What did you do to your dime today?
Mesh-71
Well...i failed to upholster the bottom of rear seat....so....seat cover it is til I can afford it....cleaned up the rear seat, did some stiching.....and put a seat cover....doesn't look bad....
And I decided to go loar....I couldn't slide the c clamps anymore due to clearance issues....so I cut another coil....I got clearance now and doesn't bottom out....looks lots better...
Oh and I found that burning rubber I kept in smelling when going around corners hard on the poker run couple weekends ago....was the pulley from the alternator ever so slightly rubbing on the bottom coolant hose from the radiator...now it's got more clearance and the hose doesn't look gashed at all, there just was rubber shavings in the area, no damage, will keep an eye on it....
  • Replies 4.2k
Out riding now, started getting the brakes working on the goon.
Working on the brakes and clutch.
These were a mother fuc wate I'm sorry it's Mother's Day I should not say that, hard to get off after a long time being on and many years of not being used.
Finally got a new windshield installed. The old one was so cloudy it really sucked to look through it. The guy that did the work has been doing windshields since the 70s. Nice to find someone that could do it right and not damage the stainless trim.
He pulled the glass and we found some minor rust damage so I sanded it all down, treated it with several coats of Zero Rust and then used JB Weld to close up the little holes. Once it dried, I used my dremel to smooth it down and guide any water towards the drain so hopefully, there will be no issues in the future.
0581C615-18DF-4C29-9FBB-F7973C282719_zps
C0C6FD88-69B9-4119-8F84-EA3BB6763461_zps
C4B00776-834F-45E4-84DA-8DDA8207DE59_zps
4C2EF98A-3027-41B7-940C-ADDB73A5B6D9_zps
85267A5A-1AE9-4CF3-9474-30A0BA072884_zps
8A32176E-04C6-4607-8975-426BB5CEA1CB_zps
D2221176-417C-43A8-82BC-79A475905B08_zps
5D438F9D-D855-4758-AB92-71C30981CA51_zps
I am quite happy with the new glass. It is so crystal clear. It's like driving a different car. It is also tinted across the top which is really nice on a bright day.
While I had it all apart, I pulled the cowl panel and lubed up the wiper assembly and installed my Mazda Wiper Motor Conversion. Thanks Kelvin and thanks James, the 510 keeper, for the help with that.
30FFFB59-1771-4356-8938-A80746CE63F3_zps
  • Like 4
got rid of the POS mr gasket throttle cable ( although it has served its purpose for about 3 years )
installed a lokar cable and what a difference in quality
the cable is stranded tighter the housing is made better and the end links are all metal not plastic garbage
the housing is smaller diameter but built much better than the MR gasket one
 I guess sometimes smaller is better :thumbup:  :thumbup:  :thumbup:
IMG_20160514_164130424_zpsxtbcoux2.jpgIMG_20160514_164141586_HDR_zpsrqdbg1ne.jIMG_20160514_164149511_zpstdochig7.jpg
a much tighter slot on the Lokar cable
TIGHTER IS ALWAYS BETTER
unless it doesent fit
the Lokar cable is smoother feeling and better overall quality  I am very happy
