick today as a matter of fact. Thank you!! :D Quote Link to comment
HRH Posted May 22, 2011 Report Share Posted May 22, 2011 When installing a rear main seal on an L series engine go to lowes and get a pvc 4" pipe thread in cap (like you would use on the rear of a potato gun) it fits the seal perfect, and you can hit it hard without it breaking! Holy shit, I never thought of that! F Yeah! I always use my hard wood block (maple or ash) and beat around it carefully. Never had any problems with sealing, but I like your idea much better. Don't have a lathe, so I can't turn my own yet. Quote Link to comment
HRH Posted May 23, 2011 Report Share Posted May 23, 2011 By the way, here's a really good tip. You know those annoying driveshaft center support bearings most Datsun trucks have? (Except 520/521s) It sucks having to press them on and off. The nut torque is something like 174 ft-lbs. It's absolutely retarded. What you can do is chuck the driveline up in a lathe, or if you're patient, take some sandpaper, and cut down the surface the bearing presses onto. I sandpapered mine down so it's still darn tight, but you can run it on with the nut, and tap it off with a hammer. Makes changing out bearings in future one heck of a lot easier. Especially if you find a carrier bearing has been manufactured incorrectly and you have to screw with it to get proper clearance. Quote Link to comment
datsunhead Posted May 24, 2011 Report Share Posted May 24, 2011 keep every datsun key you can find.i have a ring with about 15 random keys....there isnt any datsun i cant start or unlock with my magic ring. Quote Link to comment
