jeffball610 Posted February 27, 2023 Author Report Share Posted February 27, 2023 The brakes seem to be bedding in better, but now the car is torn apart for the next mods. I've been using a stock DSM oil pan for all of the 25k miles I've put on the car. it's not ideal, as the engine sits at an angle in those cars. So I'm going with a RWD oil pan from a Mighty Max/D50. In doing so, I'm making a baffle to control some oil slosh a bit. Nothing fancy. Right now I'm taking out the DSM oil "splash plate" to fit in the Mighty Max pan and go from there. I'm also switching out my turbo setup. The "old" turbo did well for all the miles I've done, but I'm trying to get better spool response for the driving I do. So I'm switching to a 68HTA v3 from Forced Performance. The size comparison is comical. 2 Quote Link to comment
datsunfreak Posted February 27, 2023 Report Share Posted February 27, 2023 4 hours ago, jeffball610 said: The size comparison is comical. Yeah, but I bet the torque comes on a LOT quicker. 😁 I find turbos are a lot like cams. You rarely regret going too small, but almost always regret going too big. Quote Link to comment
jeffball610 Posted February 28, 2023 Author Report Share Posted February 28, 2023 20 hours ago, datsunfreak said: Yeah, but I bet the torque comes on a LOT quicker. 😁 I find turbos are a lot like cams. You rarely regret going too small, but almost always regret going too big. The plan is for quicker spool and better transient response. The turbo I had was great for the 400whp goal that I had. However, just making about 325whp is too much for the 205 width tires. It's a good turbo, but not for my needs at this time. Quote Link to comment
datsunfreak Posted February 28, 2023 Report Share Posted February 28, 2023 3 hours ago, jeffball610 said: However, just making about 325whp is too much for the 205 width tires. Honestly, most (if not all) 510s struggle to handle more 225-250hp. It's tough to ever get enough tire under it to put that kind of power down. But you know that already. 😁 Quote Link to comment
thisismatt Posted February 28, 2023 Report Share Posted February 28, 2023 (edited) What about top end? 75mph passing acceleration? Edited February 28, 2023 by thisismatt Quote Link to comment
Icehouse Posted March 1, 2023 Report Share Posted March 1, 2023 I find at the Autox the off throttle almost the hardest part. Going from any throttle to zero it really upsets the car. I mean that's the fun of a turbo car but wow lots of mind power to get a fast lap. Have you been at all this year? I mean you gotta test those brakes. Quote Link to comment
Stoffregen Motorsports Posted March 1, 2023 Report Share Posted March 1, 2023 8 hours ago, Icehouse said: I find at the Autox the off throttle almost the hardest part. Going from any throttle to zero it really upsets the car. I mean that's the fun of a turbo car but wow lots of mind power to get a fast lap. Have you been at all this year? I mean you gotta test those brakes. Trailing throttle oversteer. Pretty common with a semi trailing arm suspension. The toe changes as the suspension cycles, which is why guys slot their crossmembers. There certainly is a balance between traction, horsepower and aerodynamic drag. To get a tire big enough to handle lots of HP, the car ends up being so wide that it pushes way more air. Top speed on a 510 is about 135 mph. I don't care how much HP you have, that's about it for a flying shoebox. Quote Link to comment
datsunfreak Posted March 2, 2023 Report Share Posted March 2, 2023 On 3/1/2023 at 10:07 AM, Stoffregen Motorsports said: Top speed on a 510 is about 135 mph. I don't care how much HP you have, that's about it for a flying shoebox. Depends. 😁 Bursts, or sustained? Because this one goes to 11, aka 142mph... http://www.speedhunters.com/2012/10/a-9-second-700hp-street-legal-datsun-510/ A friend who has a 400hp 510 once did the math (smarty pants engineer), and said what you said. 130ish is the limit of a streetable car. But that's because 10 miles an hour over that requires an additional 100hp, then 10 more over that requires another 200hp more, then 10 over that would need 400hp more, etc. 1 Quote Link to comment
Stoffregen Motorsports Posted March 3, 2023 Report Share Posted March 3, 2023 5 hours ago, datsunfreak said: Depends. 😁 Bursts, or sustained? Because this one goes to 11, aka 142mph... http://www.speedhunters.com/2012/10/a-9-second-700hp-street-legal-datsun-510/ A friend who has a 400hp 510 once did the math (smarty pants engineer), and said what you said. 130ish is the limit of a streetable car. But that's because 10 miles an hour over that requires an additional 100hp, then 10 more over that requires another 200hp more, then 10 over that would need 400hp more, etc. That's awesome. We learned that the hard way, when all we needed was a smarty pants engineer. The cars we learned on were GT spec SCCA racers. You could get them to work with wide tires and box flares, but then you're as wide as you are long, hence the shoebox. Similarly, Lamborghini had a challenge a few years ago to make the lightest street legal car they could make. This was started by a debate about the weight of modern cars as compared to (in this case) a 1990 Honda Civic. Turns out, even with all the carbon fiber and lightweight materials and CNC machining, their street legal car, with approved crash standards, was still something like 3500 pounds. Makes you wonder what a car company like Lamborghini could do with a 510 shaped brick. Quote Link to comment
datsunfreak Posted March 3, 2023 Report Share Posted March 3, 2023 11 hours ago, Stoffregen Motorsports said: all we needed was a smarty pants engineer. They do come in handy on occasion. 😄 11 hours ago, Stoffregen Motorsports said: Makes you wonder what a car company like Lamborghini could do with a 510 shaped brick. 1 1 Quote Link to comment
paradime Posted March 3, 2023 Report Share Posted March 3, 2023 this one goes 143 mph 1 Quote Link to comment
iceman510 Posted March 3, 2023 Report Share Posted March 3, 2023 Not with all that backpressure. 2 Quote Link to comment
paradime Posted March 4, 2023 Report Share Posted March 4, 2023 It's Bōsōzoku, so it's not called "backpressure". It's "boost"; from an expertly tuned sonic pulse vectoring passive turbo exhaust system. Very cutting edge, but for deeper technical specs, refer to the manga Akira. 1 1 Quote Link to comment
iceman510 Posted March 4, 2023 Report Share Posted March 4, 2023 Ahh, manga, so it's allowed to be pretend. 😉 2 Quote Link to comment
datzenmike Posted March 5, 2023 Report Share Posted March 5, 2023 On 3/2/2023 at 1:00 PM, datsunfreak said: Depends. 😁 Bursts, or sustained? Because this one goes to 11, aka 142mph... http://www.speedhunters.com/2012/10/a-9-second-700hp-street-legal-datsun-510/ A friend who has a 400hp 510 once did the math (smarty pants engineer), and said what you said. 130ish is the limit of a streetable car. But that's because 10 miles an hour over that requires an additional 100hp, then 10 more over that requires another 200hp more, then 10 over that would need 400hp more, etc. Air resistance quadruples with every doubling of speed. All other losses ignored if it takes 100 HP to go 100 MPH then to go 200 MPH you will need an additional 400HP. 1 Quote Link to comment
paradime Posted March 5, 2023 Report Share Posted March 5, 2023 19 minutes ago, datzenmike said: Air resistance quadruples with every doubling of speed. All other losses ignored if it takes 100 HP to go 100 MPH then to go 200 MPH you will need an additional 400HP. Terminal velocity is 120mph, so theoretically, my 400HP 510 should do 250mph going down a 50% grade, but my 510 tapped out at about 145ish going down the Grape Vine on Interstate 5. What gives? I suck at math, but I have internet access to people who don't. The power required for a 510 to overcome aerodynamic drag is not a direct 1:4 ratio. It increases as the cube of it's velocity as . I have no idea what all that shit means but... Absent all other sources of drag, the power needed to push a 510 down the freeway at 50mph might require 10hp. Double it to 100mph and it requires 80hp. Not inviting all the obvious drag coefficients of a short wheel base shoebox, and a host of other fancy drags I'm not thinking of, 200mph would require 640hp. My guess is the hood latch would give up at about 156.3mph, act like a front wing, and make it to 158 before flying into on coming traffic. 1 Quote Link to comment
Stoffregen Motorsports Posted March 5, 2023 Report Share Posted March 5, 2023 4 minutes ago, paradime said: I have no idea what all that shit means but... Yup. I got nothin... 1 Quote Link to comment
Satisaii Posted March 5, 2023 Report Share Posted March 5, 2023 I can explain it, but it is work/time and I am out of time. 1 Quote Link to comment
jeffball610 Posted June 12, 2023 Author Report Share Posted June 12, 2023 Looks like my build page turned into a debate about off topics. In any case, I finally got the car back together and sorted. The new turbo is awesome and much easier to control than the previous setup. I'm still getting used to how power comes on and how to control it. I make 12psi at 50% throttle and I'm only running about 16psi to manage traction in lower gears. Here's a quick stitch of Sunday's autocross event at the Corvetter Museum course with KYSCCA. Sorry for the crap camera mount on my helmet and the weird crop to the video. KYSCCA 6-11-23 3 Quote Link to comment
datsunfreak Posted June 12, 2023 Report Share Posted June 12, 2023 1 hour ago, jeffball610 said: Looks like my build page turned into a debate about off topics. 1 Quote Link to comment
datzenmike Posted June 12, 2023 Report Share Posted June 12, 2023 My '70 Dart rated at 275 fact0ry (for insurance) was well over 300hp. A friend with the same car dynoed @ 310. Mine would do just under a buck fifty-five @ 6,100 and it's larger than a 510 1 Quote Link to comment
Duncan Posted June 13, 2023 Report Share Posted June 13, 2023 On 3/3/2023 at 12:37 PM, paradime said: this one goes 143 mph Over a cliff on the way down, maybe? Quote Link to comment
paradime Posted June 14, 2023 Report Share Posted June 14, 2023 21 minutes ago, Duncan said: Over a cliff on the way down, maybe? That's its Bōsōzoku clocked top speed. Using their official watch-o-matic 9000. 1 1 Quote Link to comment
jeffball610 Posted Monday at 03:53 PM Author Report Share Posted Monday at 03:53 PM I haven't done much with the car due to weather and just not being confident. I put all of that aside yesterday and went to a local autocross event. The car did great and I'm making plans to drive it even more. I still need to improve my driving and I want to improve the brake feel and performance. But otherwise, I'm happy with where the car is right now while I make more plans to improve it in the future. 2 Quote Link to comment
