datzenmike Posted January 19, 2014 Report Share Posted January 19, 2014 Basically a Z22 crank, rods and block bored to 89mm and fitted with KA24E pistons... 2288cc. Could be also called a Big Bore 2.3 Quote Link to comment
ggzilla Posted January 19, 2014 Report Share Posted January 19, 2014 Datsun engines are often fine after sitting many years. Quote Link to comment
relaxed atmosphere Posted January 21, 2014 Report Share Posted January 21, 2014 thanks Will,this car was carried by US Army assigned in Subic Bay Naval Base, Phils. thanks for the info about that emblem.. @vern_k - appreciate it man..please feel free to PM me.. Quote Link to comment
ArchetypeDatsun Posted January 23, 2014 Report Share Posted January 23, 2014 There's an 81 200sx for $200 http://bend.craigslist.org/cto/4264067399.html Quote Link to comment
Will Posted January 23, 2014 Report Share Posted January 23, 2014 There's an 81 200sx for $200 http://bend.craigslist.org/cto/4264067399.html Aluminum Datsun wheels - with free car included! Quote Link to comment
vern_k Posted January 24, 2014 Report Share Posted January 24, 2014 All S110 engines are a direct swap. Only difference is some of the 1980 models don't have an O2 sensor. Z20E and Z22E run the same wiring/plugs. Ideally you should swap to the Z22 ECU, but you can tweak the MAF to make the bigger engine work, or just drive it as is as long as you don;t beat on it too hard. Even the Z24 from a truck is a good option, but will require swapping over your oil pan, intake and exhaust, then retuning the MAF. :thumbup: Would love to do a KA24E swap in one. It will bolt up to the stock trans, use the stock engine mounts, and the stock fuel pump. Just need to bolt it in and figure out the wiring. :thumbup: there are some changes between the Z20E and the Z22E like 4 or 8 spark plugs, Z20E is group fired injectors, but yes could be over come with ECU and distributor, but in theroy you could use a Z22E ecu and distibutor on a Z20E engine but would be a step back going the other way i think since you would be dropping it to group fire..... Quote Link to comment
ggzilla Posted January 24, 2014 Report Share Posted January 24, 2014 Sequential fire has superior emissions, so you'd lose that. Quote Link to comment
vern_k Posted January 24, 2014 Report Share Posted January 24, 2014 I may get a 200sx '80 or '81 I think. The motor's been sitting for years so toast? What are my options on an old car like this? Sorry for being so vague, I just don't know what I'll do. Need inspiration... I'll have a Z20 up for grabs soon if you wish to go that way Quote Link to comment
datsunfreak Posted January 25, 2014 Report Share Posted January 25, 2014 there are some changes between the Z20E and the Z22E like 4 or 8 spark plugs, Actually, that's a year thing, not an engine thing. Non-California 1980 models are 4-plug, all the rest are 8-plug. So the Z20E came both ways. Z20E is group fired injectors, but yes could be over come with ECU and distributor, but in theroy you could use a Z22E ecu and distibutor on a Z20E engine but would be a step back going the other way i think since you would be dropping it to group fire. Well, most of the Z24 engines are throttle-body-injected (or carbureted), so even the batch-fire Z20E/Z22E management is really a step up. Almost every Nissan engine was batch-fire up until the late 80s. Quote Link to comment
captaingamez Posted February 3, 2014 Report Share Posted February 3, 2014 This is going to be my next car, a coupe. Quote Link to comment
CerealWars Posted February 4, 2014 Report Share Posted February 4, 2014 Agreed, that'd make a sweet little daily slider, that coupe on meshies looks too sick. Quote Link to comment
captaingamez Posted February 4, 2014 Report Share Posted February 4, 2014 Daily time attack car in my case, drifting bores me lifeless B) . MUST HAVE S12 COUPE with FJ or CA18 TURBO!!!!! Quote Link to comment
Tristin Posted February 4, 2014 Report Share Posted February 4, 2014 Daily time attack car in my case, drifting bores me lifeless B) . MUST HAVE S12 COUPE with FJ or CA18 TURBO!!!!! Im trying to secure a coupe for myself as well, but with a KA in mind. 1 Quote Link to comment
captaingamez Posted February 4, 2014 Report Share Posted February 4, 2014 DOOOOO EEET!! Quote Link to comment
captaingamez Posted February 4, 2014 Report Share Posted February 4, 2014 They are really cool cars, very similar in build to the Maxima and 280ZX. I think 85 and up got IRS right? The turbos and VG30 ones are hella hard to find, but only came in hatchbacks. But the coupe is so sexy. Quote Link to comment
vern_k Posted February 12, 2014 Report Share Posted February 12, 2014 anybody wants some Z20 parts get them before they go to the junk yard please..... http://community.ratsun.net/classifieds/item/3029-z20-parts/ Quote Link to comment
relaxed atmosphere Posted February 12, 2014 Report Share Posted February 12, 2014 @vern_k-from what car does this Z20 came from? Quote Link to comment
relaxed atmosphere Posted February 13, 2014 Report Share Posted February 13, 2014 thanks for sharing! Quote Link to comment
Will Posted February 13, 2014 Report Share Posted February 13, 2014 ...but I DO have a soft spot for sheetmetal freaks! Quote Link to comment
vern_k Posted February 13, 2014 Report Share Posted February 13, 2014 @vern_k-from what car does this Z20 came from? 1980-81 200sx Quote Link to comment
Seeker > 620 KC Posted February 13, 2014 Report Share Posted February 13, 2014 I sure got a kick out of the article, especially the graph of the 200sx beating the Dodge challenger in the standing 1/4 mile by a fraction of a second! True? who knows. Entertaining?.. for sure! lol . Anybody still have the battery fluid monitoring sending unit(s) from their 1979-81 200sx they could take a picture of and post? From the manual it looks like it might require a pair? I've got a 1980 and the guages and system check all seem to work, but I don't have the sending units. My Nissan Parts girl says: Part number is 24412-U7610 and it fits S110 01/79-06/81 and S130 (280zx) 07/78-08/81. The bad part is she says the part is "disco" by Nissan and I haven't a clue what it looks like. :confused: Worse yet...every So Cal. junkyard 280 ZX I've looked in already had the battery cables and harnesses cut, rather than unbolted. ( I miss my old sheetmetal freak who moved away. Wish I could find another in north county San Diego.) Also looking for a good working turn signal switch. (Couldn't resist, Sorry DZM.) Quote Link to comment
